[postgis-tickets] r17129 - Move fix further into parser, fix bad test case
Paul Ramsey pramsey at cleverelephant.ca
Wed Jan 9 12:09:19 PST 2019
Author: pramsey
Date: 2019-01-09 12:09:19 -0800 (Wed, 09 Jan 2019)
New Revision: 17129
   branches/2.5/NEWS
   branches/2.5/liblwgeom/cunit/cu_in_wkt.c
   branches/2.5/liblwgeom/cunit/cu_out_x3d.c
   branches/2.5/liblwgeom/lwin_wkt_parse.c
References #4273
Modified: branches/2.5/NEWS
--- branches/2.5/NEWS	2019-01-09 19:43:03 UTC (rev 17128)
+++ branches/2.5/NEWS	2019-01-09 20:09:19 UTC (rev 17129)
@@ -25,7 +25,9 @@
   - #4276, ST_AsGeoJSON documentation refresh (Darafei Praliaskouski)
+  - #4273, Tighter parsing of WKT (Paul Ramsey)
 PostGIS 2.5.1
 2018/11/18
Modified: branches/2.5/liblwgeom/cunit/cu_in_wkt.c
--- branches/2.5/liblwgeom/cunit/cu_in_wkt.c	2019-01-09 19:43:03 UTC (rev 17128)
+++ branches/2.5/liblwgeom/cunit/cu_in_wkt.c	2019-01-09 20:09:19 UTC (rev 17129)
@@ -67,6 +67,11 @@
 static void test_wkt_in_point(void)
+	s = "POINT(1 2) foobar";
+	r = cu_wkt_in(s, WKT_SFSQL);
+	CU_ASSERT_STRING_EQUAL("parse error - invalid geometry", r);
+	lwfree(r);
 	s = "POINT(1e700 0)";
 	CU_TEST ( ! strcmp(r, "POINT(inf 0)") || ! strcmp(r, "POINT(1.#INF 0)") || ! strcmp(r, "POINT(Infinity 0)") );
Modified: branches/2.5/liblwgeom/cunit/cu_out_x3d.c
--- branches/2.5/liblwgeom/cunit/cu_out_x3d.c	2019-01-09 19:43:03 UTC (rev 17128)
+++ branches/2.5/liblwgeom/cunit/cu_out_x3d.c	2019-01-09 20:09:19 UTC (rev 17129)
@@ -77,7 +77,7 @@
 	/* huge data */
 	do_x3d3_test(
-	    "POINT(1E300 -105E-153 4E300)'", "1e+300 0 4e+300", NULL, 0, 0);
+	    "POINT(1E300 -105E-153 4E300)", "1e+300 0 4e+300", NULL, 0, 0);
Modified: branches/2.5/liblwgeom/lwin_wkt_parse.c
--- branches/2.5/liblwgeom/lwin_wkt_parse.c	2019-01-09 19:43:03 UTC (rev 17128)
+++ branches/2.5/liblwgeom/lwin_wkt_parse.c	2019-01-09 20:09:19 UTC (rev 17129)
@@ -95,16 +95,16 @@
 /* Turn on/off verbose parsing (turn off for production) */
 int wkt_yydebug = 0;
-* Error handler called by the bison parser. Mostly we will be
+* Error handler called by the bison parser. Mostly we will be
 * catching our own errors and filling out the message and errlocation
-* from WKT_ERROR in the grammar, but we keep this one
+* from WKT_ERROR in the grammar, but we keep this one
 * around just in case.
 void wkt_yyerror(__attribute__((__unused__)) const char *str)
 	/* If we haven't already set a message and location, let's set one now. */
-	if ( ! global_parser_result.message )
+	if ( ! global_parser_result.message )
 		global_parser_result.message = parser_error_messages[PARSER_ERROR_OTHER];
 		global_parser_result.errcode = PARSER_ERROR_OTHER;
@@ -137,14 +137,14 @@
 	/* Set the input text string, and parse checks. */
 	global_parser_result.wkinput = wktstr;
 	global_parser_result.parser_check_flags = parser_check_flags;
 	wkt_lexer_init(wktstr); /* Lexer ready */
 	parse_rv = wkt_yyparse(); /* Run the parse */
 	LWDEBUGF(4,"wkt_yyparse returned %d", parse_rv);
 	wkt_lexer_close(); /* Clean up lexer */
 	/* A non-zero parser return is an error. */
-	if ( parse_rv != 0 )
+	if ( parse_rv || global_parser_result.errcode )
 		if( ! global_parser_result.errcode )
@@ -153,17 +153,17 @@
 			global_parser_result.errlocation = wkt_yylloc.last_column;
-		LWDEBUGF(5, "error returned by wkt_yyparse() @ %d: [%d] '%s'",
-		            global_parser_result.errlocation,
-		            global_parser_result.errcode,
+		LWDEBUGF(5, "error returned by wkt_yyparse() @ %d: [%d] '%s'",
+		            global_parser_result.errlocation,
+		            global_parser_result.errcode,
 		            global_parser_result.message);
 		/* Copy the global values into the return pointer */
 		*parser_result = global_parser_result;
                 wkt_yylex_destroy();
 		return LW_FAILURE;
 	/* Copy the global value into the return pointer */
