[postgis-tickets] [PostGIS] #4260: Stop installing headers
trac at osgeo.org
Tue Jan 22 02:40:53 PST 2019
Reporter: Algunenano | Owner: Algunenano
Type: defect | Status: reopened
Priority: blocker | Milestone: PostGIS 3.0.0
Component: liblwgeom | Version: trunk
Resolution: | Keywords:
Changes (by Algunenano):
* status: closed => reopened
* resolution: fixed =>
Comment:
> Statically link shp2pgsql and other loader utilities to
liblwgeom
References #4260
Travis didn't like this (https://travis-
ci.org/postgis/postgis/jobs/482789301, libtool 2.4.6) but I'm not sure
why; it works fine in my system with similar releases (libtool 2.4.6,
clang 7 or gcc 8.2):
libtool: link: gcc -I ../liblwgeom -Wall -Wmissing-prototypes -std=gnu99
-g -O2 -fno-math-errno -fno-signed-zeros -fPIC -DPIC shpopen.o dbfopen.o
getopt.o shpcommon.o safileio.o pgsql2shp-core.o pgsql2shp-cli.o -Wl,--as-
needed -Wl,-rpath -Wl,/usr/local/pgsql/lib -Wl,--enable-new-dtags -o
pgsql2shp ../liblwgeom/.libs/liblwgeom.a -L/usr/local/lib
/usr/local/lib/libgeos_c.a /usr/local/lib/libgeos.a
/usr/local/lib/libproj.a -lpthread -ljson-c -lm
/usr/local/lib/libSFCGAL.so -L/usr/local/pgsql/lib -lc -lpq
getopt.o shpcommon.o safileio.o shp2pgsql-core.o shp2pgsql-cli.o -o
shp2pgsql -Wl,--as-needed -Wl,-rpath -Wl,/usr/local/pgsql/lib -Wl
,--enable-new-dtags ../liblwgeom/.libs/liblwgeom.a -L/usr/local/lib
/usr/bin/ld: /usr/local/lib/libgeos_c.a(libgeos_c_la-geos_ts_c.o): in
function `GEOS_init_r':
/src/geos/capi/geos_ts_c.cpp:340: undefined reference to `operator
new(unsigned long)'
function `GEOSWKBReader_destroy_r':
/usr/include/c++/8/ext/new_allocator.h:125: undefined reference to
`operator delete(void*)'
function `GEOSRelate_r':
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4260#comment:11>
