[postgis-tickets] r17271 - Replace VARSIZE(foo)-VARHDRSZ pattern with VARSIZE_ANY_EXHDR(foo)
Raúl Marín Rodríguez rmrodriguez at carto.com
Fri Feb 22 09:01:54 PST 2019
Nice!
On Fri, Feb 22, 2019 at 5:51 PM Paul Ramsey <pramsey at cleverelephant.ca> wrote:
> Author: pramsey
> Date: 2019-02-22 08:51:34 -0800 (Fri, 22 Feb 2019)
> New Revision: 17271
> Modified:
>    trunk/extensions/address_standardizer/address_parser.c
>    trunk/extensions/address_standardizer/address_standardizer.c
>    trunk/postgis/geography_inout.c
>    trunk/postgis/gserialized_estimate.c
>    trunk/postgis/gserialized_gist_nd.c
>    trunk/postgis/lwgeom_export.c
>    trunk/postgis/lwgeom_in_geojson.c
>    trunk/postgis/lwgeom_in_gml.c
>    trunk/postgis/lwgeom_in_kml.c
>    trunk/postgis/lwgeom_inout.c
>    trunk/postgis/lwgeom_ogc.c
>    trunk/postgis/mvt.c
>    trunk/raster/rt_pg/rtpg_gdal.c
>    trunk/raster/rt_pg/rtpg_inout.c
>    trunk/raster/rt_pg/rtpg_wkb.c
> Log:
> macro from standard Pg.
> Modified: trunk/extensions/address_standardizer/address_parser.c
> --- trunk/extensions/address_standardizer/address_parser.c      2019-02-21 20:44:29 UTC (rev 17270)
> +++ trunk/extensions/address_standardizer/address_parser.c      2019-02-22 16:51:34 UTC (rev 17271)
> @@ -22,14 +22,6 @@
>  Datum parse_address(PG_FUNCTION_ARGS);
> -static char *text2char(text *in)
> -    char *out = palloc(VARSIZE(in));
> -    memcpy(out, VARDATA(in), VARSIZE(in) - VARHDRSZ);
> -    out[VARSIZE(in) - VARHDRSZ] = '\0';
> -    return out;
>  PG_FUNCTION_INFO_V1(parse_address);
> @@ -47,7 +39,7 @@
>      DBG("Start standardize_address");
> -    str = text2char(PG_GETARG_TEXT_P(0));
> +    str = text_to_cstring(PG_GETARG_TEXT_P(0));
>      DBG("str='%s'", str);
> Modified: trunk/extensions/address_standardizer/address_standardizer.c
> --- trunk/extensions/address_standardizer/address_standardizer.c        2019-02-21 20:44:29 UTC (rev 17270)
> +++ trunk/extensions/address_standardizer/address_standardizer.c        2019-02-22 16:51:34 UTC (rev 17271)
> @@ -19,14 +19,6 @@
>  Datum standardize_address1(PG_FUNCTION_ARGS);
> -    return out;
>   * The signature for standardize_address follows. The lextab, gaztab and
>   * rultab should not change once the reference has been standardized and
> @@ -80,11 +72,11 @@
> -    lextab = text2char(PG_GETARG_TEXT_P(0));
> -    gaztab = text2char(PG_GETARG_TEXT_P(1));
> -    rultab = text2char(PG_GETARG_TEXT_P(2));
> -    micro  = text2char(PG_GETARG_TEXT_P(3));
> -    macro  = text2char(PG_GETARG_TEXT_P(4));
> +    lextab = text_to_cstring(PG_GETARG_TEXT_P(0));
> +    gaztab = text_to_cstring(PG_GETARG_TEXT_P(1));
> +    rultab = text_to_cstring(PG_GETARG_TEXT_P(2));
> +    micro  = text_to_cstring(PG_GETARG_TEXT_P(3));
> +    macro  = text_to_cstring(PG_GETARG_TEXT_P(4));
>      DBG("calling RelationNameGetTupleDesc");
>      if (get_call_result_type( fcinfo, NULL, &tuple_desc ) != TYPEFUNC_COMPOSITE ) {
> @@ -167,10 +159,10 @@
> -    addr   = text2char(PG_GETARG_TEXT_P(3));
> +    addr   = text_to_cstring(PG_GETARG_TEXT_P(3));
> Modified: trunk/postgis/geography_inout.c
> --- trunk/postgis/geography_inout.c     2019-02-21 20:44:29 UTC (rev 17270)
> +++ trunk/postgis/geography_inout.c     2019-02-22 16:51:34 UTC (rev 17271)
> @@ -260,7 +260,7 @@
>         if (PG_NARGS() >4 && !PG_ARGISNULL(4))
>                 prefix_text = PG_GETARG_TEXT_P(4);
> -               if ( VARSIZE(prefix_text)-VARHDRSZ == 0 )
> +               if ( VARSIZE_ANY_EXHDR(prefix_text) == 0 )
>                         prefix = "";
