[postgis-tickets] r17211 - Only build static liblwgeom
Raul raul at rmr.ninja
Tue Jan 22 07:04:04 PST 2019
Author: algunenano
Date: 2019-01-22 07:04:04 -0800 (Tue, 22 Jan 2019)
New Revision: 17211
   trunk/liblwgeom/Makefile.in
   trunk/liblwgeom/cunit/Makefile.in
References #4260
Closes https://github.com/postgis/postgis/pull/366
Modified: trunk/liblwgeom/Makefile.in
--- trunk/liblwgeom/Makefile.in	2019-01-22 12:29:06 UTC (rev 17210)
+++ trunk/liblwgeom/Makefile.in	2019-01-22 15:04:04 UTC (rev 17211)
@@ -171,7 +171,7 @@
 liblwgeom.la: $(LT_OBJS)
 	$(LIBTOOL) --tag=CC --mode=link $(CC) -rpath $(libdir) $(LT_OBJS) \
-             -release $(SOVER) -version-info $(VERSION_INFO) $(LDFLAGS) -o $@
+             -release $(SOVER) -version-info $(VERSION_INFO) $(LDFLAGS) -static -o $@
 maintainer-clean: clean
 	rm -f lwin_wkt_lex.c
Modified: trunk/liblwgeom/cunit/Makefile.in
--- trunk/liblwgeom/cunit/Makefile.in	2019-01-22 12:29:06 UTC (rev 17210)
+++ trunk/liblwgeom/cunit/Makefile.in	2019-01-22 15:04:04 UTC (rev 17211)
@@ -95,7 +95,7 @@
 # Build the main unit test executable
 cu_tester: ../liblwgeom.la $(OBJS)
-	$(LIBTOOL) --mode=link $(CC) $(CFLAGS) -o $@ $(OBJS) ../liblwgeom.la $(LDFLAGS)
+	$(LIBTOOL) --mode=link $(CC) $(CFLAGS) -o $@ $(OBJS) $(LDFLAGS) -static ../liblwgeom.la
 # Command to build each of the .o files
 $(OBJS): %.o: %.c
