[postgis-tickets] [PostGIS] #4287: Assertion failure in gserialized_gist_picksplit while creating gist index on geometry(LineString, 4326) column
trac at osgeo.org
Wed Jan 9 01:28:53 PST 2019
on geometry(LineString,4326) column
Reporter: bgandhi1 | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.5.2
Component: postgis | Version: 2.4.x
Resolution: | Keywords:
Comment (by Algunenano):
> POSTGIS="2.4.3 r16312"
The latest 2.4.X release available is 2.4.6; it has a couple of fixes
around the `gserialized` code but I'm not sure if they matter here.
> We are able to consistently reproduce this with this table/column. Can
we get help regarding if this is a known issue, or has been fixed in
latest versions of PostGIS?
Can you share the table/column values or a subset that can be used to
reproduce this?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4287#comment:1>
