[postgis-tickets] [PostGIS] #4284: Winnie hanging indefinitely on CUnit GEOS tests
trac at osgeo.org
Wed Jan 2 12:09:56 PST 2019
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS GEOS
Component: postgis | Version: trunk
Resolution: | Keywords:
Description changed by robe:
Old description:
> -------------- Dependencies --------------
> GEOS config: /projects/geos/rel-3.8.0devw64gcc48/bin/geos-
> config
> GEOS version: 3.8.0dev
> GDAL config: /projects/gdal/rel-2.2.4w64gcc48/bin/gdal-config
> GDAL version: 2.2.4
> SFCGAL config: /projects/CGAL/rel-sfcgal-1.3.2w64gcc48/bin
> /sfcgal-config
> SFCGAL version: 1.3.2
> PostgreSQL config:
> /projects/postgresql/rel/pg11w64gcc48/bin/pg_config
> PostgreSQL version: PostgreSQL 11.0
> PROJ4 version: 49
> Libxml2 config: /projects/libxml/rel-
> libxml2-2.7.8w64gcc48/bin/xml2-config
> Libxml2 version: 2.7.8
> JSON-C support: yes
> protobuf-c support: yes
> PCRE support: yes
> Perl: /bin/perl
> Suite: algorithm
> Test: test_lw_segment_side ...passed
> Test: test_lw_segment_intersects ...passed
> Test: test_lwline_crossing_short_lines ...passed
> Test: test_lwline_crossing_long_lines ...passed
> Test: test_lwline_crossing_bugs ...passed
> Test: test_lwpoint_set_ordinate ...passed
> Test: test_lwpoint_get_ordinate ...passed
> Test: test_point_interpolate ...passed
> Test: test_lwline_interpolate_points ...passed
> Test: test_lwline_interpolate_point_3d ...passed
> Test: test_lwline_clip ...passed
> Test: test_lwpoly_clip ...passed
> Test: test_lwtriangle_clip ...passed
> Test: test_lwline_clip_big ...passed
> Test: test_lwmline_clip ...passed
> Test: test_geohash_point ...passed
> Test: test_geohash_precision ...passed
> Test: test_geohash ...passed
> Test: test_geohash_point_as_int ...passed
> Test: test_isclosed ...passed
> Test: test_lwgeom_simplify ...passed
> Test: test_lw_arc_center ...passed
> :hangs here forever
> I think this might be because I flipped her to GEOS 3.8 testing.
> pramsey I think is aware of this. I'll flip back to 3.7 and test locally
> on mine to see if gcc 8.1 has the same issue.
New description:
config
GDAL version: 2.2.4
/sfcgal-config
PostgreSQL config:
PROJ4 version: 49
JSON-C support: yes
PCRE support: yes
Perl: /bin/perl
Suite: algorithm
Test: test_point_density ...Build was aborted
Aborted by Regina Obe
:hangs here forever
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4284#comment:4>
