[postgis-tickets] r17198 - Sync generated files to parser file
Paul Ramsey
pramsey at cleverelephant.ca
Mon Jan 21 11:50:56 PST 2019
Author: pramsey
Date: 2019-01-21 11:50:56 -0800 (Mon, 21 Jan 2019)
New Revision: 17198
branches/2.4/liblwgeom/lwin_wkt_parse.c
branches/2.4/liblwgeom/lwin_wkt_parse.h
Modified: branches/2.4/liblwgeom/lwin_wkt_parse.c
--- branches/2.4/liblwgeom/lwin_wkt_parse.c 2019-01-21 19:47:14 UTC (rev 17197)
+++ branches/2.4/liblwgeom/lwin_wkt_parse.c 2019-01-21 19:50:56 UTC (rev 17198)
@@ -1,31 +1,8 @@
- * PostGIS - Spatial Types for PostgreSQL
- * http://postgis.net
- * PostGIS is free software: you can redistribute it and/or modify
- * it under the terms of the GNU General Public License as published by
- * the Free Software Foundation, either version 2 of the License, or
- * (at your option) any later version.
- * PostGIS is distributed in the hope that it will be useful,
- * but WITHOUT ANY WARRANTY; without even the implied warranty of
- * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
- * GNU General Public License for more details.
- * You should have received a copy of the GNU General Public License
- * along with PostGIS. If not, see <http://www.gnu.org/licenses/>.
- Copyright (C) 1984, 1989-1990, 2000-2015 Free Software Foundation, Inc.
+/* A Bison parser, made by GNU Bison 3.2.2. */
/* Bison implementation for Yacc-like parsers in C
+ Copyright (C) 1984, 1989-1990, 2000-2015, 2018 Free Software Foundation, Inc.
This program is free software: you can redistribute it and/or modify
@@ -63,11 +40,14 @@
define necessary library symbols; they are noted "INFRINGES ON
USER NAME SPACE" below. */
+/* Undocumented macros, especially those whose name start with YY_,
+ are private implementation details. Do not rely on them. */
/* Identify Bison output. */
#define YYBISON 1
/* Bison version. */
-#define YYBISON_VERSION "3.0.4"
+#define YYBISON_VERSION "3.2.2"
/* Skeleton name. */
#define YYSKELETON_NAME "yacc.c"
@@ -93,8 +73,8 @@
#define yychar wkt_yychar
#define yylloc wkt_yylloc
-/* Copy the first part of user declarations. */
-#line 1 "lwin_wkt_parse.y" /* yacc.c:339 */
+/* First part of user prologue. */
+#line 1 "lwin_wkt_parse.y" /* yacc.c:338 */
/* WKT Parser */
@@ -205,13 +185,16 @@
-#line 178 "lwin_wkt_parse.c" /* yacc.c:339 */
+#line 189 "lwin_wkt_parse.c" /* yacc.c:338 */
# ifndef YY_NULLPTR
-# if defined __cplusplus && 201103L <= __cplusplus
-# define YY_NULLPTR nullptr
+# if defined __cplusplus
+# if 201103L <= __cplusplus
+# define YY_NULLPTR nullptr
+# else
+# define YY_NULLPTR 0
+# endif
# else
-# define YY_NULLPTR 0
+# define YY_NULLPTR ((void*)0)
# endif
# endif
@@ -295,7 +278,7 @@
union YYSTYPE
-#line 108 "lwin_wkt_parse.y" /* yacc.c:355 */
+#line 116 "lwin_wkt_parse.y" /* yacc.c:353 */
int integervalue;
double doublevalue;
@@ -304,7 +287,7 @@
POINT coordinatevalue;
POINTARRAY *ptarrayvalue;
-#line 277 "lwin_wkt_parse.c" /* yacc.c:355 */
+#line 291 "lwin_wkt_parse.c" /* yacc.c:353 */
typedef union YYSTYPE YYSTYPE;
@@ -333,9 +316,7 @@
#endif /* !YY_WKT_YY_LWIN_WKT_PARSE_H_INCLUDED */
-/* Copy the second part of user declarations. */
-#line 308 "lwin_wkt_parse.c" /* yacc.c:358 */
#ifdef short
# undef short
@@ -356,13 +337,13 @@
#ifdef YYTYPE_UINT16
typedef YYTYPE_UINT16 yytype_uint16;
#else
-typedef unsigned short int yytype_uint16;
+typedef unsigned short yytype_uint16;
#endif
#ifdef YYTYPE_INT16
typedef YYTYPE_INT16 yytype_int16;
#else
-typedef short int yytype_int16;
+typedef short yytype_int16;
#endif
#ifndef YYSIZE_T
@@ -374,7 +355,7 @@
# include <stddef.h> /* INFRINGES ON USER NAME SPACE */
# define YYSIZE_T size_t
# else
-# define YYSIZE_T unsigned int
+# define YYSIZE_T unsigned
# endif
#endif
@@ -410,15 +391,6 @@
# define YY_ATTRIBUTE_UNUSED YY_ATTRIBUTE ((__unused__))
#endif
-#if !defined _Noreturn \
- && (!defined __STDC_VERSION__ || __STDC_VERSION__ < 201112)
-# if defined _MSC_VER && 1200 <= _MSC_VER
-# define _Noreturn __declspec (noreturn)
-# else
-# define _Noreturn YY_ATTRIBUTE ((__noreturn__))
-# endif
-#endif
/* Suppress unused-variable warnings by "using" E. */
#if ! defined lint || defined __GNUC__
# define YYUSE(E) ((void) (E))
@@ -426,7 +398,7 @@
# define YYUSE(E) /* empty */
#endif
-#if defined __GNUC__ && 407 <= __GNUC__ * 100 + __GNUC_MINOR__
+#if defined __GNUC__ && ! defined __ICC && 407 <= __GNUC__ * 100 + __GNUC_MINOR__
/* Suppress an incorrect diagnostic about yylval being uninitialized. */
# define YY_IGNORE_MAYBE_UNINITIALIZED_BEGIN \
_Pragma ("GCC diagnostic push") \
@@ -596,7 +568,7 @@
#define YYMAXUTOK 280
#define YYTRANSLATE(YYX) \
- ((unsigned int) (YYX) <= YYMAXUTOK ? yytranslate[YYX] : YYUNDEFTOK)
+ ((unsigned) (YYX) <= YYMAXUTOK ? yytranslate[YYX] : YYUNDEFTOK)
/* YYTRANSLATE[TOKEN-NUM] -- Symbol number corresponding to TOKEN-NUM
as returned by yylex, without out-of-bounds checking. */
@@ -637,20 +609,20 @@
/* YYRLINE[YYN] -- Source line where rule number YYN was defined. */
static const yytype_uint16 yyrline[] =
- 0, 212, 212, 214, 218, 219, 220, 221, 222, 223,
- 224, 225, 226, 227, 228, 229, 230, 231, 232, 235,
- 237, 239, 241, 245, 247, 251, 253, 255, 257, 261,
- 263, 265, 267, 269, 271, 275, 277, 279, 281, 285,
- 287, 289, 291, 295, 297, 299, 301, 305, 307, 311,
- 313, 317, 319, 321, 323, 327, 329, 333, 336, 338,
- 340, 342, 346, 348, 352, 353, 354, 355, 358, 360,
- 364, 366, 370, 373, 376, 378, 380, 382, 386, 388,
- 390, 392, 394, 396, 400, 402, 404, 406, 410, 412,
- 414, 416, 418, 420, 422, 424, 428, 430, 432, 434,
- 438, 440, 444, 446, 448, 450, 454, 456, 458, 460,
- 464, 466, 470, 472, 476, 478, 480, 482, 486, 490,
- 492, 494, 496, 500, 502, 506, 508, 510, 514, 516,
- 518, 520, 524, 526, 530, 532, 534
+ 0, 220, 220, 222, 226, 227, 228, 229, 230, 231,
+ 232, 233, 234, 235, 236, 237, 238, 239, 240, 243,
+ 245, 247, 249, 253, 255, 259, 261, 263, 265, 269,
+ 271, 273, 275, 277, 279, 283, 285, 287, 289, 293,
+ 295, 297, 299, 303, 305, 307, 309, 313, 315, 319,
+ 321, 325, 327, 329, 331, 335, 337, 341, 344, 346,
+ 348, 350, 354, 356, 360, 361, 362, 363, 366, 368,
+ 372, 374, 378, 381, 384, 386, 388, 390, 394, 396,
+ 398, 400, 402, 404, 408, 410, 412, 414, 418, 420,
+ 422, 424, 426, 428, 430, 432, 436, 438, 440, 442,
+ 446, 448, 452, 454, 456, 458, 462, 464, 466, 468,
+ 472, 474, 478, 480, 484, 486, 488, 490, 494, 498,
+ 500, 502, 504, 508, 510, 514, 516, 518, 522, 524,
+ 526, 528, 532, 534, 538, 540, 542
#endif
@@ -1013,10 +985,10 @@
/* Print *YYLOCP on YYO. Private, do not rely on its existence. */
YY_ATTRIBUTE_UNUSED
-static unsigned
+static int
yy_location_print_ (FILE *yyo, YYLTYPE const * const yylocp)
- unsigned res = 0;
+ int res = 0;
int end_col = 0 != yylocp->last_column ? yylocp->last_column - 1 : 0;
if (0 <= yylocp->first_line)
@@ -1059,40 +1031,40 @@
} while (0)
-| Print this symbol's value on YYOUTPUT. |
+| Print this symbol's value on YYO. |
static void
-yy_symbol_value_print (FILE *yyoutput, int yytype, YYSTYPE const * const yyvaluep, YYLTYPE const * const yylocationp)
+yy_symbol_value_print (FILE *yyo, int yytype, YYSTYPE const * const yyvaluep, YYLTYPE const * const yylocationp)
- FILE *yyo = yyoutput;
- YYUSE (yyo);
+ FILE *yyoutput = yyo;
+ YYUSE (yyoutput);
YYUSE (yylocationp);
if (!yyvaluep)
return;
# ifdef YYPRINT
if (yytype < YYNTOKENS)
- YYPRINT (yyoutput, yytoknum[yytype], *yyvaluep);
