[postgis-tickets] [PostGIS] #4303: Getting this error on many bots -ALTER EXTENSION failing
trac at osgeo.org
Mon Jan 21 14:58:06 PST 2019
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.0.0
Component: postgis | Version: trunk
Keywords: |
17:30:49 ^
17:30:49 HINT: Perhaps you meant to reference the column "proc.probin".
17:30:49 QUERY: SELECT 'ALTER EXTENSION ' || e.extname || ' DROP ' || $3
|| ' ' || COALESCE(proc.proname || '(' || oidvectortypes(proc.proargtypes)
|| ')' ,typ.typname, cd.relname, op.oprname,
17:30:49 cs.typname || ' AS ' ||
ct.typname || ') ', opcname, opfname) || ';' AS remove_command
17:30:49 FROM pg_depend As d INNER JOIN
pg_extension As e
17:30:49 ON d.refobjid = e.oid INNER JOIN
pg_class As c ON
17:30:49 c.oid = d.classid
17:30:49 LEFT JOIN pg_proc AS proc
ON proc.oid = d.objid
17:30:49 LEFT JOIN pg_type AS typ
ON typ.oid = d.objid
17:30:49 LEFT JOIN pg_class As cd
ON cd.oid = d.objid
17:30:49 LEFT JOIN pg_operator As
op ON op.oid = d.objid
17:30:49 LEFT JOIN pg_cast AS ca ON
ca.oid = d.objid
17:30:49 LEFT JOIN pg_type AS cs ON
ca.castsource = cs.oid
17:30:49 LEFT JOIN pg_type AS ct ON
ca.casttarget = ct.oid
17:30:49 LEFT JOIN pg_opclass As oc
ON oc.oid = d.objid
17:30:49 LEFT JOIN pg_opfamily As
ofa ON ofa.oid = d.objid
17:30:49 WHERE d.deptype = 'e' and e.extname = $1
and c.relname = $2 AND (proc.prokind = 'a') = $4;
17:30:49 CONTEXT: PL/pgSQL function
postgis_extension_remove_objects(text,text) line 48 at FOR over EXECUTE
statement
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4303>