> @@ -267,12 +267,12 @@
>                 else
>                         /* +2 is one for the ':' and one for term null */
> -                       prefix_buf = palloc(VARSIZE(prefix_text)-VARHDRSZ+2);
> -                       memcpy(prefix_buf, VARDATA(prefix_text),
> -                              VARSIZE(prefix_text)-VARHDRSZ);
> +                       prefix_buf = palloc(VARSIZE_ANY_EXHDR(prefix_text)+2);
> +                       memcpy(prefix_buf, VARDATA_ANY(prefix_text),
> +                              VARSIZE_ANY_EXHDR(prefix_text));
>                         /* add colon and null terminate */
> -                       prefix_buf[VARSIZE(prefix_text)-VARHDRSZ] = ':';
> -                       prefix_buf[VARSIZE(prefix_text)-VARHDRSZ+1] = '\0';
> +                       prefix_buf[VARSIZE_ANY_EXHDR(prefix_text)] = ':';
> +                       prefix_buf[VARSIZE_ANY_EXHDR(prefix_text)+1] = '\0';
>                         prefix = prefix_buf;
> @@ -281,15 +281,15 @@
>         if (PG_NARGS() >5 && !PG_ARGISNULL(5))
>                 id_text = PG_GETARG_TEXT_P(5);
> -               if ( VARSIZE(id_text)-VARHDRSZ == 0 )
> +               if ( VARSIZE_ANY_EXHDR(id_text) == 0 )
>                         id = "";
>                 else
> -                       id_buf = palloc(VARSIZE(id_text)-VARHDRSZ+1);
> -                       memcpy(id_buf, VARDATA(id_text), VARSIZE(id_text)-VARHDRSZ);
> -                       prefix_buf[VARSIZE(id_text)-VARHDRSZ+1] = '\0';
> +                       id_buf = palloc(VARSIZE_ANY_EXHDR(id_text)+1);
> +                       memcpy(id_buf, VARDATA(id_text), VARSIZE_ANY_EXHDR(id_text));
> +                       prefix_buf[VARSIZE_ANY_EXHDR(id_text)+1] = '\0';
>                         id = id_buf;
> @@ -389,7 +389,7 @@
>         if (PG_NARGS() >3 && !PG_ARGISNULL(3))
>                 prefix_text = PG_GETARG_TEXT_P(3);
>                         prefix = "";
> @@ -396,12 +396,12 @@
>                 else
> -                       prefixbuf = palloc(VARSIZE(prefix_text)-VARHDRSZ+2);
> +                       prefixbuf = palloc(VARSIZE_ANY_EXHDR(prefix_text)+2);
>                         memcpy(prefixbuf, VARDATA(prefix_text),
> -                       prefixbuf[VARSIZE(prefix_text)-VARHDRSZ] = ':';
> -                       prefixbuf[VARSIZE(prefix_text)-VARHDRSZ+1] = '\0';
> +                       prefixbuf[VARSIZE_ANY_EXHDR(prefix_text)] = ':';
> +                       prefixbuf[VARSIZE_ANY_EXHDR(prefix_text)+1] = '\0';
>                         prefix = prefixbuf;
> Modified: trunk/postgis/gserialized_estimate.c
> --- trunk/postgis/gserialized_estimate.c        2019-02-21 20:44:29 UTC (rev 17270)
> +++ trunk/postgis/gserialized_estimate.c        2019-02-22 16:51:34 UTC (rev 17271)
> @@ -304,7 +304,7 @@
>         int mode = 2;
>         char *modestr;
> -       if (VARSIZE(txt) - VARHDRSZ <= 0)
> +       if (VARSIZE_ANY_EXHDR(txt) <= 0)
>                 return mode;
>         modestr = (char*)VARDATA(txt);
>         if ( modestr[0] == 'N' )
> Modified: trunk/postgis/gserialized_gist_nd.c
> --- trunk/postgis/gserialized_gist_nd.c 2019-02-21 20:44:29 UTC (rev 17270)
> +++ trunk/postgis/gserialized_gist_nd.c 2019-02-22 16:51:34 UTC (rev 17271)
> @@ -141,7 +141,7 @@
>  inline bool
>  gidx_is_unknown(const GIDX *a)
> -       size_t size = VARSIZE(a) - VARHDRSZ;
> +       size_t size = VARSIZE_ANY_EXHDR(a);
>         /* "unknown" gidx objects have a too-small size of one float */
>         if (size <= 0.0)
>                 return true;
> Modified: trunk/postgis/lwgeom_export.c
