[postgis-tickets] r17222 - Coverage: Download script when needed
Raul raul at rmr.ninja
Wed Jan 30 11:36:30 PST 2019
Author: algunenano
Date: 2019-01-30 11:36:30 -0800 (Wed, 30 Jan 2019)
New Revision: 17222
Removed:
   trunk/.github/codecov.bash
   trunk/ci/travis/run_coverage.sh
Deleted: trunk/.github/codecov.bash
--- trunk/.github/codecov.bash	2019-01-30 19:17:05 UTC (rev 17221)
+++ trunk/.github/codecov.bash	2019-01-30 19:36:30 UTC (rev 17222)
@@ -1,1550 +0,0 @@
-#!/usr/bin/env bash
-# Apache License Version 2.0, January 2004
-# https://github.com/codecov/codecov-bash/blob/master/LICENSE
-set -e +o pipefail
-VERSION="8b76995"
-url="https://codecov.io"
-env="$CODECOV_ENV"
-service=""
-token=""
-search_in=""
-flags=""
-exit_with=0
-curlargs=""
-curlawsargs=""
-dump="0"
-clean="0"
-curl_s="-s"
-name="$CODECOV_NAME"
-include_cov=""
-exclude_cov=""
-ddp="$(echo ~)/Library/Developer/Xcode/DerivedData"
-xp=""
-files=""
-cacert="$CODECOV_CA_BUNDLE"
-gcov_ignore="-not -path './bower_components/**' -not -path './node_modules/**' -not -path './vendor/**'"
-gcov_include=""
-ft_gcov="1"
-ft_coveragepy="1"
-ft_fix="1"
-ft_search="1"
-ft_s3="1"
-ft_network="1"
-ft_xcodellvm="0"
-ft_xcodeplist="1"
-_git_root=$(git rev-parse --show-toplevel 2>/dev/null || hg root 2>/dev/null || echo $PWD)
-git_root="$_git_root"
-codecov_yml=""
-remote_addr=""
-if [ "$git_root" = "$PWD" ];
-then
-  git_root="."
-fi
-url_o=""
-pr_o=""
-build_o=""
-commit_o=""
-search_in_o=""
-tag_o=""
-branch_o=""
-slug_o=""
-prefix_o=""
-commit="$VCS_COMMIT_ID"
-branch="$VCS_BRANCH_NAME"
-pr="$VCS_PULL_REQUEST"
-slug="$VCS_SLUG"
-tag="$VCS_TAG"
-build_url="$CI_BUILD_URL"
-build="$CI_BUILD_ID"
-job="$CI_JOB_ID"
-beta_xcode_partials=""
-proj_root="$git_root"
-gcov_exe="gcov"
-gcov_arg=""
-b="\033[0;36m"
-g="\033[0;32m"
-r="\033[0;31m"
-e="\033[0;90m"
-x="\033[0m"
-show_help() {
-cat << EOF
-                Codecov Bash $VERSION
-          Global report uploading tool for Codecov
-       Documentation at https://docs.codecov.io/docs
-    Contribute at https://github.com/codecov/codecov-bash
-    -h          Display this help and exit
-    -f FILE     Target file(s) to upload
-                 -f "path/to/file"     only upload this file
-                                       skips searching unless provided patterns below
-                 -f '!*.bar'           ignore all files at pattern *.bar
-                 -f '*.foo'            include all files at pattern *.foo
-                 Must use single quotes.
-                 This is non-exclusive, use -s "*.foo" to match specific paths.
-    -s DIR       Directory to search for coverage reports.
-                 Already searches project root and artifact folders.
-    -t TOKEN     Set the private repository token
-                 (option) set environment variable CODECOV_TOKEN=:uuid
-                 -t @/path/to/token_file
-                 -t uuid
-    -n NAME      Custom defined name of the upload. Visible in Codecov UI
-    -e ENV       Specify environment variables to be included with this build
-                 Also accepting environment variables: CODECOV_ENV=VAR,VAR2
-                 -e VAR,VAR2
-    -X feature   Toggle functionalities
-                 -X gcov          Disable gcov
-                 -X coveragepy    Disable python coverage
-                 -X fix           Disable report fixing
-                 -X search        Disable searching for reports
-                 -X xcode         Disable xcode processing
-                 -X network       Disable uploading the file network
-    -R root dir  Used when not in git/hg project to identify project root directory
-    -y conf file Used to specify the location of the .codecov.yml config file
-    -F flag      Flag the upload to group coverage metrics
-                 -F unittests        This upload is only unittests
-                 -F integration      This upload is only integration tests
-                 -F ui,chrome        This upload is Chrome - UI tests
-    -c           Move discovered coverage reports to the trash
-    -Z           Exit with 1 if not successful. Default will Exit with 0
-    -- xcode --
-    -D           Custom Derived Data Path for Coverage.profdata and gcov processing
-                 Default '~/Library/Developer/Xcode/DerivedData'
-    -J           Specify packages to build coverage.
-                 This can significantly reduces time to build coverage reports.
