[postgis-tickets] [PostGIS] #4293: Polygon fill-extrusion issue in mapbox with ST_AsMVT created tiles
PostGIS trac at osgeo.org
Fri Jan 11 02:19:47 PST 2019
 Reporter:  joedjc   |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS 2.5.2
Component:  postgis  |    Version:  2.4.x
 Keywords:           |
 I am having some issues displaying ST_AsMVT created tiles in Mapbox.
 This applies specifically to fill-extrusions (e.g. 3D buildings) in
 Mapbox. When rendering these tiles to foreground extrusions are missing.
 I believe this to be a PostGIS issue because generating tiles from the
 same data in Mapnik renders correctly.
 I've attached an image of a Polygon with fill-extrusion created from a
 PostGIS tile and a Mapnik tile from the same data source.
 Could it be the case that the Polygon is created in a format which does
 not render correctly in Mapbox?
 [[Image(https://s3-eu-
 west-1.amazonaws.com/www.iventis.co.uk/assets/postgis_vs_mapnik.png)]]
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4293>
