[postgis-tickets] r17273 - Comment out old pointonsurface test, as newer versions
Paul Ramsey
pramsey at cleverelephant.ca
Fri Feb 22 10:10:46 PST 2019
Author: pramsey
Date: 2019-02-22 10:10:46 -0800 (Fri, 22 Feb 2019)
New Revision: 17273
trunk/regress/core/tickets.sql
trunk/regress/core/tickets_expected
of GEOS will no longer throw the expected exception.
History marches on.
References #4103
Modified: trunk/regress/core/tickets.sql
--- trunk/regress/core/tickets.sql 2019-02-22 17:26:46 UTC (rev 17272)
+++ trunk/regress/core/tickets.sql 2019-02-22 18:10:46 UTC (rev 17273)
@@ -1092,7 +1092,7 @@
--#4089
select '#4089', st_astext(st_geomfromtwkb(st_AsTWKB(st_GeometryFromText('LINESTRING Z(1 1 1, 3 3 1)'), 1, 0, 0, false, true)));
-select '#4103', ST_Intersects(ST_PointOnSurface('0103000020110F0000010000000A000000000000C41E644741000000EEA2A75A41000000F420644741000000629EA75A410000007A2D644741000000E49FA75A41000000C02E644741000000409DA75A41000000286A64474100000064A4A75A410000007867644741000000FAA9A75A41000000E82B644741000000D2A2A75A41000000222D64474100000046A0A75A41000000242B6447410000006CA4A75A41000000C41E644741000000EEA2A75A41'::geometry), '0103000020110F0000010000000A000000000000C41E644741000000EEA2A75A41000000F420644741000000629EA75A410000007A2D644741000000E49FA75A41000000C02E644741000000409DA75A41000000286A64474100000064A4A75A410000007867644741000000FAA9A75A41000000E82B644741000000D2A2A75A41000000222D64474100000046A0A75A41000000242B6447410000006CA4A75A41000000C41E644741000000EEA2A75A41'::geometry);
+--select '#4103', ST_Intersects(ST_PointOnSurface('0103000020110F0000010000000A000000000000C41E644741000000EEA2A75A41000000F420644741000000629EA75A410000007A2D644741000000E49FA75A41000000C02E644741000000409DA75A41000000286A64474100000064A4A75A410000007867644741000000FAA9A75A41000000E82B644741000000D2A2A75A41000000222D64474100000046A0A75A41000000242B6447410000006CA4A75A41000000C41E644741000000EEA2A75A41'::geometry), '0103000020110F0000010000000A000000000000C41E644741000000EEA2A75A41000000F420644741000000629EA75A410000007A2D644741000000E49FA75A41000000C02E644741000000409DA75A41000000286A64474100000064A4A75A410000007867644741000000FAA9A75A41000000E82B644741000000D2A2A75A41000000222D64474100000046A0A75A41000000242B6447410000006CA4A75A41000000C41E644741000000EEA2A75A41'::geometry);
-- #4081
select '#4081',
Modified: trunk/regress/core/tickets_expected
--- trunk/regress/core/tickets_expected 2019-02-22 17:26:46 UTC (rev 17272)
+++ trunk/regress/core/tickets_expected 2019-02-22 18:10:46 UTC (rev 17273)
@@ -336,7 +336,6 @@
#4055a|4326
#4055b|4326
#4089|LINESTRING Z (1 1 1,3 3 1)
-ERROR: lwgeom_pointonsurface: GEOS Error: TopologyException: Input geom 1 is invalid: Self-intersection
#4081|f|t
NOTICE: table "bug_4144_table" does not exist, skipping
#4299|t