+ YYPRINT (yyo, yytoknum[yytype], *yyvaluep);
# endif
YYUSE (yytype);
-| Print this symbol on YYOUTPUT. |
+| Print this symbol on YYO. |
static void
-yy_symbol_print (FILE *yyoutput, int yytype, YYSTYPE const * const yyvaluep, YYLTYPE const * const yylocationp)
+yy_symbol_print (FILE *yyo, int yytype, YYSTYPE const * const yyvaluep, YYLTYPE const * const yylocationp)
- YYFPRINTF (yyoutput, "%s %s (",
+ YYFPRINTF (yyo, "%s %s (",
yytype < YYNTOKENS ? "token" : "nterm", yytname[yytype]);
- YY_LOCATION_PRINT (yyoutput, *yylocationp);
- YYFPRINTF (yyoutput, ": ");
- yy_symbol_value_print (yyoutput, yytype, yyvaluep, yylocationp);
- YYFPRINTF (yyoutput, ")");
+ YY_LOCATION_PRINT (yyo, *yylocationp);
+ YYFPRINTF (yyo, ": ");
+ yy_symbol_value_print (yyo, yytype, yyvaluep, yylocationp);
+ YYFPRINTF (yyo, ")");
@@ -1126,7 +1098,7 @@
static void
yy_reduce_print (yytype_int16 *yyssp, YYSTYPE *yyvsp, YYLTYPE *yylsp, int yyrule)
- unsigned long int yylno = yyrline[yyrule];
+ unsigned long yylno = yyrline[yyrule];
int yynrhs = yyr2[yyrule];
int yyi;
YYFPRINTF (stderr, "Reducing stack by rule %d (line %lu):\n",
@@ -1259,7 +1231,7 @@
if (! yyres)
return yystrlen (yystr);
- return yystpcpy (yyres, yystr) - yyres;
+ return (YYSIZE_T) (yystpcpy (yyres, yystr) - yyres);
# endif
@@ -1352,6 +1324,7 @@
case N: \
yyformat = S; \
break
+ default: /* Avoid compiler warnings. */
YYCASE_(0, YY_("syntax error"));
YYCASE_(1, YY_("syntax error, unexpected %s"));
YYCASE_(2, YY_("syntax error, unexpected %s, expecting %s"));
@@ -1416,219 +1389,219 @@
switch (yytype)
case 28: /* geometry_no_srid */
-#line 190 "lwin_wkt_parse.y" /* yacc.c:1257 */
+#line 198 "lwin_wkt_parse.y" /* yacc.c:1254 */
{ lwgeom_free(((*yyvaluep).geometryvalue)); }
-#line 1391 "lwin_wkt_parse.c" /* yacc.c:1257 */
+#line 1395 "lwin_wkt_parse.c" /* yacc.c:1254 */
break;
case 29: /* geometrycollection */
-#line 191 "lwin_wkt_parse.y" /* yacc.c:1257 */
+#line 199 "lwin_wkt_parse.y" /* yacc.c:1254 */
-#line 1397 "lwin_wkt_parse.c" /* yacc.c:1257 */
+#line 1401 "lwin_wkt_parse.c" /* yacc.c:1254 */
break;
case 31: /* multisurface */
-#line 198 "lwin_wkt_parse.y" /* yacc.c:1257 */
+#line 206 "lwin_wkt_parse.y" /* yacc.c:1254 */
-#line 1403 "lwin_wkt_parse.c" /* yacc.c:1257 */
+#line 1407 "lwin_wkt_parse.c" /* yacc.c:1254 */
break;
case 32: /* surface_list */
-#line 177 "lwin_wkt_parse.y" /* yacc.c:1257 */
+#line 185 "lwin_wkt_parse.y" /* yacc.c:1254 */
-#line 1409 "lwin_wkt_parse.c" /* yacc.c:1257 */
+#line 1413 "lwin_wkt_parse.c" /* yacc.c:1254 */
break;
case 33: /* tin */
-#line 205 "lwin_wkt_parse.y" /* yacc.c:1257 */
+#line 213 "lwin_wkt_parse.y" /* yacc.c:1254 */
-#line 1415 "lwin_wkt_parse.c" /* yacc.c:1257 */
+#line 1419 "lwin_wkt_parse.c" /* yacc.c:1254 */
break;
case 34: /* polyhedralsurface */
-#line 204 "lwin_wkt_parse.y" /* yacc.c:1257 */
+#line 212 "lwin_wkt_parse.y" /* yacc.c:1254 */
-#line 1421 "lwin_wkt_parse.c" /* yacc.c:1257 */
+#line 1425 "lwin_wkt_parse.c" /* yacc.c:1254 */
break;
case 35: /* multipolygon */
-#line 197 "lwin_wkt_parse.y" /* yacc.c:1257 */
+#line 205 "lwin_wkt_parse.y" /* yacc.c:1254 */
-#line 1427 "lwin_wkt_parse.c" /* yacc.c:1257 */
+#line 1431 "lwin_wkt_parse.c" /* yacc.c:1254 */
break;
case 36: /* polygon_list */
-#line 178 "lwin_wkt_parse.y" /* yacc.c:1257 */
+#line 186 "lwin_wkt_parse.y" /* yacc.c:1254 */
-#line 1433 "lwin_wkt_parse.c" /* yacc.c:1257 */
+#line 1437 "lwin_wkt_parse.c" /* yacc.c:1254 */
break;
case 37: /* patch_list */
-#line 179 "lwin_wkt_parse.y" /* yacc.c:1257 */
+#line 187 "lwin_wkt_parse.y" /* yacc.c:1254 */
-#line 1439 "lwin_wkt_parse.c" /* yacc.c:1257 */
+#line 1443 "lwin_wkt_parse.c" /* yacc.c:1254 */
break;
case 38: /* polygon */
-#line 201 "lwin_wkt_parse.y" /* yacc.c:1257 */
+#line 209 "lwin_wkt_parse.y" /* yacc.c:1254 */
-#line 1445 "lwin_wkt_parse.c" /* yacc.c:1257 */
+#line 1449 "lwin_wkt_parse.c" /* yacc.c:1254 */
break;
case 39: /* polygon_untagged */
-#line 203 "lwin_wkt_parse.y" /* yacc.c:1257 */
+#line 211 "lwin_wkt_parse.y" /* yacc.c:1254 */
-#line 1451 "lwin_wkt_parse.c" /* yacc.c:1257 */
+#line 1455 "lwin_wkt_parse.c" /* yacc.c:1254 */
break;
case 40: /* patch */
-#line 202 "lwin_wkt_parse.y" /* yacc.c:1257 */
+#line 210 "lwin_wkt_parse.y" /* yacc.c:1254 */
-#line 1457 "lwin_wkt_parse.c" /* yacc.c:1257 */
+#line 1461 "lwin_wkt_parse.c" /* yacc.c:1254 */
break;
case 41: /* curvepolygon */
-#line 188 "lwin_wkt_parse.y" /* yacc.c:1257 */
+#line 196 "lwin_wkt_parse.y" /* yacc.c:1254 */
-#line 1463 "lwin_wkt_parse.c" /* yacc.c:1257 */
+#line 1467 "lwin_wkt_parse.c" /* yacc.c:1254 */
break;
case 42: /* curvering_list */
-#line 175 "lwin_wkt_parse.y" /* yacc.c:1257 */
+#line 183 "lwin_wkt_parse.y" /* yacc.c:1254 */
-#line 1469 "lwin_wkt_parse.c" /* yacc.c:1257 */
+#line 1473 "lwin_wkt_parse.c" /* yacc.c:1254 */
break;
case 43: /* curvering */
-#line 189 "lwin_wkt_parse.y" /* yacc.c:1257 */
+#line 197 "lwin_wkt_parse.y" /* yacc.c:1254 */
-#line 1475 "lwin_wkt_parse.c" /* yacc.c:1257 */
+#line 1479 "lwin_wkt_parse.c" /* yacc.c:1254 */
break;
case 44: /* patchring_list */
-#line 185 "lwin_wkt_parse.y" /* yacc.c:1257 */
+#line 193 "lwin_wkt_parse.y" /* yacc.c:1254 */
-#line 1481 "lwin_wkt_parse.c" /* yacc.c:1257 */
+#line 1485 "lwin_wkt_parse.c" /* yacc.c:1254 */
break;
case 45: /* ring_list */
-#line 184 "lwin_wkt_parse.y" /* yacc.c:1257 */
+#line 192 "lwin_wkt_parse.y" /* yacc.c:1254 */
-#line 1487 "lwin_wkt_parse.c" /* yacc.c:1257 */
+#line 1491 "lwin_wkt_parse.c" /* yacc.c:1254 */
break;
case 46: /* patchring */
-#line 174 "lwin_wkt_parse.y" /* yacc.c:1257 */
+#line 182 "lwin_wkt_parse.y" /* yacc.c:1254 */
{ ptarray_free(((*yyvaluep).ptarrayvalue)); }
-#line 1493 "lwin_wkt_parse.c" /* yacc.c:1257 */
+#line 1497 "lwin_wkt_parse.c" /* yacc.c:1254 */
break;
case 47: /* ring */
-#line 173 "lwin_wkt_parse.y" /* yacc.c:1257 */
+#line 181 "lwin_wkt_parse.y" /* yacc.c:1254 */
-#line 1499 "lwin_wkt_parse.c" /* yacc.c:1257 */
+#line 1503 "lwin_wkt_parse.c" /* yacc.c:1254 */
break;
case 48: /* compoundcurve */
-#line 187 "lwin_wkt_parse.y" /* yacc.c:1257 */
+#line 195 "lwin_wkt_parse.y" /* yacc.c:1254 */
-#line 1505 "lwin_wkt_parse.c" /* yacc.c:1257 */
+#line 1509 "lwin_wkt_parse.c" /* yacc.c:1254 */
break;
case 49: /* compound_list */
-#line 183 "lwin_wkt_parse.y" /* yacc.c:1257 */
+#line 191 "lwin_wkt_parse.y" /* yacc.c:1254 */
-#line 1511 "lwin_wkt_parse.c" /* yacc.c:1257 */
+#line 1515 "lwin_wkt_parse.c" /* yacc.c:1254 */
break;
case 50: /* multicurve */
-#line 194 "lwin_wkt_parse.y" /* yacc.c:1257 */
+#line 202 "lwin_wkt_parse.y" /* yacc.c:1254 */
-#line 1517 "lwin_wkt_parse.c" /* yacc.c:1257 */
+#line 1521 "lwin_wkt_parse.c" /* yacc.c:1254 */
break;
case 51: /* curve_list */
-#line 182 "lwin_wkt_parse.y" /* yacc.c:1257 */
+#line 190 "lwin_wkt_parse.y" /* yacc.c:1254 */
-#line 1523 "lwin_wkt_parse.c" /* yacc.c:1257 */
+#line 1527 "lwin_wkt_parse.c" /* yacc.c:1254 */
break;
case 52: /* multilinestring */
-#line 195 "lwin_wkt_parse.y" /* yacc.c:1257 */
+#line 203 "lwin_wkt_parse.y" /* yacc.c:1254 */
-#line 1529 "lwin_wkt_parse.c" /* yacc.c:1257 */
+#line 1533 "lwin_wkt_parse.c" /* yacc.c:1254 */
break;
case 53: /* linestring_list */
-#line 181 "lwin_wkt_parse.y" /* yacc.c:1257 */
+#line 189 "lwin_wkt_parse.y" /* yacc.c:1254 */
-#line 1535 "lwin_wkt_parse.c" /* yacc.c:1257 */
+#line 1539 "lwin_wkt_parse.c" /* yacc.c:1254 */
break;