-                 -J 'MyAppName'      Will match "MyAppName" and "MyAppNameTests"
-                 -J '^ExampleApp$'   Will match only "ExampleApp" not "ExampleAppTests"
-    -- gcov --
-    -g GLOB      Paths to ignore during gcov gathering
-    -G GLOB      Paths to include during gcov gathering
-    -p dir       Project root directory
-                 Also used when preparing gcov
-    -k prefix    Prefix filepaths to help resolve path fixing: https://github.com/codecov/support/issues/472
-    -x gcovexe   gcov executable to run. Defaults to 'gcov'
-    -a gcovargs  extra arguments to pass to gcov
-    -- Override CI Environment Variables --
-       These variables are automatically detected by popular CI providers
-    -B branch    Specify the branch name
-    -C sha       Specify the commit sha
-    -P pr        Specify the pull request number
-    -b build     Specify the build number
-    -T tag       Specify the git tag
-    -- Enterprise --
-    -u URL       Set the target url for Enterprise customers
-                 Not required when retrieving the bash uploader from your CCE
-                 (option) Set environment variable CODECOV_URL=https://my-hosted-codecov.com
-    -r SLUG      owner/repo slug used instead of the private repo token in Enterprise
-                 (option) set environment variable CODECOV_SLUG=:owner/:repo
-                 (option) set in your codecov.yml "codecov.slug"
-    -S PATH      File path to your cacert.pem file used to verify ssl with Codecov Enterprise (optional)
-                 (option) Set environment variable: CODECOV_CA_BUNDLE="/path/to/ca.pem"
-    -U curlargs  Extra curl arguments to communicate with Codecov. e.g., -U "--proxy http://http-proxy"
-    -A curlargs  Extra curl arguments to communicate with AWS.
-    -- Debugging --
-    -d           Don't upload, but dump upload file to stdout
-    -K           Remove color from the output
-    -v           Verbose mode
-EOF
-say() {
-  echo -e "$1"
-urlencode() {
-  echo "$1" | curl -Gso /dev/null -w %{url_effective} --data-urlencode @- "" | cut -c 3- | sed -e 's/%0A//'
-swiftcov() {
-  _dir=$(dirname "$1" | sed 's/\(Build\).*/\1/g')
-  for _type in app framework xctest
-  do
-    find "$_dir" -name "*.$_type" | while read f
-    do
-      _proj=${f##*/}
-      _proj=${_proj%."$_type"}
-      if [ "$2" = "" ] || [ "$(echo "$_proj" | grep -i "$2")" != "" ];
-      then
-        say "    $g+$x Building reports for $_proj $_type"
-        dest=$([ -f "$f/$_proj" ] && echo "$f/$_proj" || echo "$f/Contents/MacOS/$_proj")
-        _proj_name=$(echo "$_proj" | sed -e 's/[[:space:]]//g')
-        xcrun llvm-cov show $beta_xcode_partials -instr-profile "$1" "$dest" > "$_proj_name.$_type.coverage.txt" \
-         || say "    ${r}x>${x} llvm-cov failed to produce results for $dest"
-      fi
-    done
-  done
-# Credits to: https://gist.github.com/pkuczynski/8665367
-parse_yaml() {
-   local prefix=$2
-   local s='[[:space:]]*' w='[a-zA-Z0-9_]*' fs=$(echo @|tr @ '\034')
-   sed -ne "s|^\($s\)\($w\)$s:$s\"\(.*\)\"$s\$|\1$fs\2$fs\3|p" \
-        -e "s|^\($s\)\($w\)$s:$s\(.*\)$s\$|\1$fs\2$fs\3|p" $1 |
-   awk -F$fs '{
-      indent = length($1)/2;
-      vname[indent] = $2;
-      for (i in vname) {if (i > indent) {delete vname[i]}}
-      if (length($3) > 0) {
-         vn=""; if (indent > 0) {vn=(vn)(vname[0])("_")}
-         printf("%s%s%s=\"%s\"\n", "'$prefix'",vn, $2, $3);
-if [ $# != 0 ];
-then
-  while getopts "a:A:b:B:cC:dD:e:f:F:g:G:hJ:k:Kn:p:P:r:R:y:s:S:t:T:u:U:vx:X:Z" o
-  do
-    case "$o" in
-      "a")
-        gcov_arg=$OPTARG
-      "A")
-        curlawsargs="$OPTARG"
-      "b")
-        build_o="$OPTARG"
-      "B")
-        branch_o="$OPTARG"
-      "c")
-        clean="1"
-      "C")
-        commit_o="$OPTARG"
-      "d")
-        dump="1"
-      "D")
-        ddp="$OPTARG"
-      "e")
-        env="$env,$OPTARG"
-      "f")
-        if [ "${OPTARG::1}" = "!" ];
-        then
-          exclude_cov="$exclude_cov -not -path '${OPTARG:1}'"
-        elif [[ "$OPTARG" = *"*"* ]];
-        then
-          include_cov="$include_cov -or -name '$OPTARG'"
-        else
-          ft_search=0
-          if [ "$files" = "" ];
-          then
-            files="$OPTARG"
-          else
-            files="$files
-$OPTARG"
-          fi
-        fi
-      "F")
-        if [ "$flags" = "" ];
-        then
-          flags="$OPTARG"
-        else
-          flags="$flags,$OPTARG"
-        fi
-      "g")
