[postgis-tickets] [PostGIS] #4330: postgis_restore fails when output piped to an intermediate process
trac at osgeo.org
Wed Feb 20 08:38:24 PST 2019
Reporter: hranalli | Owner: strk
Type: patch | Status: new
Priority: medium | Milestone: PostGIS 2.5.2
Component: build/upgrade/install | Version: 2.5.x
Keywords: |
We are upgrading a database from Postgres 8.2.23 and PostGIS 1.4 to
PostgreSQL 11.2 and PostGIS 2.5. As part of our process, we pipe the
output of postgis_restore.pl to sed, whic makes some changes to the SQL
before it is piped to psql.
When we do this, postgis_restore buffers the output in memory, and then is
killed by the OS when it runs out of memory. I've created a patch that
eliminates this buffering in the places where it is unnecessary (the
culprit is in the TABLE DATA commands, as these are the most memory
intensive).
Once postgis_restore is run with the patch in place, it does a fine job of
upgrading the database.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4330>
