[postgis-tickets] [PostGIS] #4269: Inconsistent result for ST_Intersects depending on the plan
trac at osgeo.org
Thu Jan 17 14:17:55 PST 2019
Reporter: Algunenano | Owner: pramsey
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 2.4.7
Component: postgis | Version: 2.5.x
Resolution: | Keywords:
Comment (by pramsey):
Just skipping the whole join thing, which I feel is a red herring, you can
see fun stuff happening in this example:
WITH data AS (
SELECT 1 as cid, 'POLYGON Z ((122427.759 489209.498
14.5066901703871,122395.957 489222.943 14.3997094723791,122399.649
489231.676 4.98556790825181,122431.452 489218.231
5.09216481886026,122427.759 489209.498 14.5066901703871))'::geometry geom
UNION ALL
SELECT 2, 'POLYGON Z ((122427.027 489216.053 5.97863674861823,122419.873
489219.077 6.03923989893278,122421.6 489223.163
1.83027232084998,122428.754 489220.138 1.77054008712955,122427.027
489216.053 5.97863674861823))'::geometry
UNION ALL
SELECT 3, 'POLYGON Z ((122422.267 489220.741 0,122424.396 489219.847
0,122424.396 489219.847 30,122422.267 489220.741 30,122422.267 489220.741
0))'::geometry
ORDER BY cid
SELECT a.cid, b.cid, ST_Relate(a.geom, b.geom) AS relate,
_ST_Intersects(a.geom, b.geom)
FROM data a, data b
ORDER BY a.cid, b.cid;
cid | cid | relate | _st_intersects
1 | 1 | 2FFF1FFF2 | t
1 | 2 | 212101212 | t
1 | 3 | FF2FF1FF2 | t
2 | 1 | 212101212 | t
2 | 2 | 2FFF1FFF2 | t
2 | 3 | FF2FF1FF2 | t
3 | 1 | FFFFFF212 | f
3 | 2 | FFFFFF212 | t
3 | 3 | FFFFFFFF2 | t
(9 rows)
Note how the relate matrix of polygon 3 vs itself is not the standard
pattern of the other two. The invalid third polygon is problematic. I
don't see how this isn't just a known issue... invalid inputs lead to odd
results, like non-commutative tests on intersects.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4269#comment:8>