-        gcov_ignore="$gcov_ignore -not -path '$OPTARG'"
-      "G")
-        gcov_include="$gcov_include -path '$OPTARG'"
-      "h")
-        show_help
-        exit 0;
-      "J")
-        ft_xcodellvm="1"
-        ft_xcodeplist="0"
-        if [ "$xp" = "" ];
-        then
-          xp="$OPTARG"
-        else
-          xp="$xp\|$OPTARG"
-        fi
-      "k")
-        prefix_o=$(echo "$OPTARG" | sed -e 's:^/*::' -e 's:/*$::')
-      "K")
-        b=""
-        g=""
-        r=""
-        e=""
-        x=""
-      "n")
-        name="$OPTARG"
-      "p")
-        proj_root="$OPTARG"
-      "P")
-        pr_o="$OPTARG"
-      "r")
-        slug_o="$OPTARG"
-      "R")
-        git_root="$OPTARG"
-      "s")
-        if [ "$search_in_o" = "" ];
-        then
-          search_in_o="$OPTARG"
-        else
-          search_in_o="$search_in_o $OPTARG"
-        fi
-      "S")
-        cacert="--cacert \"$OPTARG\""
-      "t")
-        if [ "${OPTARG::1}" = "@" ];
-        then
-          token=$(cat "${OPTARG:1}" | tr -d ' \n')
-        else
-          token="$OPTARG"
-        fi
-      "T")
-        tag_o="$OPTARG"
-      "u")
-        url_o=$(echo "$OPTARG" | sed -e 's/\/$//')
-      "U")
-        curlargs="$OPTARG"
-      "v")
-        set -x
-        curl_s=""
-      "x")
-        gcov_exe=$OPTARG
-      "X")
-        if [ "$OPTARG" = "gcov" ];
-        then
-          ft_gcov="0"
-        elif [ "$OPTARG" = "coveragepy" ] || [ "$OPTARG" = "py" ];
-        then
-          ft_coveragepy="0"
-        elif [ "$OPTARG" = "xcodellvm" ];
-        then
-          ft_xcodellvm="1"
-          ft_xcodeplist="0"
-        elif [ "$OPTARG" = "fix" ] || [ "$OPTARG" = "fixes" ];
-        then
-          ft_fix="0"
-        elif [ "$OPTARG" = "xcode" ];
-        then
-          ft_xcodellvm="0"
-          ft_xcodeplist="0"
-        elif [ "$OPTARG" = "search" ];
-        then
-          ft_search="0"
-        elif [ "$OPTARG" = "xcodepartials" ];
-        then
-          beta_xcode_partials="-use-color"
-        elif [ "$OPTARG" = "network" ];
-        then
-          ft_network="0"
-        elif [ "$OPTARG" = "s3" ];
-        then
-          ft_s3="0"
-        fi
-      "y")
-        codecov_yml="$OPTARG"
-      "Z")
-        exit_with=1
-    esac
-  done
-fi
-say "
-  _____          _
- / ____|        | |
-| |     ___   __| | ___  ___ _____   __
-| |    / _ \\ / _\` |/ _ \\/ __/ _ \\ \\ / /
-| |___| (_) | (_| |  __/ (_| (_) \\ V /
- \\_____\\___/ \\__,_|\\___|\\___\\___/ \\_/
-                              Bash-$VERSION
-search_in="$proj_root"
-if [ "$JENKINS_URL" != "" ];
-then
-  say "$e==>$x Jenkins CI detected."
-  # https://wiki.jenkins-ci.org/display/JENKINS/Building+a+software+project
-  # https://wiki.jenkins-ci.org/display/JENKINS/GitHub+pull+request+builder+plugin#GitHubpullrequestbuilderplugin-EnvironmentVariables
-  service="jenkins"
-  if [ "$ghprbSourceBranch" != "" ];
-  then
-     branch="$ghprbSourceBranch"
-  elif [ "$GIT_BRANCH" != "" ];
-  then
-     branch="$GIT_BRANCH"
-  elif [ "$BRANCH_NAME" != "" ];
-  then
-    branch="$BRANCH_NAME"
-  fi
-  if [ "$ghprbActualCommit" != "" ];
-  then
-    commit="$ghprbActualCommit"
-  elif [ "$GIT_COMMIT" != "" ];
-  then
-    commit="$GIT_COMMIT"
-  fi
-  if [ "$ghprbPullId" != "" ];
-  then
-    pr="$ghprbPullId"
-  elif [ "$CHANGE_ID" != "" ];
-  then
-    pr="$CHANGE_ID"
-  fi
-  build="$BUILD_NUMBER"
-  build_url=$(urlencode "$BUILD_URL")
-elif [ "$CI" = "true" ] && [ "$TRAVIS" = "true" ] && [ "$SHIPPABLE" != "true" ];
-then
-  say "$e==>$x Travis CI detected."
-  # https://docs.travis-ci.com/user/environment-variables/
-  service="travis"
-  commit="${TRAVIS_PULL_REQUEST_SHA:-$TRAVIS_COMMIT}"
-  build="$TRAVIS_JOB_NUMBER"
-  pr="$TRAVIS_PULL_REQUEST"
-  job="$TRAVIS_JOB_ID"
-  slug="$TRAVIS_REPO_SLUG"
-  env="$env,TRAVIS_OS_NAME"
-  tag="$TRAVIS_TAG"
-  if [ "$TRAVIS_BRANCH" != "$TRAVIS_TAG" ];
-  then
-    branch="$TRAVIS_BRANCH"
-  fi
-  language=$(printenv | grep "TRAVIS_.*_VERSION" | head -1)
-  if [ "$language" != "" ];
-  then
-    env="$env,${language%=*}"
-  fi
-elif [ "$DOCKER_REPO" != "" ];
-then
-  say "$e==>$x Docker detected."
-  # https://docs.docker.com/docker-cloud/builds/advanced/
-  service="docker"
-  branch="$SOURCE_BRANCH"
-  commit="$SOURCE_COMMIT"
-  slug="$DOCKER_REPO"
-  tag="$CACHE_TAG"
-  env="$env,IMAGE_NAME"
-elif [ "$CI" = "true" ] && [ "$CI_NAME" = "codeship" ];
-then
-  say "$e==>$x Codeship CI detected."
