[postgis-tickets] [PostGIS] #4296: Use `server_version_num` instead of parsing version()
trac at osgeo.org
Mon Jan 14 05:44:31 PST 2019
Reporter: Algunenano | Owner: Algunenano
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 2.3.9
Component: postgis | Version: 2.3.x
Keywords: |
Some PostgreSQL forks (e.g. `EnterpriseDB`) modify the version() output so
matching `PostgreSQL ([0-9\.]+)` doesn't work. This affects
`postgis_extension_remove_objects` and `_postgis_pgsql_version` functions.
Using `SELECT current_setting('server_version_num')` should be equivalent
and clearer.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4296>
