[postgis-tickets] [PostGIS] #4278: ST_3DIntersects / ST_3DDistance solid aware in LWGEOM
PostGIS trac at osgeo.org
Wed Jan 23 02:52:53 PST 2019
  Reporter:  komzpa   |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 3.0.0
 Component:  postgis  |    Version:  2.4.x
Resolution:           |   Keywords:
Comment (by komzpa):
 Ray from point to infinity can be expressed as a box (Xmin=X[-eps],
 Xmax=X[+eps], Ymin=Y[-eps], Ymax=Y[+eps], Zmin=Z, Zmax = infinity). You
 can intersect such box with any dimension geometry by feeding the ranges
 into lwgeom_clip_to_ordinate_range.
 Afterwards you get a bunch of super tiny polygons with 2D area=0, area =
 eps^2. Count ones with area>0, that will get you a good approximation of
 number of hits. If you find a hit with area of 0 < area < eps^2, it's on
 the edge, mark it with a TODO:FIXME and emit a warning.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4278#comment:3>