-  # https://www.codeship.io/documentation/continuous-integration/set-environment-variables/
-  service="codeship"
-  branch="$CI_BRANCH"
-  build="$CI_BUILD_NUMBER"
-  build_url=$(urlencode "$CI_BUILD_URL")
-  commit="$CI_COMMIT_ID"
-elif [ ! -z "$CF_BUILD_URL" ] && [ ! -z "$CF_BUILD_ID" ];
-then
-  say "$e==>$x Codefresh CI detected."
-  # https://docs.codefresh.io/v1.0/docs/variables
-  service="codefresh"
-  branch="$CF_BRANCH"
-  build="$CF_BUILD_ID"
-  build_url=$(urlencode "$CF_BUILD_URL")
-  commit="$CF_REVISION"
-elif [ "$TEAMCITY_VERSION" != "" ];
-then
-  say "$e==>$x TeamCity CI detected."
-  # https://confluence.jetbrains.com/display/TCD8/Predefined+Build+Parameters
-  # https://confluence.jetbrains.com/plugins/servlet/mobile#content/view/74847298
-  if [ "$TEAMCITY_BUILD_BRANCH" = '' ];
-  then
-    echo "    Teamcity does not automatically make build parameters available as environment variables."
-    echo "    Add the following environment parameters to the build configuration"
-    echo "    env.TEAMCITY_BUILD_BRANCH = %teamcity.build.branch%"
-    echo "    env.TEAMCITY_BUILD_ID = %teamcity.build.id%"
-    echo "    env.TEAMCITY_BUILD_URL = %teamcity.serverUrl%/viewLog.html?buildId=%teamcity.build.id%"
-    echo "    env.TEAMCITY_BUILD_COMMIT = %system.build.vcs.number%"
-    echo "    env.TEAMCITY_BUILD_REPOSITORY = %vcsroot.<YOUR TEAMCITY VCS NAME>.url%"
-  fi
-  service="teamcity"
-  branch="$TEAMCITY_BUILD_BRANCH"
-  build="$TEAMCITY_BUILD_ID"
-  build_url=$(urlencode "$TEAMCITY_BUILD_URL")
-  if [ "$TEAMCITY_BUILD_COMMIT" != "" ];
-  then
-    commit="$TEAMCITY_BUILD_COMMIT"
-  else
-    commit="$BUILD_VCS_NUMBER"
-  fi
-  remote_addr="$TEAMCITY_BUILD_REPOSITORY"
-elif [ "$CI" = "true" ] && [ "$CIRCLECI" = "true" ];
-then
-  say "$e==>$x Circle CI detected."
-  # https://circleci.com/docs/environment-variables
-  service="circleci"
-  branch="$CIRCLE_BRANCH"
-  build="$CIRCLE_BUILD_NUM"
-  job="$CIRCLE_NODE_INDEX"
-  if [ "$CIRCLE_PROJECT_REPONAME" != "" ];
-  then
-    slug="$CIRCLE_PROJECT_USERNAME/$CIRCLE_PROJECT_REPONAME"
-  else
-    # git at github.com:owner/repo.git
-    slug="${CIRCLE_REPOSITORY_URL##*:}"
-    # owner/repo.git
-    slug="${slug%%.git}"
-  fi
-  pr="$CIRCLE_PR_NUMBER"
-  commit="$CIRCLE_SHA1"
-  search_in="$search_in $CIRCLE_ARTIFACTS $CIRCLE_TEST_REPORTS"
-elif [ "$BUDDYBUILD_BRANCH" != "" ];
-then
-  say "$e==>$x buddybuild detected"
-  # http://docs.buddybuild.com/v6/docs/custom-prebuild-and-postbuild-steps
-  service="buddybuild"
-  branch="$BUDDYBUILD_BRANCH"
-  build="$BUDDYBUILD_BUILD_NUMBER"
-  build_url="https://dashboard.buddybuild.com/public/apps/$BUDDYBUILD_APP_ID/build/$BUDDYBUILD_BUILD_ID"
-  # BUDDYBUILD_TRIGGERED_BY
-  if [ "$ddp" = "$(echo ~)/Library/Developer/Xcode/DerivedData" ];
-  then
-    ddp="/private/tmp/sandbox/${BUDDYBUILD_APP_ID}/bbtest"
-  fi
-elif [ "${bamboo_planRepository_revision}" != "" ];
-then
-  say "$e==>$x Bamboo detected"
-  # https://confluence.atlassian.com/bamboo/bamboo-variables-289277087.html#Bamboovariables-Build-specificvariables
-  service="bamboo"
-  commit="${bamboo_planRepository_revision}"
-  branch="${bamboo_planRepository_branch}"
-  build="${bamboo_buildNumber}"
-  build_url="${bamboo_buildResultsUrl}"
-  remote_addr="${bamboo_planRepository_repositoryUrl}"
-elif [ "$CI" = "true" ] && [ "$BITRISE_IO" = "true" ];
-then
-  # http://devcenter.bitrise.io/faq/available-environment-variables/
-  say "$e==>$x Bitrise CI detected."
-  service="bitrise"
-  branch="$BITRISE_GIT_BRANCH"
-  build="$BITRISE_BUILD_NUMBER"
-  build_url=$(urlencode "$BITRISE_BUILD_URL")
-  pr="$BITRISE_PULL_REQUEST"
-  if [ "$GIT_CLONE_COMMIT_HASH" != "" ];
-  then
-    commit="$GIT_CLONE_COMMIT_HASH"
-  fi
-elif [ "$CI" = "true" ] && [ "$SEMAPHORE" = "true" ];
-then
-  say "$e==>$x Semaphore CI detected."
