[postgis-tickets] r17142 - Drone 1.0 config (the 1.0 has major breaking changes from 0.5/0.8 so can't use existing .drone.yml
Regina Obe
lr at pcorp.us
Sun Jan 13 12:46:50 PST 2019
Author: robe
Date: 2019-01-13 12:46:50 -0800 (Sun, 13 Jan 2019)
New Revision: 17142
Added:
trunk/.drone-1.0.yml
Currently two drone 1.0 agens - debbie and dronie.sogeo.org
dronie.osgeo.org (residing on osgeo7 server) is also the 1.0 drone server -- https://dronie.osgeo.org
Added: trunk/.drone-1.0.yml
--- trunk/.drone-1.0.yml (rev 0)
+++ trunk/.drone-1.0.yml 2019-01-13 20:46:50 UTC (rev 17142)
@@ -0,0 +1,76 @@
+# This is for the drone 1.0 agent
+# https://docs.drone.io/user-guide/pipeline/steps/
+# https://dronie.osgeo.org #1.0 server
+# See https://git.osgeo.org/gitea/postgis/postgis-docker
+test-image: &test-image docker.kbt.io/postgis/build-test:trisquel2
+clone:
+ image: plugins/git
+ depth: 20
+ recursive: false
+kind: pipeline
+name: pg-9.5
+steps:
+- name: build
+ image: *test-image
+ pull: true
+ commands:
+ - export PGVER=9.5
+ - service postgresql start $PGVER
+ - export PGPORT=`grep ^port /etc/postgresql/$PGVER/main/postgresql.conf | awk '{print $3}'`
+ - export PATH=/usr/lib/postgresql/$PGVER/bin:$PATH
+ - psql --version
+ - ./autogen.sh
+ - ./configure CFLAGS="-O0 -Wall -fno-omit-frame-pointer -Werror" --without-interrupt-tests
+ - make -j
+ # we should maybe wait for postgresql service to startup here...
+ - psql -c "select version()" template1
+ - make check RUNTESTFLAGS=-v
+ - make install
+ - utils/check_all_upgrades.sh
+ `grep '^POSTGIS_' Version.config | cut -d= -f2 | paste -sd '.'`
+kind: pipeline
+name: pg-9.6
+steps:
+- name: build
+ pull: true
+ commands:
+ - export PGVER=9.6
+ - psql --version
+ - ./autogen.sh
+ - make -j
+ - make install
+kind: pipeline
+name: pg-10
+steps:
+- name: build
+ pull: true
+ commands:
+ - export PGVER=10
+ - psql --version
+ - ./autogen.sh
+ - make -j
+ - make install
