[postgis-tickets] [PostGIS] #4308: winnie is no complaining about SFCGAL in liblwgeom
PostGIS trac at osgeo.org
Sat Jan 26 15:12:14 PST 2019
 Reporter:  robe       |      Owner:  robe
     Type:  defect     |     Status:  new
 Priority:  blocker    |  Milestone:  PostGIS 3.0.0
Component:  buildbots  |    Version:  trunk
 Keywords:             |
 I don't recall liblwgeom relying on SFCGAL before so this seems like a
 relatively new problem.
 /bin/sh ../../libtool --mode=execute  ./cu_tester
 E:/jenkins/postgis/branches/3.0/liblwgeom/cunit/cu_tester.exe: error while
 loading shared libraries: libSFCGAL.dll: cannot open shared object file:
 No such file or directory
 Makefile:92: recipe for target 'check' failed
 make[2]: *** [check] Error 127
 make[2]: Leaving directory
 '/projects/postgis/branches/3.0/liblwgeom/cunit'
 Makefile:193: recipe for target 'check' failed
 make[1]: *** [check] Error 2
 make[1]: Leaving directory '/projects/postgis/branches/3.0/liblwgeom'
 GNUmakefile:20: recipe for target 'check' failed
 make: *** [check] Error 1
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4308>