> --- trunk/postgis/lwgeom_export.c       2019-02-21 20:44:29 UTC (rev 17270)
> +++ trunk/postgis/lwgeom_export.c       2019-02-22 16:51:34 UTC (rev 17271)
> @@ -233,7 +233,7 @@
>                 else
> -                       len = VARSIZE(prefix_text)-VARHDRSZ;
> +                       len = VARSIZE_ANY_EXHDR(prefix_text);
>                         prefix_buf = palloc(len + 2); /* +2 is one for the ':' and one for term null */
>                         memcpy(prefix_buf, VARDATA(prefix_text), len);
> @@ -252,7 +252,7 @@
>                 else
> -                       len = VARSIZE(gml_id_text)-VARHDRSZ;
> +                       len = VARSIZE_ANY_EXHDR(gml_id_text);
>                         gml_id_buf = palloc(len+1);
>                         memcpy(gml_id_buf, VARDATA(gml_id_text), len);
>                         gml_id_buf[len] = '\0';
> @@ -355,7 +355,7 @@
>                         prefix = "";
> @@ -362,12 +362,12 @@
>                 else
>                         prefix = prefixbuf;
> @@ -581,7 +581,7 @@
>                 defid_text = PG_GETARG_TEXT_P(4);
> -               if ( VARSIZE(defid_text)-VARHDRSZ == 0 )
> +               if ( VARSIZE_ANY_EXHDR(defid_text) == 0 )
>                         defid = "";
> @@ -588,12 +588,12 @@
>                 else
> -                       defidbuf = palloc(VARSIZE(defid_text)-VARHDRSZ+2);
> +                       defidbuf = palloc(VARSIZE_ANY_EXHDR(defid_text)+2);
>                         memcpy(defidbuf, VARDATA(defid_text),
> -                              VARSIZE(defid_text)-VARHDRSZ);
> +                              VARSIZE_ANY_EXHDR(defid_text));
> -                       defidbuf[VARSIZE(defid_text)-VARHDRSZ] = ':';
> -                       defidbuf[VARSIZE(defid_text)-VARHDRSZ+1] = '\0';
> +                       defidbuf[VARSIZE_ANY_EXHDR(defid_text)] = ':';
> +                       defidbuf[VARSIZE_ANY_EXHDR(defid_text)+1] = '\0';
>                         defid = defidbuf;
> Modified: trunk/postgis/lwgeom_in_geojson.c
> --- trunk/postgis/lwgeom_in_geojson.c   2019-02-21 20:44:29 UTC (rev 17270)
> +++ trunk/postgis/lwgeom_in_geojson.c   2019-02-22 16:51:34 UTC (rev 17271)
> @@ -51,7 +51,7 @@
>  static char*
>  text2cstring(const text *textptr)
> -       size_t size = VARSIZE(textptr) - VARHDRSZ;
> +       size_t size = VARSIZE_ANY_EXHDR(textptr);
>         char *str = lwalloc(size+1);
>         memcpy(str, VARDATA(textptr), size);
>         str[size]='\0';
> Modified: trunk/postgis/lwgeom_in_gml.c
> --- trunk/postgis/lwgeom_in_gml.c       2019-02-21 20:44:29 UTC (rev 17270)
> +++ trunk/postgis/lwgeom_in_gml.c       2019-02-22 16:51:34 UTC (rev 17271)
> @@ -108,7 +108,7 @@
>         if (PG_ARGISNULL(0)) PG_RETURN_NULL();
>         xml_input = PG_GETARG_TEXT_P(0);
>         xml = text_to_cstring(xml_input);
> -       xml_size = VARSIZE(xml_input) - VARHDRSZ;
> +       xml_size = VARSIZE_ANY_EXHDR(xml_input);
>         /* Zero for undefined */
>         root_srid = PG_GETARG_INT32(1);
> Modified: trunk/postgis/lwgeom_in_kml.c
> --- trunk/postgis/lwgeom_in_kml.c       2019-02-21 20:44:29 UTC (rev 17270)
> +++ trunk/postgis/lwgeom_in_kml.c       2019-02-22 16:51:34 UTC (rev 17271)
> @@ -86,7 +86,7 @@
>         /* Begin to Parse XML doc */
>         xmlInitParser();
> Modified: trunk/postgis/lwgeom_inout.c
> --- trunk/postgis/lwgeom_inout.c        2019-02-21 20:44:29 UTC (rev 17270)
> +++ trunk/postgis/lwgeom_inout.c        2019-02-22 16:51:34 UTC (rev 17271)
> @@ -374,7 +374,7 @@
>         LWGEOM *lwgeom;
