[postgis-tickets] [PostGIS] #4289: A multipolygon is inverted in ST_AsMVTGeom in some cases
trac at osgeo.org
Wed Jan 9 07:20:34 PST 2019
Reporter: ajolma | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone:
Component: postgis | Version: trunk
Keywords: vector tile |
A complex multipolygon is inverted (areas in the tile not in the
multipolygon become multipolygon and vice versa) when preparing a tile.
The problematic multipolygon is attached.
I'm using the command
SELECT ST_AsMVTGeom(ST_Transform(problem.geom, 3857), TileBBox(12, 2358,
1093, 3857), 256, 10, TRUE) geom
INTO test
FROM problem
WHERE ST_Intersects(TileBBox(12, 2358, 1093, 3857), problem.geom)
TileBBox is a function
create or replace function TileBBox (z int, x int, y int, srid int = 3857)
returns geometry
language plpgsql immutable as
$func$
declare
max numeric := 20037508.34;
res numeric := (max*2)/(2^z);
bbox geometry;
begin
bbox := ST_MakeEnvelope(
-max + (x * res),
max - (y * res),
-max + (x * res) + res,
max - (y * res) - res,
3857
if srid = 3857 then
return bbox;
else
return ST_Transform(bbox, srid);
end if;
end;
$func$;
PostGIS is https://postgis.net/stuff/postgis-3.0.0dev.tar.gz downloaded
today.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4289>
