[postgis-tickets] [PostGIS] #4292: Attribute properties are rounded to whole numbers in ST_AsMVT
trac at osgeo.org
Fri Jan 11 02:05:28 PST 2019
Reporter: joedjc | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.5.2
Component: postgis | Version: 2.4.x
Keywords: |
If I add a decimal number as a feature-attribute value it seems to be
rounded to a whole number in the tile output.
For example:
SELECT ST_AsMVT(q, 'test', 4096, 'geom') FROM
SELECT 1 AS c1,
ST_AsMVTGeom(ST_GeomFromText('POLYGON ((35 10, 45 45, 15 40, 10
20, 35 10), (20 30, 35 35, 30 20, 20 30))'),
ST_MakeBox2D(ST_Point(0, 0), ST_Point(4096, 4096)), 4096, 0,
false) AS geom,
'{"test": 0.75}'::jsonb as properties
) AS q;
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4292>