case 54: /* circularstring */
-#line 186 "lwin_wkt_parse.y" /* yacc.c:1257 */
+#line 194 "lwin_wkt_parse.y" /* yacc.c:1254 */
-#line 1541 "lwin_wkt_parse.c" /* yacc.c:1257 */
+#line 1545 "lwin_wkt_parse.c" /* yacc.c:1254 */
break;
case 55: /* linestring */
-#line 192 "lwin_wkt_parse.y" /* yacc.c:1257 */
+#line 200 "lwin_wkt_parse.y" /* yacc.c:1254 */
-#line 1547 "lwin_wkt_parse.c" /* yacc.c:1257 */
+#line 1551 "lwin_wkt_parse.c" /* yacc.c:1254 */
break;
case 56: /* linestring_untagged */
-#line 193 "lwin_wkt_parse.y" /* yacc.c:1257 */
+#line 201 "lwin_wkt_parse.y" /* yacc.c:1254 */
-#line 1553 "lwin_wkt_parse.c" /* yacc.c:1257 */
+#line 1557 "lwin_wkt_parse.c" /* yacc.c:1254 */
break;
case 57: /* triangle_list */
-#line 176 "lwin_wkt_parse.y" /* yacc.c:1257 */
+#line 184 "lwin_wkt_parse.y" /* yacc.c:1254 */
-#line 1559 "lwin_wkt_parse.c" /* yacc.c:1257 */
+#line 1563 "lwin_wkt_parse.c" /* yacc.c:1254 */
break;
case 58: /* triangle */
-#line 206 "lwin_wkt_parse.y" /* yacc.c:1257 */
+#line 214 "lwin_wkt_parse.y" /* yacc.c:1254 */
-#line 1565 "lwin_wkt_parse.c" /* yacc.c:1257 */
+#line 1569 "lwin_wkt_parse.c" /* yacc.c:1254 */
break;
case 59: /* triangle_untagged */
-#line 207 "lwin_wkt_parse.y" /* yacc.c:1257 */
+#line 215 "lwin_wkt_parse.y" /* yacc.c:1254 */
-#line 1571 "lwin_wkt_parse.c" /* yacc.c:1257 */
+#line 1575 "lwin_wkt_parse.c" /* yacc.c:1254 */
break;
case 60: /* multipoint */
-#line 196 "lwin_wkt_parse.y" /* yacc.c:1257 */
+#line 204 "lwin_wkt_parse.y" /* yacc.c:1254 */
-#line 1577 "lwin_wkt_parse.c" /* yacc.c:1257 */
+#line 1581 "lwin_wkt_parse.c" /* yacc.c:1254 */
break;
case 61: /* point_list */
-#line 180 "lwin_wkt_parse.y" /* yacc.c:1257 */
+#line 188 "lwin_wkt_parse.y" /* yacc.c:1254 */
-#line 1583 "lwin_wkt_parse.c" /* yacc.c:1257 */
+#line 1587 "lwin_wkt_parse.c" /* yacc.c:1254 */
break;
case 62: /* point_untagged */
-#line 200 "lwin_wkt_parse.y" /* yacc.c:1257 */
+#line 208 "lwin_wkt_parse.y" /* yacc.c:1254 */
-#line 1589 "lwin_wkt_parse.c" /* yacc.c:1257 */
+#line 1593 "lwin_wkt_parse.c" /* yacc.c:1254 */
break;
case 63: /* point */
-#line 199 "lwin_wkt_parse.y" /* yacc.c:1257 */
+#line 207 "lwin_wkt_parse.y" /* yacc.c:1254 */
-#line 1595 "lwin_wkt_parse.c" /* yacc.c:1257 */
+#line 1599 "lwin_wkt_parse.c" /* yacc.c:1254 */
break;
case 64: /* ptarray */
-#line 172 "lwin_wkt_parse.y" /* yacc.c:1257 */
+#line 180 "lwin_wkt_parse.y" /* yacc.c:1254 */
-#line 1601 "lwin_wkt_parse.c" /* yacc.c:1257 */
+#line 1605 "lwin_wkt_parse.c" /* yacc.c:1254 */
break;
@@ -1740,12 +1713,12 @@
yyssp++;
yysetstate:
- *yyssp = yystate;
+ *yyssp = (yytype_int16) yystate;
if (yyss + yystacksize - 1 <= yyssp)
/* Get the current used size of the three stacks, in elements. */
- YYSIZE_T yysize = yyssp - yyss + 1;
+ YYSIZE_T yysize = (YYSIZE_T) (yyssp - yyss + 1);
#ifdef yyoverflow
@@ -1765,10 +1738,9 @@
&yyvs1, yysize * sizeof (*yyvsp),
&yyls1, yysize * sizeof (*yylsp),
&yystacksize);
- yyls = yyls1;
yyss = yyss1;
yyvs = yyvs1;
+ yyls = yyls1;
#else /* no yyoverflow */
# ifndef YYSTACK_RELOCATE
@@ -1802,7 +1774,7 @@
yylsp = yyls + yysize - 1;
YYDPRINTF ((stderr, "Stack size increased to %lu\n",
- (unsigned long int) yystacksize));
+ (unsigned long) yystacksize));
YYABORT;
@@ -1908,823 +1880,824 @@
GCC warning that YYVAL may be used uninitialized. */
yyval = yyvsp[1-yylen];
- /* Default location. */
+ /* Default location. */
YYLLOC_DEFAULT (yyloc, (yylsp - yylen), yylen);
+ yyerror_range[1] = yyloc;
YY_REDUCE_PRINT (yyn);
switch (yyn)
case 2:
-#line 213 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 221 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ wkt_parser_geometry_new((yyvsp[0].geometryvalue), SRID_UNKNOWN); WKT_ERROR(); }
-#line 1889 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 1893 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 3:
-#line 215 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 223 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ wkt_parser_geometry_new((yyvsp[0].geometryvalue), (yyvsp[-2].integervalue)); WKT_ERROR(); }
-#line 1895 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 1899 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 4:
-#line 218 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 226 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = (yyvsp[0].geometryvalue); }
-#line 1901 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 1905 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 5:
-#line 219 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 227 "lwin_wkt_parse.y" /* yacc.c:1645 */
-#line 1907 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 1911 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 6:
-#line 220 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 228 "lwin_wkt_parse.y" /* yacc.c:1645 */
-#line 1913 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 1917 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 7:
-#line 221 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 229 "lwin_wkt_parse.y" /* yacc.c:1645 */
-#line 1919 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 1923 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 8:
-#line 222 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 230 "lwin_wkt_parse.y" /* yacc.c:1645 */
-#line 1925 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 1929 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 9:
-#line 223 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 231 "lwin_wkt_parse.y" /* yacc.c:1645 */
-#line 1931 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 1935 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 10:
-#line 224 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 232 "lwin_wkt_parse.y" /* yacc.c:1645 */
-#line 1937 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 1941 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 11:
-#line 225 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 233 "lwin_wkt_parse.y" /* yacc.c:1645 */
-#line 1943 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 1947 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 12:
-#line 226 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 234 "lwin_wkt_parse.y" /* yacc.c:1645 */
-#line 1949 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 1953 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 13:
-#line 227 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 235 "lwin_wkt_parse.y" /* yacc.c:1645 */
-#line 1955 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 1959 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 14:
-#line 228 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 236 "lwin_wkt_parse.y" /* yacc.c:1645 */
-#line 1961 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 1965 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 15:
-#line 229 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 237 "lwin_wkt_parse.y" /* yacc.c:1645 */
-#line 1967 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 1971 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 16:
-#line 230 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 238 "lwin_wkt_parse.y" /* yacc.c:1645 */
-#line 1973 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 1977 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 17:
-#line 231 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 239 "lwin_wkt_parse.y" /* yacc.c:1645 */
