[postgis-tickets] [PostGIS] #4336: ST_LineToCurve generates wrong Arcs for Epsilon 1E-1 (+ potential fix)
trac at osgeo.org
Thu Feb 28 08:05:05 PST 2019
Reporter: tvijlbrief | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.5.2
Component: postgis | Version: 2.4.x
Keywords: |
See also https://github.com/tomtor/postgis/blob/master/patch
The two attached images show the issues.
The first image shows that the large light blue arc which clearly exceeds
the 0.1m tolerance. This is caused by line 23 in the diff file: comparing
an angle difference in radians to the EPSILON value 0.1 (m).
I opted for excepting angles which differ by at most 25% but it would
probably be more consistent to compare the distances between a2/a3 and
a3/candidate so that they are within (2*) Epsilon.
The second image shows another issue. The current code requires that
points which EXTENT the candidate arc have similar angles.
However, we do not have such a constraint for a1/a2/a3 which form the
ORIGINAL candidate arc. This is inconsistent.
I added a test which require that difference in distance between a1/a2 and
a2/a3 is at most 2 * Epsilon.
These errors will be much rarer when using the default 1E-8 epsilon, but
the issues are the same.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4336>
