[postgis-tickets] [PostGIS] #4311: MVT: Introduce wagyu to clip and validate polygon
trac at osgeo.org
Mon Jan 28 08:06:33 PST 2019
Reporter: Algunenano | Owner: pramsey
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 3.0.0
Component: postgis | Version: trunk
Keywords: |
After I commented on the possibility of introducing wagyu to validate MVT
polygons inside Postgis [1], I came up with several improvements that I've
already committed and I have a final PR [3] that only contains the changes
to introduce Wagyu as an option during configure (`--with-wagyu`).
The sort summary is that on the worst case, Wagyu is as fast as GEOS and
it the best test case, it's 34x faster. The main caveat is that some small
polygons might be dropped due to how it handles tolerance (but I haven't
seen any visual impact for it).
It's currently bringing wagyu master as-is. Even though I made some
changes for performance and to add interruptions, they have been accepted
so the code is kept unmodified from upstream.
Next steps:
- I plan to move `uthash.h` to the new `deps` folders to make it clear
that the code comes from other project and it's covered by a different
license. We should also check if we want to apply an update based on
upstream.
- Similarly the `.proto` files could be moved.
- At some point in the future I want to give it a try and enable wagyu as
default and see how bots react to it (it requires a C++11 compiler and I'm
not fully confident on the mix with autotools). ''It works in my
machine...''
References:
1- Initial email: https://lists.osgeo.org/pipermail/postgis-
devel/2018-December/027613.html
2- Thread: https://lists.osgeo.org/pipermail/postgis-
devel/2018-December/thread.html#27613
3 - Github PR: https://github.com/postgis/postgis/pull/356
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4311>