-  # https://semaphoreapp.com/docs/available-environment-variables.html
-  service="semaphore"
-  build="$SEMAPHORE_BUILD_NUMBER"
-  job="$SEMAPHORE_CURRENT_THREAD"
-  pr="$PULL_REQUEST_NUMBER"
-  slug="$SEMAPHORE_REPO_SLUG"
-  commit="$REVISION"
-  env="$env,SEMAPHORE_TRIGGER_SOURCE"
-elif [ "$CI" = "true" ] && [ "$BUILDKITE" = "true" ];
-then
-  say "$e==>$x Buildkite CI detected."
-  # https://buildkite.com/docs/guides/environment-variables
-  service="buildkite"
-  branch="$BUILDKITE_BRANCH"
-  build="$BUILDKITE_BUILD_NUMBER"
-  job="$BUILDKITE_JOB_ID"
-  build_url=$(urlencode "$BUILDKITE_BUILD_URL")
-  slug="$BUILDKITE_PROJECT_SLUG"
-  commit="$BUILDKITE_COMMIT"
-  if [[ "$BUILDKITE_PULL_REQUEST" != "false" ]]; then
-    pr="$BUILDKITE_PULL_REQUEST"
-  fi
-  tag="$BUILDKITE_TAG"
-elif [ "$CI" = "drone" ];
-then
-  say "$e==>$x Drone CI detected."
-  # http://docs.drone.io/env.html
-  # drone commits are not full shas
-  service="drone.io"
-  branch="$DRONE_BRANCH"
-  build="$DRONE_BUILD_NUMBER"
-  build_url=$(urlencode "${DRONE_BUILD_LINK}")
-  pr="$DRONE_PULL_REQUEST"
-  job="$DRONE_JOB_NUMBER"
-  tag="$DRONE_TAG"
-elif [ "$HEROKU_TEST_RUN_BRANCH" != "" ];
-then
-  say "$e==>$x Heroku CI detected."
-  # https://devcenter.heroku.com/articles/heroku-ci#environment-variables
-  service="heroku"
-  branch="$HEROKU_TEST_RUN_BRANCH"
-  build="$HEROKU_TEST_RUN_ID"
-elif [ "$CI" = "True" ] && [ "$APPVEYOR" = "True" ];
-then
-  say "$e==>$x Appveyor CI detected."
-  # http://www.appveyor.com/docs/environment-variables
-  service="appveyor"
-  branch="$APPVEYOR_REPO_BRANCH"
-  build=$(urlencode "$APPVEYOR_JOB_ID")
-  pr="$APPVEYOR_PULL_REQUEST_NUMBER"
-  job="$APPVEYOR_ACCOUNT_NAME%2F$APPVEYOR_PROJECT_SLUG%2F$APPVEYOR_BUILD_VERSION"
-  slug="$APPVEYOR_REPO_NAME"
-  commit="$APPVEYOR_REPO_COMMIT"
-elif [ "$CI" = "true" ] && [ "$WERCKER_GIT_BRANCH" != "" ];
-then
-  say "$e==>$x Wercker CI detected."
-  # http://devcenter.wercker.com/articles/steps/variables.html
-  service="wercker"
-  branch="$WERCKER_GIT_BRANCH"
-  build="$WERCKER_MAIN_PIPELINE_STARTED"
-  slug="$WERCKER_GIT_OWNER/$WERCKER_GIT_REPOSITORY"
-  commit="$WERCKER_GIT_COMMIT"
-elif [ "$CI" = "true" ] && [ "$MAGNUM" = "true" ];
-then
-  say "$e==>$x Magnum CI detected."
-  # https://magnum-ci.com/docs/environment
-  service="magnum"
-  commit="$CI_COMMIT"
-elif [ "$SHIPPABLE" = "true" ];
-then
-  say "$e==>$x Shippable CI detected."
-  # http://docs.shippable.com/ci_configure/
-  service="shippable"
-  branch=$([ "$HEAD_BRANCH" != "" ] && echo "$HEAD_BRANCH" || echo "$BRANCH")
-  pr="$PULL_REQUEST"
-  slug="$REPO_FULL_NAME"
-  commit="$COMMIT"
-elif [ "$TDDIUM" = "true" ];
-then
-  say "Solano CI detected."
-  # http://docs.solanolabs.com/Setup/tddium-set-environment-variables/
-  service="solano"
-  commit="$TDDIUM_CURRENT_COMMIT"
-  branch="$TDDIUM_CURRENT_BRANCH"
-  build="$TDDIUM_TID"
-  pr="$TDDIUM_PR_ID"
-elif [ "$GREENHOUSE" = "true" ];
-then
-  say "$e==>$x Greenhouse CI detected."
-  # http://docs.greenhouseci.com/docs/environment-variables-files
-  service="greenhouse"
-  branch="$GREENHOUSE_BRANCH"
-  build="$GREENHOUSE_BUILD_NUMBER"
-  build_url=$(urlencode "$GREENHOUSE_BUILD_URL")
-  pr="$GREENHOUSE_PULL_REQUEST"
-  commit="$GREENHOUSE_COMMIT"
-  search_in="$search_in $GREENHOUSE_EXPORT_DIR"
-elif [ "$GITLAB_CI" != "" ];
-then
-  say "$e==>$x GitLab CI detected."
