[postgis-tickets] [PostGIS] #4288: Changes to liblwgeom/lwinline.h don't trigger a rebuild
trac at osgeo.org
Wed Jan 9 08:05:18 PST 2019
Reporter: Algunenano | Owner: Algunenano
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 3.0.0
Component: build/upgrade/install | Version: trunk
Resolution: | Keywords:
Comment (by Algunenano):
> There is completely alternative way of solving this: compile all the
liblwgeom as single compiler call, without building a bunch of .o files
and then linking them. May require a rework of build system but is
potentially a bigger gain.
That would mean that changing a single character in a `.c` would force
rebuilding everything and that things like ccache become useless. I'm not
a fan unless you show some super big win elsewhere, and even if you did,
I'd ask for an option to only enable it during release.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4288#comment:2>
