[postgis-tickets] [PostGIS] #4310: Improve MVT vectortile_layer_combine to remove duplicates
trac at osgeo.org
Mon Jan 28 07:31:20 PST 2019
Reporter: Algunenano | Owner: Algunenano
Type: enhancement | Status: assigned
Priority: medium | Milestone: PostGIS 3.0.0
Component: postgis | Version: trunk
Keywords: |
In the current parallel implementation of ST_AsMVT we combine layers by
copying both keys and values from both layers on top of each other.
This is fast but introduces the possibility of duplicates (both in keys
and values), which is discouraged in the v2 spec. This means that the
final tiles end up being bigger than they should, and might create issues
with decoders that incorrectly rely on the keys to be unique (e.g:
https://github.com/mapbox/vector-tile/issues/55).
We should look for a performant way to merge the layers removing
duplicates, if possible.
Also, that part of the code isn't currently being tested, so we'd need to
look for the proper way to do it (raising costs for the test or disabling
certain plans).
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4310>
