[postgis-tickets] [PostGIS] #4307: Building against PG 12 is broken
trac at osgeo.org
Thu Jan 24 07:35:15 PST 2019
Reporter: Algunenano | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.5.2
Component: postgis | Version: 2.4.x
Keywords: |
Example from debbie
(https://debbie.postgis.net/job/PostGIS_Regress/11208/console):
gcc -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-
statement -Werror=vla -Wendif-labels -Wmissing-format-attribute -Wformat-
security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -Wno-
format-truncation -Wno-stringop-truncation -g -O2 -fPIC -I../liblwgeom
-std=gnu99 -g -O2 -fno-math-errno -fno-signed-zeros -I../libpgcommon
-I/var/lib/jenkins/workspace/geos/rel-3.7w64/include
-I/usr/include/libxml2 -I/usr/include -DHAVE_SFCGAL -fPIC
-I/usr/include -DHAVE_SFCGAL -I. -I./
-I/var/lib/jenkins/workspace/pg/rel/pg12w64/include/postgresql/server
-I/var/lib/jenkins/workspace/pg/rel/pg12w64/include/postgresql/internal
-D_GNU_SOURCE -c -o gserialized_estimate.o gserialized_estimate.c
gserialized_estimate.c:81:10: fatal error: utils/tqual.h: No such file or
directory
#include "utils/tqual.h"
compilation terminated.
make[1]: *** [<builtin>: gserialized_estimate.o] Error 1
Changed in the following PG commit:
commit c91560defc57f89f7e88632ea14ae77b5cec78ee
Author: Andres Freund <andres at anarazel.de>
Date: Mon Jan 21 17:03:15 2019 -0800
Move remaining code from tqual.[ch] to heapam.h / heapam_visibility.c.
Given these routines are heap specific, and that there will be more
generic visibility support in via table AM, it makes sense to move the
prototypes to heapam.h (routines like HeapTupleSatisfiesVacuum will
not be exposed in a generic fashion, because they are too storage
specific).
Similarly, the code in tqual.c is specific to heap, so moving it into
access/heap/ makes sense.
Discussion:
https://postgr.es/m/20180703070645.wchpu5muyto5n647@alap3.anarazel.de
Should be backported as far as we want to support PG12 (2.4?)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4307>
