[postgis-tickets] [PostGIS] #4293: Polygon fill-extrusion issue in mapbox with ST_AsMVT created tiles
PostGIS trac at osgeo.org
Fri Jan 11 06:04:15 PST 2019
  Reporter:  joedjc   |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 2.5.2
 Component:  postgis  |    Version:  2.4.x
Resolution:           |   Keywords:
Comment (by Algunenano):
 > Here is the dataset for the Polygon used in the example:
 Can you share the whole query (with a polygon example) so we can check if
 the output is valid?
 What library are you using for the visualization? It's just a wild
 speculation, but if it isn't a Postgis issue it could be that it adds
 extra requirements on top of the MVT spec.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4293#comment:4>
