[postgis-tickets] r17174 - Avoid passing a NULL pointer to GEOSisEmpty
Raul raul at rmr.ninja
Fri Jan 18 08:05:18 PST 2019
Author: algunenano
Date: 2019-01-18 08:05:18 -0800 (Fri, 18 Jan 2019)
New Revision: 17174
   trunk/NEWS
   trunk/liblwgeom/lwgeom_geos_clean.c
   trunk/liblwgeom/lwgeom_geos_cluster.c
References #4275
Modified: trunk/NEWS
--- trunk/NEWS	2019-01-18 11:58:46 UTC (rev 17173)
+++ trunk/NEWS	2019-01-18 16:05:18 UTC (rev 17174)
@@ -66,6 +66,7 @@
   - #4301, ST_Subdivide: fix endless loop on coordinates near coincident to bounds
            (Darafei Praliaskouski)
   - #4289, ST_AsMVTGeom: Transform coordinates space before clipping (Raúl Marín)
+  - #4275, Avoid passing a NULL pointer to GEOSisEmpty (Raúl Marín)
 PostGIS 2.5.0
Modified: trunk/liblwgeom/lwgeom_geos_clean.c
--- trunk/liblwgeom/lwgeom_geos_clean.c	2019-01-18 11:58:46 UTC (rev 17173)
+++ trunk/liblwgeom/lwgeom_geos_clean.c	2019-01-18 16:05:18 UTC (rev 17174)
@@ -573,11 +573,15 @@
 		const GEOSGeometry* g = GEOSGetGeometryN(gin, i);
 		GEOSGeometry* vg;
 		vg = LWGEOM_GEOS_makeValidLine(g);
+		/* Drop any invalid or empty geometry */
+		if (!vg)
+			continue;
 		if (GEOSisEmpty(vg))
-			/* we don't care about this one */
 			GEOSGeom_destroy(vg);
+			continue;
 		if (GEOSGeomTypeId(vg) == GEOS_POINT)
 			points[npoints++] = vg;
 		else if (GEOSGeomTypeId(vg) == GEOS_LINESTRING)
@@ -827,7 +831,7 @@
 		pd = GEOSDifference(pi, po); /* input points - output points */
 		GEOSGeom_destroy(pi);
 		GEOSGeom_destroy(po);
-		loss = !GEOSisEmpty(pd);
+		loss = pd && !GEOSisEmpty(pd);
 		GEOSGeom_destroy(pd);
 		if (loss)
Modified: trunk/liblwgeom/lwgeom_geos_cluster.c
--- trunk/liblwgeom/lwgeom_geos_cluster.c	2019-01-18 11:58:46 UTC (rev 17173)
+++ trunk/liblwgeom/lwgeom_geos_cluster.c	2019-01-18 16:05:18 UTC (rev 17174)
@@ -178,7 +178,7 @@
 		const GEOSPreparedGeometry* prep = NULL;
-		if (GEOSisEmpty(geoms[p]))
+		if (!geoms[p] || GEOSisEmpty(geoms[p]))
 			continue;
 		cxt.num_items_found = 0;