-#line 1979 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 1983 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 18:
-#line 232 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 240 "lwin_wkt_parse.y" /* yacc.c:1645 */
-#line 1985 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 1989 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 19:
-#line 236 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 244 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(COLLECTIONTYPE, (yyvsp[-1].geometryvalue), NULL); WKT_ERROR(); }
-#line 1991 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 1995 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 20:
-#line 238 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 246 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(COLLECTIONTYPE, (yyvsp[-1].geometryvalue), (yyvsp[-3].stringvalue)); WKT_ERROR(); }
-#line 1997 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2001 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 21:
-#line 240 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 248 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(COLLECTIONTYPE, NULL, (yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 2003 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2007 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 22:
-#line 242 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 250 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(COLLECTIONTYPE, NULL, NULL); WKT_ERROR(); }
-#line 2009 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2013 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 23:
-#line 246 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 254 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_collection_add_geom((yyvsp[-2].geometryvalue),(yyvsp[0].geometryvalue)); WKT_ERROR(); }
-#line 2015 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2019 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 24:
-#line 248 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 256 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_collection_new((yyvsp[0].geometryvalue)); WKT_ERROR(); }
-#line 2021 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2025 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 25:
-#line 252 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 260 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTISURFACETYPE, (yyvsp[-1].geometryvalue), NULL); WKT_ERROR(); }
-#line 2027 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2031 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 26:
-#line 254 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 262 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTISURFACETYPE, (yyvsp[-1].geometryvalue), (yyvsp[-3].stringvalue)); WKT_ERROR(); }
-#line 2033 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2037 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 27:
-#line 256 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 264 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTISURFACETYPE, NULL, (yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 2039 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2043 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 28:
-#line 258 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 266 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTISURFACETYPE, NULL, NULL); WKT_ERROR(); }
-#line 2045 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2049 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 29:
-#line 262 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 270 "lwin_wkt_parse.y" /* yacc.c:1645 */
-#line 2051 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2055 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 30:
-#line 264 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 272 "lwin_wkt_parse.y" /* yacc.c:1645 */
-#line 2057 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2061 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 31:
-#line 266 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 274 "lwin_wkt_parse.y" /* yacc.c:1645 */
-#line 2063 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2067 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 32:
-#line 268 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 276 "lwin_wkt_parse.y" /* yacc.c:1645 */
-#line 2069 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2073 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 33:
-#line 270 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 278 "lwin_wkt_parse.y" /* yacc.c:1645 */
-#line 2075 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2079 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 34:
-#line 272 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 280 "lwin_wkt_parse.y" /* yacc.c:1645 */
-#line 2081 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2085 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 35:
-#line 276 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 284 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(TINTYPE, (yyvsp[-1].geometryvalue), NULL); WKT_ERROR(); }
-#line 2087 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2091 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 36:
-#line 278 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 286 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(TINTYPE, (yyvsp[-1].geometryvalue), (yyvsp[-3].stringvalue)); WKT_ERROR(); }
-#line 2093 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2097 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 37:
-#line 280 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 288 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(TINTYPE, NULL, (yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 2099 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2103 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 38:
-#line 282 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 290 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(TINTYPE, NULL, NULL); WKT_ERROR(); }
-#line 2105 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2109 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 39:
-#line 286 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 294 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(POLYHEDRALSURFACETYPE, (yyvsp[-1].geometryvalue), NULL); WKT_ERROR(); }
-#line 2111 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2115 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 40:
-#line 288 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 296 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(POLYHEDRALSURFACETYPE, (yyvsp[-1].geometryvalue), (yyvsp[-3].stringvalue)); WKT_ERROR(); }
-#line 2117 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2121 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 41:
-#line 290 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 298 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(POLYHEDRALSURFACETYPE, NULL, (yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 2123 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2127 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 42:
-#line 292 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 300 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(POLYHEDRALSURFACETYPE, NULL, NULL); WKT_ERROR(); }