-  # http://doc.gitlab.com/ce/ci/variables/README.html
-  service="gitlab"
-  branch="${CI_BUILD_REF_NAME:-$CI_COMMIT_REF_NAME}"
-  build="${CI_BUILD_ID:-$CI_JOB_ID}"
-  remote_addr="${CI_BUILD_REPO:-$CI_REPOSITORY_URL}"
-  commit="${CI_BUILD_REF:-$CI_COMMIT_SHA}"
-else
-  say "${r}x>${x} No CI provider detected."
-  say "    Testing inside Docker? ${b}http://docs.codecov.io/docs/testing-with-docker${x}"
-  say "    Testing with Tox? ${b}https://docs.codecov.io/docs/python#section-testing-with-tox${x}"
-fi
-say "    ${e}project root:${x} $git_root"
-# find branch, commit, repo from git command
-if [ "$GIT_BRANCH" != "" ];
-then
-elif [ "$branch" = "" ];
-then
-  branch=$(git rev-parse --abbrev-ref HEAD 2>/dev/null || hg branch 2>/dev/null || echo "")
-  if [ "$branch" = "HEAD" ];
-  then
-    branch=""
-  fi
-fi
-if [ "$commit_o" = "" ];
-then
-  # merge commit -> actual commit
-  mc=
-  if [ -n "$pr" ] && [ "$pr" != false ];
-  then
-    mc=$(git show --no-patch --format="%P" 2>/dev/null || echo "")
-  fi
-  if [[ "$mc" =~ ^[a-z0-9]{40}[[:space:]][a-z0-9]{40}$ ]];
-  then
-    say "    Fixing merge commit SHA"
-    commit=$(echo "$mc" | cut -d' ' -f2)
-  then
-  elif [ "$commit" = "" ];
-  then
-    commit=$(git log -1 --format="%H" 2>/dev/null || hg id -i --debug 2>/dev/null | tr -d '+' || echo "")
-  fi
-else
-  commit="$commit_o"
-fi
-if [ "$CODECOV_TOKEN" != "" ] && [ "$token" = "" ];
-then
-  say "${e}-->${x} token set from env"
-  token="$CODECOV_TOKEN"
-fi
-if [ "$CODECOV_URL" != "" ] && [ "$url_o" = "" ];
-then
-  say "${e}-->${x} url set from env"
-  url_o=$(echo "$CODECOV_URL" | sed -e 's/\/$//')
-fi
-if [ "$CODECOV_SLUG" != "" ];
-then
-  say "${e}-->${x} slug set from env"
-  slug_o="$CODECOV_SLUG"
-elif [ "$slug" = "" ];
-then
-  if [ "$remote_addr" = "" ];
-  then
-    remote_addr=$(git config --get remote.origin.url || hg paths default || echo '')
-  fi
-  if [ "$remote_addr" != "" ];
-  then
-    if echo "$remote_addr" | grep -q "//"; then
-      # https
-      slug=$(echo "$remote_addr" | cut -d / -f 4,5 | sed -e 's/\.git$//')
-    else
-      # ssh
-      slug=$(echo "$remote_addr" | cut -d : -f 2 | sed -e 's/\.git$//')
-    fi
-  fi
-  if [ "$slug" = "/" ];
-  then
-    slug=""
-  fi
-fi
-yaml=$(test -n "$codecov_yml" && echo "$codecov_yml" \
-       || cd "$git_root" && \
-          git ls-files "*codecov.yml" "*codecov.yaml" 2>/dev/null \
-       || hg locate "*codecov.yml" "*codecov.yaml" 2>/dev/null \
-       || cd $proj_root && find . -type f -name '*codecov.y*ml' -depth 1 2>/dev/null \
-       || echo '')
-yaml=$(echo "$yaml" | head -1)
-if [ "$yaml" != "" ];
-then
-  say "    ${e}Yaml found at:${x} $yaml"
-  config=$(parse_yaml "$git_root/$yaml" || echo '')
-  # TODO validate the yaml here
-  if [ "$(echo "$config" | grep 'codecov_token="')" != "" ] && [ "$token" = "" ];
-  then
-    say "${e}-->${x} token set from yaml"
-    token="$(echo "$config" | grep 'codecov_token="' | sed -e 's/codecov_token="//' | sed -e 's/"\.*//')"
-  fi
-  if [ "$(echo "$config" | grep 'codecov_url="')" != "" ] && [ "$url_o" = "" ];
-  then
-    say "${e}-->${x} url set from yaml"
-    url_o="$(echo "$config" | grep 'codecov_url="' | sed -e 's/codecov_url="//' | sed -e 's/"\.*//')"
-  fi
-  if [ "$(echo "$config" | grep 'codecov_slug="')" != "" ] && [ "$slug_o" = "" ];
-  then
-    say "${e}-->${x} slug set from yaml"
-    slug_o="$(echo "$config" | grep 'codecov_slug="' | sed -e 's/codecov_slug="//' | sed -e 's/"\.*//')"
-  fi
-else
-  say "    ${g}Yaml not found, that's ok! Learn more at${x} ${b}http://docs.codecov.io/docs/codecov-yaml${x}"
-fi
-if [ "$branch_o" != "" ];
-then
-  branch=$(urlencode "$branch_o")
-else
-  branch=$(urlencode "$branch")
-fi
-query="branch=$branch\
-       &commit=$commit\
-       &build=$([ "$build_o" = "" ] && echo "$build" || echo "$build_o")\
-       &build_url=$build_url\
-       &name=$(urlencode "$name")\
-       &tag=$([ "$tag_o" = "" ] && echo "$tag" || echo "$tag_o")\
-       &slug=$([ "$slug_o" = "" ] && urlencode "$slug" || urlencode "$slug_o")\
-       &service=$service\
-       &flags=$flags\
-       &pr=$([ "$pr_o" = "" ] && echo "${pr##\#}" || echo "${pr_o##\#}")\
-       &job=$job"
-if [ "$ft_search" = "1" ];
-then
-  # detect bower comoponents location
-  bower_components="bower_components"
-  bower_rc=$(cd "$git_root" && cat .bowerrc 2>/dev/null || echo "")
-  if [ "$bower_rc" != "" ];
-  then
-    bower_components=$(echo "$bower_rc" | tr -d '\n' | grep '"directory"' | cut -d'"' -f4 | sed -e 's/\/$//')
-    if [ "$bower_components" = "" ];
-    then
-    fi
-  fi
-  # Swift Coverage
-  if [ "$ft_xcodellvm" = "1" ] && [ -d "$ddp" ];
-  then
-    say "${e}==>${x} Processing Xcode reports via llvm-cov"
-    say "    DerivedData folder: $ddp"
-    profdata_files=$(find "$ddp" -name '*.profdata' 2>/dev/null || echo '')
