[postgis-tickets] [PostGIS] #4334: Can't upgrade with a view based on ST_AsMVTGeom
trac at osgeo.org
Wed Feb 27 05:02:01 PST 2019
Reporter: Algunenano | Owner: strk
Type: defect | Status: new
Priority: high | Milestone: PostGIS 2.4.7
Component: build/upgrade/install | Version: 2.4.x
Keywords: |
cartodb_dev_user_3e4a6fc6-4137-4c59-bc63-066f80efb90e_db=# alter extension
postgis update TO "3.0.0devnext";
ERROR: cannot drop function
st_asmvtgeom(geometry,box2d,integer,integer,boolean) because other objects
depend on it
DETAIL: view mvt depends on function
view "Building" depends on function
view aaaaaaaaaaa depends on function
view aaaaa depends on function
HINT: Use DROP ... CASCADE to drop the dependent objects too.
postgis_upgrade.sql does this:
DROP FUNCTION IF EXISTS ST_AsMVTGeom(geom geometry, bounds box2d, extent
int4, buffer int4, clip_geom bool);
CREATE OR REPLACE FUNCTION ST_AsMVTGeom(geom geometry, bounds box2d,
extent int4 default 4096, buffer int4 default 256, clip_geom bool default
true)
RETURNS geometry
AS '$libdir/postgis-3','ST_AsMVTGeom'
LANGUAGE 'c' IMMUTABLE PARALLEL SAFE;
Since the 2 signatures are the same, it's trying to drop the current
ST_AsMVTGeom before doing the CREATE OR REPLACE, so the upgrade fails.
I'm planning on checking the rest of the functions in
postgis_drop_before.sql to confirm they aren't covering already existing
functions like it's happening in ST_AsMVTGeom.
I guess 2.4+ is affected by this.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4334>