-#line 2129 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2133 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 43:
-#line 296 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 304 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTIPOLYGONTYPE, (yyvsp[-1].geometryvalue), NULL); WKT_ERROR(); }
-#line 2135 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2139 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 44:
-#line 298 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 306 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTIPOLYGONTYPE, (yyvsp[-1].geometryvalue), (yyvsp[-3].stringvalue)); WKT_ERROR(); }
-#line 2141 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2145 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 45:
-#line 300 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 308 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTIPOLYGONTYPE, NULL, (yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 2147 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2151 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 46:
-#line 302 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 310 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTIPOLYGONTYPE, NULL, NULL); WKT_ERROR(); }
-#line 2153 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2157 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 47:
-#line 306 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 314 "lwin_wkt_parse.y" /* yacc.c:1645 */
-#line 2159 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2163 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 48:
-#line 308 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 316 "lwin_wkt_parse.y" /* yacc.c:1645 */
-#line 2165 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2169 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 49:
-#line 312 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 320 "lwin_wkt_parse.y" /* yacc.c:1645 */
-#line 2171 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2175 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 50:
-#line 314 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 322 "lwin_wkt_parse.y" /* yacc.c:1645 */
-#line 2177 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2181 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 51:
-#line 318 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 326 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_polygon_finalize((yyvsp[-1].geometryvalue), NULL); WKT_ERROR(); }
-#line 2183 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2187 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 52:
-#line 320 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 328 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_polygon_finalize((yyvsp[-1].geometryvalue), (yyvsp[-3].stringvalue)); WKT_ERROR(); }
-#line 2189 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2193 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 53:
-#line 322 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 330 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_polygon_finalize(NULL, (yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 2195 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2199 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 54:
-#line 324 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 332 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_polygon_finalize(NULL, NULL); WKT_ERROR(); }
-#line 2201 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2205 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 55:
-#line 328 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 336 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = (yyvsp[-1].geometryvalue); }
-#line 2207 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2211 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 56:
-#line 330 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 338 "lwin_wkt_parse.y" /* yacc.c:1645 */
-#line 2213 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2217 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 57:
-#line 333 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 341 "lwin_wkt_parse.y" /* yacc.c:1645 */
-#line 2219 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2223 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 58:
-#line 337 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 345 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_curvepolygon_finalize((yyvsp[-1].geometryvalue), NULL); WKT_ERROR(); }
-#line 2225 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2229 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 59:
-#line 339 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 347 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_curvepolygon_finalize((yyvsp[-1].geometryvalue), (yyvsp[-3].stringvalue)); WKT_ERROR(); }
-#line 2231 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2235 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 60:
-#line 341 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 349 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_curvepolygon_finalize(NULL, (yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 2237 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2241 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 61:
-#line 343 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 351 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_curvepolygon_finalize(NULL, NULL); WKT_ERROR(); }
-#line 2243 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2247 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 62:
-#line 347 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 355 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_curvepolygon_add_ring((yyvsp[-2].geometryvalue),(yyvsp[0].geometryvalue)); WKT_ERROR(); }
-#line 2249 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2253 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 63:
-#line 349 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 357 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_curvepolygon_new((yyvsp[0].geometryvalue)); WKT_ERROR(); }
-#line 2255 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2259 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 64:
-#line 352 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 360 "lwin_wkt_parse.y" /* yacc.c:1645 */
-#line 2261 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2265 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 65:
-#line 353 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 361 "lwin_wkt_parse.y" /* yacc.c:1645 */
-#line 2267 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2271 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 66:
-#line 354 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 362 "lwin_wkt_parse.y" /* yacc.c:1645 */
-#line 2273 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2277 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 67:
-#line 355 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 363 "lwin_wkt_parse.y" /* yacc.c:1645 */
-#line 2279 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2283 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 68:
-#line 359 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 367 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_polygon_add_ring((yyvsp[-2].geometryvalue),(yyvsp[0].ptarrayvalue),'Z'); WKT_ERROR(); }
