[postgis-tickets] [PostGIS] #4290: bug in Postgis geodetic code impacting distance calculation with geography multipolygon
trac at osgeo.org
Thu Jan 10 06:18:17 PST 2019
multipolygon
Reporter: dmkaplan2000 | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.5.2
Component: postgis | Version: 2.4.x
Resolution: | Keywords:
Comment (by dmkaplan2000):
More readable code for error:
CREATE TEMP TABLE tt (gid int PRIMARY KEY, geom geometry);
\copy tt FROM 'bad_geography_dist_calcs.csv' WITH (FORMAT 'csv',HEADER
TRUE)
-- Incorrect dist_geography and dist_geography_tree for t1.gid=1 and
t2.gid=3
SELECT t1.gid AS gid1, t2.gid AS gid2,
ST_Distance(t1.geom,t2.geom) AS dist_lonlat,
ST_Distance(ST_Transform(t1.geom,26918),
ST_Transform(t2.geom,26918)) AS dist_utm,
ST_Distance(t1.geom::geography,t2.geom::geography) AS
dist_geography,
_ST_DistanceTree(t1.geom::geography,t2.geom::geography) AS
dist_geography_tree,
_ST_DistanceUncached(t1.geom::geography,t2.geom::geography) AS
dist_geography_uncached,
ST_Distance((ST_Dump(t1.geom)).geom::geography,(ST_Dump(t2.geom)).geom::geography)
AS dist_geography_dump
FROM tt t1 JOIN tt t2 ON t1.gid<t2.gid
WHERE t1.gid=1
-- No error for postgis 2.4.3, but error for 2.5.0
dist_geography,
WHERE t1.gid=1 AND t2.gid=3
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4290#comment:1>
