[postgis-tickets] [PostGIS] #4331: ST_3DMakeBox crashes on POINT EMPTY
trac at osgeo.org
Sun Feb 24 20:32:00 PST 2019
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.0.0
Component: postgis | Version: 2.4.x
Keywords: |
Tested on
POSTGIS="3.0.0dev r17279" [EXTENSION] PGSQL="120" GEOS="3.8.0dev-
CAPI-1.11.0 a47cf0f5" SFCGAL="1.3.2" PROJ="Rel. 5.2.0, September 15th,
2018" GDAL="GDAL 2.3.1, released 2018/06/22" LIBXML="2.7.8"
LIBPROTOBUF="1.2.1" RASTER PostgreSQL 12develslicing on
x86_64-w64-mingw32, compiled by gcc.exe (x86_64-posix-seh-rev0, Built by
MinGW-W64 project) 8.1.0, 64-bit
and
POSTGIS="3.0.0dev r17265" [EXTENSION] PGSQL="110" GEOS="3.8.0dev-
CAPI-1.11.0 a47cf0f5" PROJ="Rel. 5.2.0, September 15th, 2018"
LIBXML="2.7.8" LIBPROTOBUF="1.2.1" PostgreSQL 11.0 on x86_64-w64-mingw32,
compiled by gcc.exe (x86_64-posix-seh-rev0, Built by MinGW-W64 project)
8.1.0, 64-bit
SELECT ST_3DMakeBox(ST_GeomFromText('POINT EMPTY',4326),
ST_GeomFromText('POINT EMPTY',4326))
I couldn't get a back trace for some reason. Just gives:
[Thread 9816.0x99c exited with code 0]
[Thread 9816.0x3090 exited with code 3]
[Thread 9816.0xd1c exited with code 3]
[Inferior 1 (process 9816) exited with code 03]
PostGIS 2.5.1 is fine and gives:
BOX3D(0 2.61511713111389e-317 5.59388634019276e-317,5.59390215029343e-317
3.47323850655278e-317 5.59386657756693e-317)
I think i had run garden tests earlier in 3.0 cycle so this might be a
relatively new issue in 3.0. Last time I tried running the tests I think
a month or so it would hange becasue of thge GEOS 3.8 issue I was having
under mingw64.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4331>