-#line 2285 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2289 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 69:
-#line 361 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 369 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_polygon_new((yyvsp[0].ptarrayvalue),'Z'); WKT_ERROR(); }
-#line 2291 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2295 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 70:
-#line 365 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 373 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_polygon_add_ring((yyvsp[-2].geometryvalue),(yyvsp[0].ptarrayvalue),'2'); WKT_ERROR(); }
-#line 2297 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2301 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 71:
-#line 367 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 375 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_polygon_new((yyvsp[0].ptarrayvalue),'2'); WKT_ERROR(); }
-#line 2303 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2307 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 72:
-#line 370 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 378 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.ptarrayvalue) = (yyvsp[-1].ptarrayvalue); }
-#line 2309 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2313 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 73:
-#line 373 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 381 "lwin_wkt_parse.y" /* yacc.c:1645 */
-#line 2315 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2319 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 74:
-#line 377 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 385 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(COMPOUNDTYPE, (yyvsp[-1].geometryvalue), NULL); WKT_ERROR(); }
-#line 2321 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2325 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 75:
-#line 379 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 387 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(COMPOUNDTYPE, (yyvsp[-1].geometryvalue), (yyvsp[-3].stringvalue)); WKT_ERROR(); }
-#line 2327 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2331 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 76:
-#line 381 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 389 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(COMPOUNDTYPE, NULL, (yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 2333 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2337 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 77:
-#line 383 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 391 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(COMPOUNDTYPE, NULL, NULL); WKT_ERROR(); }
-#line 2339 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2343 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 78:
-#line 387 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 395 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_compound_add_geom((yyvsp[-2].geometryvalue),(yyvsp[0].geometryvalue)); WKT_ERROR(); }
-#line 2345 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2349 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 79:
-#line 389 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 397 "lwin_wkt_parse.y" /* yacc.c:1645 */
-#line 2351 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2355 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 80:
-#line 391 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 399 "lwin_wkt_parse.y" /* yacc.c:1645 */
-#line 2357 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2361 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 81:
-#line 393 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 401 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_compound_new((yyvsp[0].geometryvalue)); WKT_ERROR(); }
-#line 2363 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2367 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 82:
-#line 395 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 403 "lwin_wkt_parse.y" /* yacc.c:1645 */
-#line 2369 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2373 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 83:
-#line 397 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 405 "lwin_wkt_parse.y" /* yacc.c:1645 */
-#line 2375 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2379 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 84:
-#line 401 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 409 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTICURVETYPE, (yyvsp[-1].geometryvalue), NULL); WKT_ERROR(); }
-#line 2381 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2385 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 85:
-#line 403 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 411 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTICURVETYPE, (yyvsp[-1].geometryvalue), (yyvsp[-3].stringvalue)); WKT_ERROR(); }
-#line 2387 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2391 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 86:
-#line 405 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 413 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTICURVETYPE, NULL, (yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 2393 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2397 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 87:
-#line 407 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 415 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTICURVETYPE, NULL, NULL); WKT_ERROR(); }
-#line 2399 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2403 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 88:
-#line 411 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 419 "lwin_wkt_parse.y" /* yacc.c:1645 */
-#line 2405 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2409 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 89:
-#line 413 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 421 "lwin_wkt_parse.y" /* yacc.c:1645 */
-#line 2411 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2415 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 90:
-#line 415 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 423 "lwin_wkt_parse.y" /* yacc.c:1645 */
-#line 2417 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2421 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 91:
-#line 417 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 425 "lwin_wkt_parse.y" /* yacc.c:1645 */
-#line 2423 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2427 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 92:
-#line 419 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 427 "lwin_wkt_parse.y" /* yacc.c:1645 */
-#line 2429 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2433 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 93:
-#line 421 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 429 "lwin_wkt_parse.y" /* yacc.c:1645 */
-#line 2435 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2439 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 94:
-#line 423 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 431 "lwin_wkt_parse.y" /* yacc.c:1645 */
