[postgis-tickets] r17216 - Put back docker hub postgis 11 test, remove drone pre 1.0 config (we are standardizing on 1.0 now)
Regina Obe
lr at pcorp.us
Sat Jan 26 10:00:53 PST 2019
Author: robe
Date: 2019-01-26 10:00:53 -0800 (Sat, 26 Jan 2019)
New Revision: 17216
Removed:
trunk/.drone.yml
trunk/.drone-1.0.yml
Modified: trunk/.drone-1.0.yml
--- trunk/.drone-1.0.yml 2019-01-25 11:52:33 UTC (rev 17215)
+++ trunk/.drone-1.0.yml 2019-01-26 18:00:53 UTC (rev 17216)
@@ -72,4 +72,15 @@
- make install
- utils/check_all_upgrades.sh
`grep '^POSTGIS_' Version.config | cut -d= -f2 | paste -sd '.'`
+test-image: &test-image postgis/postgis-build-env:pg11-geosmaster-gdal23-proj51
+kind: pipeline
+name: pg-11-geosmaster-gdal23-proj51
+steps:
+ - name: build
+ image: *test-image
+ pull: true
+ commands:
+ - bash ci/travis/run_tests.sh
Deleted: trunk/.drone.yml
--- trunk/.drone.yml 2019-01-25 11:52:33 UTC (rev 17215)
+++ trunk/.drone.yml 2019-01-26 18:00:53 UTC (rev 17216)
@@ -1,33 +0,0 @@
-# See http://readme.drone.io/0.5/usage/overview
-# See https://git.osgeo.org/gogs/postgis/postgis-docker
-test-image: &test-image docker.kbt.io/postgis/build-test:trisquel2
-matrix:
- PGVER:
- - 9.5
- - 9.6
- - 10
-pipeline:
- clone:
- image: plugins/git
- depth: 20
- recursive: false
- build:
- image: *test-image
- pull: true
- commands:
- - service postgresql start $PGVER
- - export PGPORT=`grep ^port /etc/postgresql/$PGVER/main/postgresql.conf | awk '{print $3}'`
- - export PATH=/usr/lib/postgresql/$PGVER/bin:$PATH
- - psql --version
- - ./autogen.sh
- - ./configure CFLAGS="-O0 -Wall -fno-omit-frame-pointer -Werror" --without-interrupt-tests
- - make -j
- # we should maybe wait for postgresql service to startup here...
- - psql -c "select version()" template1
- - make check RUNTESTFLAGS=-v
- - make install
- - utils/check_all_upgrades.sh
- `grep '^POSTGIS_' Version.config | cut -d= -f2 | paste -sd '.'`