>         uint8_t *wkb = (uint8_t*)VARDATA(bytea_wkb);
> -       lwgeom = lwgeom_from_wkb(wkb, VARSIZE(bytea_wkb)-VARHDRSZ, LW_PARSER_CHECK_ALL);
> +       lwgeom = lwgeom_from_wkb(wkb, VARSIZE_ANY_EXHDR(bytea_wkb), LW_PARSER_CHECK_ALL);
>         if (  ( PG_NARGS()>1) && ( ! PG_ARGISNULL(1) ))
> @@ -403,7 +403,7 @@
>         LWGEOM *lwgeom;
>         uint8_t *twkb = (uint8_t*)VARDATA(bytea_twkb);
> -       lwgeom = lwgeom_from_twkb(twkb, VARSIZE(bytea_twkb)-VARHDRSZ, LW_PARSER_CHECK_ALL);
> +       lwgeom = lwgeom_from_twkb(twkb, VARSIZE_ANY_EXHDR(bytea_twkb), LW_PARSER_CHECK_ALL);
>         if ( lwgeom_needs_bbox(lwgeom) )
>                 lwgeom_add_bbox(lwgeom);
> @@ -443,7 +443,7 @@
>                         variant = variant | WKB_NDR;
> -       wkb_size= VARSIZE(geom) - VARHDRSZ;
> +       wkb_size= VARSIZE_ANY_EXHDR(geom);
>         /* Create WKB hex string */
>         lwgeom = lwgeom_from_gserialized(geom);
> Modified: trunk/postgis/lwgeom_ogc.c
> --- trunk/postgis/lwgeom_ogc.c  2019-02-21 20:44:29 UTC (rev 17270)
> +++ trunk/postgis/lwgeom_ogc.c  2019-02-22 16:51:34 UTC (rev 17271)
> @@ -830,7 +830,7 @@
>         LWGEOM *lwgeom;
> Modified: trunk/postgis/mvt.c
> --- trunk/postgis/mvt.c 2019-02-21 20:44:29 UTC (rev 17270)
> +++ trunk/postgis/mvt.c 2019-02-22 16:51:34 UTC (rev 17271)
> @@ -1183,7 +1183,7 @@
>                 NULL
> -       size_t len = VARSIZE(ba) - VARHDRSZ;
> +       size_t len = VARSIZE_ANY_EXHDR(ba);
>         VectorTile__Tile *tile = vector_tile__tile__unpack(&allocator, len, (uint8_t*)VARDATA(ba));
>         mvt_agg_context *ctx = palloc(sizeof(mvt_agg_context));
>         memset(ctx, 0, sizeof(mvt_agg_context));
> Modified: trunk/raster/rt_pg/rtpg_gdal.c
> --- trunk/raster/rt_pg/rtpg_gdal.c      2019-02-21 20:44:29 UTC (rev 17270)
> +++ trunk/raster/rt_pg/rtpg_gdal.c      2019-02-22 16:51:34 UTC (rev 17271)
> @@ -77,7 +77,7 @@
>         /* get data */
>         bytea_data = (bytea *) PG_GETARG_BYTEA_P(0);
>         data = (uint8_t *) VARDATA(bytea_data);
> -       data_len = VARSIZE(bytea_data) - VARHDRSZ;
> +       data_len = VARSIZE_ANY_EXHDR(bytea_data);
>         /* process srid */
>         /* NULL srid means try to determine SRID from bytea */
> @@ -321,7 +321,7 @@
>                 PG_RETURN_NULL();
>         SET_VARSIZE(result, result_size);
> -       memcpy(VARDATA(result), gdal, VARSIZE(result) - VARHDRSZ);
> +       memcpy(VARDATA(result), gdal, VARSIZE_ANY_EXHDR(result));
>         /* free gdal mem buffer */
>         CPLFree(gdal);
> Modified: trunk/raster/rt_pg/rtpg_inout.c
> --- trunk/raster/rt_pg/rtpg_inout.c     2019-02-21 20:44:29 UTC (rev 17270)
> +++ trunk/raster/rt_pg/rtpg_inout.c     2019-02-22 16:51:34 UTC (rev 17271)
> @@ -142,7 +142,7 @@
>         result_size = wkb_size + VARHDRSZ;
>         result = (bytea *)palloc(result_size);
> -       memcpy(VARDATA(result), wkb, VARSIZE(result) - VARHDRSZ);
> +       memcpy(VARDATA(result), wkb, VARSIZE_ANY_EXHDR(result));
>         /* Free raster objects used */
>         rt_raster_destroy(raster);
> Modified: trunk/raster/rt_pg/rtpg_wkb.c
> --- trunk/raster/rt_pg/rtpg_wkb.c       2019-02-21 20:44:29 UTC (rev 17270)
> +++ trunk/raster/rt_pg/rtpg_wkb.c       2019-02-22 16:51:34 UTC (rev 17271)
> @@ -81,7 +81,7 @@
>         result = (char *)palloc(result_size);
> @@ -153,7 +153,7 @@
>         raster = rt_raster_from_wkb(data, data_len);
>         PG_FREE_IF_COPY(bytea_data, 0);
> postgis-tickets mailing list
> postgis-tickets at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-tickets
carto.com