-#line 2441 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2445 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 95:
-#line 425 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 433 "lwin_wkt_parse.y" /* yacc.c:1645 */
-#line 2447 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2451 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 96:
-#line 429 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 437 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTILINETYPE, (yyvsp[-1].geometryvalue), NULL); WKT_ERROR(); }
-#line 2453 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2457 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 97:
-#line 431 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 439 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTILINETYPE, (yyvsp[-1].geometryvalue), (yyvsp[-3].stringvalue)); WKT_ERROR(); }
-#line 2459 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2463 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 98:
-#line 433 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 441 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTILINETYPE, NULL, (yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 2465 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2469 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 99:
-#line 435 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 443 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTILINETYPE, NULL, NULL); WKT_ERROR(); }
-#line 2471 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2475 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 100:
-#line 439 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 447 "lwin_wkt_parse.y" /* yacc.c:1645 */
-#line 2477 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2481 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 101:
-#line 441 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 449 "lwin_wkt_parse.y" /* yacc.c:1645 */
-#line 2483 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2487 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 102:
-#line 445 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 453 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_circularstring_new((yyvsp[-1].ptarrayvalue), NULL); WKT_ERROR(); }
-#line 2489 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2493 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 103:
-#line 447 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 455 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_circularstring_new((yyvsp[-1].ptarrayvalue), (yyvsp[-3].stringvalue)); WKT_ERROR(); }
-#line 2495 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2499 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 104:
-#line 449 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 457 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_circularstring_new(NULL, (yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 2501 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2505 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 105:
-#line 451 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 459 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_circularstring_new(NULL, NULL); WKT_ERROR(); }
-#line 2507 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2511 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 106:
-#line 455 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 463 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_linestring_new((yyvsp[-1].ptarrayvalue), NULL); WKT_ERROR(); }
-#line 2513 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2517 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 107:
-#line 457 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 465 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_linestring_new((yyvsp[-1].ptarrayvalue), (yyvsp[-3].stringvalue)); WKT_ERROR(); }
-#line 2519 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2523 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 108:
-#line 459 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 467 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_linestring_new(NULL, (yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 2525 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2529 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 109:
-#line 461 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 469 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_linestring_new(NULL, NULL); WKT_ERROR(); }
-#line 2531 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2535 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 110:
-#line 465 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 473 "lwin_wkt_parse.y" /* yacc.c:1645 */
-#line 2537 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2541 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 111:
-#line 467 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 475 "lwin_wkt_parse.y" /* yacc.c:1645 */
-#line 2543 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2547 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 112:
-#line 471 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 479 "lwin_wkt_parse.y" /* yacc.c:1645 */
-#line 2549 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2553 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 113:
-#line 473 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 481 "lwin_wkt_parse.y" /* yacc.c:1645 */
-#line 2555 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2559 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 114:
-#line 477 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 485 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_triangle_new((yyvsp[-2].ptarrayvalue), NULL); WKT_ERROR(); }
-#line 2561 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2565 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 115:
-#line 479 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 487 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_triangle_new((yyvsp[-2].ptarrayvalue), (yyvsp[-5].stringvalue)); WKT_ERROR(); }
-#line 2567 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2571 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 116:
-#line 481 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 489 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_triangle_new(NULL, (yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 2573 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2577 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 117:
-#line 483 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 491 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_triangle_new(NULL, NULL); WKT_ERROR(); }
-#line 2579 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2583 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 118:
-#line 487 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 495 "lwin_wkt_parse.y" /* yacc.c:1645 */
-#line 2585 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2589 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 119:
-#line 491 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 499 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTIPOINTTYPE, (yyvsp[-1].geometryvalue), NULL); WKT_ERROR(); }
-#line 2591 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2595 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 120:
