[postgis-tickets] [PostGIS] #4331: ST_3DMakeBox crashes on POINT EMPTY
trac at osgeo.org
Mon Feb 25 03:25:51 PST 2019
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.0.0
Component: postgis | Version: 2.4.x
Resolution: | Keywords:
Comment (by Algunenano):
This works fine in `12593.f4cdc57bc` and crashes in `12604.b608efe32`:
#0 0x00007f36f88fcd7f in raise () from /usr/lib/libc.so.6
#1 0x00007f36f88e7672 in abort () from /usr/lib/libc.so.6
#2 0x00007f36f88e7548 in __assert_fail_base.cold.0 () from
/usr/lib/libc.so.6
#3 0x00007f36f88f5396 in __assert_fail () from /usr/lib/libc.so.6
#4 0x00007f34e8095e8e in getPoint3dz_p (pa=<optimized out>, n=0,
op=<optimized out>) at /usr/src/debug/postgis/liblwgeom/lwgeom_api.c:222
#5 BOX3D_construct (fcinfo=<optimized out>) at lwgeom_box3d.c:570
#6 0x000055e6cf6523e0 in ExecInterpExpr (state=<optimized out>,
econtext=<optimized out>, isnull=0x7ffe49cff5df) at execExprInterp.c:678
#7 0x000055e6cf71e5ae in ExecEvalExprSwitchContext (state=<optimized
out>, econtext=0x7ffe49cff1c0, isNull=0x50e7494944bc0000)
at ../../../../src/include/executor/executor.h:303
#8 evaluate_expr (expr=<optimized out>, result_type=85661,
result_typmod=-1, result_collation=0) at clauses.c:4970
#9 0x000055e6cf71dddf in evaluate_function (funcid=85900,
result_type=<optimized out>, result_typmod=-1, result_collid=0,
input_collid=0, args=0x55e6d13d9408, context=<optimized out>,
funcvariadic=<optimized out>, func_tuple=<optimized out>)
I can bisect it to a specific commit if necessary
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4331#comment:2>