-    if [ "$profdata_files" != "" ];
-    then
-      # xcode via profdata
-      then
-        # xp=$(xcodebuild -showBuildSettings 2>/dev/null | grep -i "^\s*PRODUCT_NAME" | sed -e 's/.*= \(.*\)/\1/')
-        # say " ${e}->${x} Speed up Xcode processing by adding ${e}-J '$xp'${x}"
-        say "    ${g}hint${x} Speed up Swift processing by using use ${g}-J 'AppName'${x} (regexp accepted)"
-        say "    ${g}hint${x} This will remove Pods/ from your report. Also ${b}https://docs.codecov.io/docs/ignoring-paths${x}"
-      fi
-      while read -r profdata;
-      do
-        if [ "$profdata" != "" ];
-        then
-          swiftcov "$profdata" "$xp"
-        fi
-      done <<< "$profdata_files"
-    else
-      say "    ${e}->${x} No Swift coverage found"
-    fi
-    # Obj-C Gcov Coverage
-    if [ "$ft_gcov" = "1" ];
-    then
-      say "    ${e}->${x} Running $gcov_exe for Obj-C"
-      bash -c "find $ddp -type f -name '*.gcda' $gcov_include $gcov_ignore -exec $gcov_exe -p $gcov_arg {} +" || true
-    fi
-  fi
-  if [ "$ft_xcodeplist" = "1" ] && [ -d "$ddp" ];
-  then
-    say "${e}==>${x} Processing Xcode plists"
-    plists_files=$(find "$ddp" -name '*.xccoverage' 2>/dev/null || echo '')
-    if [ "$plists_files" != "" ];
-    then
-      while read -r plist;
-      do
-        if [ "$plist" != "" ];
-        then
-          say "    ${g}Found${x} plist file at $plist"
-          plutil -convert xml1 -o "$(basename "$plist").plist" -- $plist
-        fi
-      done <<< "$plists_files"
-    fi
-  fi
-  # Gcov Coverage
-  then
-    say "${e}==>${x} Running gcov in $proj_root ${e}(disable via -X gcov)${x}"
-    bash -c "find $proj_root -type f -name '*.gcno' $gcov_include $gcov_ignore -execdir $gcov_exe -pb $gcov_arg {} +" || true
-  else
-    say "${e}==>${x} gcov disabled"
-  fi
-  # Python Coverage
-  if [ "$ft_coveragepy" = "1" ];
-  then
-    if [ ! -f coverage.xml ];
-    then
-      if which coverage >/dev/null 2>&1;
-      then
-        say "${e}==>${x} Python coveragepy exists ${e}disable via -X coveragepy${x}"
-        dotcoverage=$(find "$git_root" -name '.coverage' -or -name '.coverage.*' | head -1 || echo '')
-        if [ "$dotcoverage" != "" ];
-        then
-          cd "$(dirname "$dotcoverage")"
-          if [ ! -f .coverage ];
-          then
-            say "    ${e}->${x} Running coverage combine"
-            coverage combine -a
-          fi
-          say "    ${e}->${x} Running coverage xml"
-          if [ "$(coverage xml -i)" != "No data to report." ];
-          then
-            files="$files
-$PWD/coverage.xml"
-          else
-            say "    ${r}No data to report.${x}"
-          fi
-          cd "$proj_root"
-        else
-          say "    ${r}No .coverage file found.${x}"
-        fi
-      else
-        say "${e}==>${x} Python coveragepy not found"
-      fi
-    fi
-  else
-    say "${e}==>${x} Python coveragepy disabled"
-  fi
-  if [ "$search_in_o" != "" ];
-  then
-    # location override
-    search_in="$search_in_o"
-  fi
-  say "$e==>$x Searching for coverage reports in:"
-  for _path in $search_in
-  do
-    say "    ${g}+${x} $_path"
-  done
-  patterns="find $search_in \( \
-                        -name vendor \
-                        -or -name htmlcov \
-                        -or -name virtualenv \
-                        -or -name js/generated/coverage \
-                        -or -name .virtualenv \
-                        -or -name virtualenvs \
-                        -or -name .virtualenvs \
-                        -or -name .env \
-                        -or -name .envs \
-                        -or -name env \
-                        -or -name .yarn-cache \
-                        -or -name envs \
-                        -or -name .venv \
-                        -or -name .venvs \
-                        -or -name venv \
-                        -or -name venvs \
-                        -or -name .git \
-                        -or -name .hg \
-                        -or -name .tox \
-                        -or -name __pycache__ \
-                        -or -name '.egg-info*' \
-                        -or -name '$bower_components' \
-                        -or -name node_modules \
-                        -or -name 'conftest_*.c.gcov' \
-                    \) -prune -or \
-                    -type f \( -name '*coverage*.*' \
-                     -or -name 'nosetests.xml' \
-                     -or -name 'jacoco*.xml' \
-                     -or -name 'clover.xml' \
-                     -or -name 'report.xml' \
-                     -or -name '*.codecov.*' \
-                     -or -name 'codecov.*' \
-                     -or -name 'cobertura.xml' \
-                     -or -name 'excoveralls.json' \
-                     -or -name 'luacov.report.out' \
-                     -or -name 'coverage-final.json' \