-#line 493 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 501 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTIPOINTTYPE, (yyvsp[-1].geometryvalue), (yyvsp[-3].stringvalue)); WKT_ERROR(); }
-#line 2597 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2601 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 121:
-#line 495 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 503 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTIPOINTTYPE, NULL, (yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 2603 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2607 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 122:
-#line 497 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 505 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTIPOINTTYPE, NULL, NULL); WKT_ERROR(); }
-#line 2609 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2613 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 123:
-#line 501 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 509 "lwin_wkt_parse.y" /* yacc.c:1645 */
-#line 2615 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2619 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 124:
-#line 503 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 511 "lwin_wkt_parse.y" /* yacc.c:1645 */
-#line 2621 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2625 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 125:
-#line 507 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 515 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_point_new(wkt_parser_ptarray_new((yyvsp[0].coordinatevalue)),NULL); WKT_ERROR(); }
-#line 2627 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2631 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 126:
-#line 509 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 517 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_point_new(wkt_parser_ptarray_new((yyvsp[-1].coordinatevalue)),NULL); WKT_ERROR(); }
-#line 2633 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2637 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 127:
-#line 511 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 519 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_point_new(NULL, NULL); WKT_ERROR(); }
-#line 2639 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2643 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 128:
-#line 515 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 523 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_point_new((yyvsp[-1].ptarrayvalue), NULL); WKT_ERROR(); }
-#line 2645 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2649 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 129:
-#line 517 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 525 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_point_new((yyvsp[-1].ptarrayvalue), (yyvsp[-3].stringvalue)); WKT_ERROR(); }
-#line 2651 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2655 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 130:
-#line 519 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 527 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_point_new(NULL, (yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 2657 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2661 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 131:
-#line 521 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 529 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.geometryvalue) = wkt_parser_point_new(NULL,NULL); WKT_ERROR(); }
-#line 2663 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2667 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 132:
-#line 525 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 533 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.ptarrayvalue) = wkt_parser_ptarray_add_coord((yyvsp[-2].ptarrayvalue), (yyvsp[0].coordinatevalue)); WKT_ERROR(); }
-#line 2669 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2673 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 133:
-#line 527 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 535 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.ptarrayvalue) = wkt_parser_ptarray_new((yyvsp[0].coordinatevalue)); WKT_ERROR(); }
-#line 2675 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2679 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 134:
-#line 531 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 539 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.coordinatevalue) = wkt_parser_coord_2((yyvsp[-1].doublevalue), (yyvsp[0].doublevalue)); WKT_ERROR(); }
-#line 2681 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2685 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 135:
-#line 533 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 541 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.coordinatevalue) = wkt_parser_coord_3((yyvsp[-2].doublevalue), (yyvsp[-1].doublevalue), (yyvsp[0].doublevalue)); WKT_ERROR(); }
-#line 2687 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2691 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
case 136:
-#line 535 "lwin_wkt_parse.y" /* yacc.c:1646 */
+#line 543 "lwin_wkt_parse.y" /* yacc.c:1645 */
{ (yyval.coordinatevalue) = wkt_parser_coord_4((yyvsp[-3].doublevalue), (yyvsp[-2].doublevalue), (yyvsp[-1].doublevalue), (yyvsp[0].doublevalue)); WKT_ERROR(); }
-#line 2693 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2697 "lwin_wkt_parse.c" /* yacc.c:1645 */
break;
-#line 2697 "lwin_wkt_parse.c" /* yacc.c:1646 */
+#line 2701 "lwin_wkt_parse.c" /* yacc.c:1645 */
default: break;
/* User semantic actions sometimes alter yychar, and that requires
@@ -2750,15 +2723,14 @@
/* Now 'shift' the result of the reduction. Determine what state
that goes to, based on the state we popped back to and the rule
number reduced by. */
+ const int yylhs = yyr1[yyn] - YYNTOKENS;
+ const int yyi = yypgoto[yylhs] + *yyssp;
+ yystate = (0 <= yyi && yyi <= YYLAST && yycheck[yyi] == *yyssp
+ ? yytable[yyi]
+ : yydefgoto[yylhs]);
- yyn = yyr1[yyn];
- yystate = yypgoto[yyn - YYNTOKENS] + *yyssp;
- if (0 <= yystate && yystate <= YYLAST && yycheck[yystate] == *yyssp)
- yystate = yytable[yystate];
- else
- yystate = yydefgoto[yyn - YYNTOKENS];
goto yynewstate;
@@ -2847,7 +2819,6 @@
if (/*CONSTCOND*/ 0)
goto yyerrorlab;
- yyerror_range[1] = yylsp[1-yylen];
/* Do not reclaim the symbols of the rule whose action triggered
this YYERROR. */
YYPOPSTACK (yylen);
@@ -2959,6 +2930,6 @@
#endif
return yyresult;
-#line 537 "lwin_wkt_parse.y" /* yacc.c:1906 */
+#line 545 "lwin_wkt_parse.y" /* yacc.c:1903 */
Modified: branches/2.4/liblwgeom/lwin_wkt_parse.h
--- branches/2.4/liblwgeom/lwin_wkt_parse.h 2019-01-21 19:47:14 UTC (rev 17197)
+++ branches/2.4/liblwgeom/lwin_wkt_parse.h 2019-01-21 19:50:56 UTC (rev 17198)
@@ -1,31 +1,8 @@
/* Bison interface for Yacc-like parsers in C
@@ -53,6 +30,9 @@
This special exception was added by the Free Software Foundation in
version 2.2 of Bison. */
#ifndef YY_WKT_YY_LWIN_WKT_PARSE_H_INCLUDED
# define YY_WKT_YY_LWIN_WKT_PARSE_H_INCLUDED
/* Debug traces. */
@@ -123,7 +103,7 @@
union YYSTYPE
-#line 108 "lwin_wkt_parse.y" /* yacc.c:1909 */
+#line 116 "lwin_wkt_parse.y" /* yacc.c:1906 */
int integervalue;
double doublevalue;
@@ -132,7 +112,7 @@
-#line 113 "lwin_wkt_parse.h" /* yacc.c:1909 */
+#line 116 "lwin_wkt_parse.h" /* yacc.c:1906 */