-                     -or -name 'naxsi.info' \
-                     -or -name 'lcov.info' \
-                     -or -name 'lcov.dat' \
-                     -or -name '*.lcov' \
-                     -or -name '*.clover' \
-                     -or -name 'cover.out' \
-                     -or -name 'gcov.info' \
-                     -or -name '*.gcov' \
-                     -or -name '*.lst' \
-                     $include_cov \) \
-                    $exclude_cov \
-                    -not -name '*.profdata' \
-                    -not -name 'coverage-summary.json' \
-                    -not -name 'phpunit-code-coverage.xml' \
-                    -not -name '*/classycle/report.xml' \
-                    -not -name 'remapInstanbul.coverage*.json' \
-                    -not -name 'phpunit-coverage.xml' \
-                    -not -name '*codecov.yml' \
-                    -not -name '*.serialized' \
-                    -not -name '.coverage*' \
-                    -not -name '.*coveragerc' \
-                    -not -name '*.sh' \
-                    -not -name '*.bat' \
-                    -not -name '*.ps1' \
-                    -not -name '*.env' \
-                    -not -name '*.cmake' \
-                    -not -name '*.dox' \
-                    -not -name '*.ec' \
-                    -not -name '*.rst' \
-                    -not -name '*.h' \
-                    -not -name '*.scss' \
-                    -not -name '*.o' \
-                    -not -name '*.proto' \
-                    -not -name '*.sbt' \
-                    -not -name '*.xcoverage.*' \
-                    -not -name '*.gz' \
-                    -not -name '*.conf' \
-                    -not -name '*.p12' \
-                    -not -name '*.csv' \
-                    -not -name '*.rsp' \
-                    -not -name '*.m4' \
-                    -not -name '*.pem' \
-                    -not -name '*~' \
-                    -not -name '*.exe' \
-                    -not -name '*.am' \
-                    -not -name '*.template' \
-                    -not -name '*.cp' \
-                    -not -name '*.bw' \
-                    -not -name '*.crt' \
-                    -not -name '*.log' \
-                    -not -name '*.pth' \
-                    -not -name '*.in' \
-                    -not -name '*.jar*' \
-                    -not -name '*.pom*' \
-                    -not -name '*.png' \
-                    -not -name '*.jpg' \
-                    -not -name '*.sql' \
-                    -not -name '*.jpeg' \
-                    -not -name '*.svg' \
-                    -not -name '*.gif' \
-                    -not -name '*.snapshot' \
-                    -not -name '*.mak*' \
-                    -not -name '*.bash' \
-                    -not -name '*.data' \
-                    -not -name '*.py' \
-                    -not -name '*.class' \
-                    -not -name '*.xcconfig' \
-                    -not -name '*.coverage' \
-                    -not -name '*.pyc' \
-                    -not -name '*.cfg' \
-                    -not -name '*.egg' \
-                    -not -name '*.ru' \
-                    -not -name '*.css' \
-                    -not -name '*.less' \
-                    -not -name '*.pyo' \
-                    -not -name '*.whl' \
-                    -not -name '*.html' \
-                    -not -name '*.ftl' \
-                    -not -name '*.erb' \
-                    -not -name '*.rb' \
-                    -not -name '*.js' \
-                    -not -name '*.jade' \
-                    -not -name '*.db' \
-                    -not -name '*.md' \
-                    -not -name '*.cpp' \
-                    -not -name '*.gradle' \
-                    -not -name '*.tar.tz' \
-                    -not -name 'include.lst' \
-                    -not -name 'fullLocaleNames.lst' \
-                    -not -name 'inputFiles.lst' \
-                    -not -name 'createdFiles.lst' \
-                    -not -name 'scoverage.measurements.*' \
-                    -not -name 'test_*_coverage.txt' \
-                    -not -name 'testrunner-coverage*' \
-                    -print 2>/dev/null"
-  files=$(eval "$patterns" || echo '')
-elif [ "$include_cov" != "" ];
-then
-  files=$(eval "find $search_in -type f \( ${include_cov:5} \)$exclude_cov 2>/dev/null" || echo '')
-fi
-num_of_files=$(echo "$files" | wc -l | tr -d ' ')
-if [ "$num_of_files" != '' ] && [ "$files" != '' ];
-then
-  say "    ${e}->${x} Found $num_of_files reports"
-fi
-# no files found
-if [ "$files" = "" ];
-then
-  say "${r}-->${x} No coverage report found."
-  say "    Please visit ${b}http://docs.codecov.io/docs/supported-languages${x}"
-  exit ${exit_with};
-fi
-if [ "$ft_network" == "1" ];
-then
-  say "${e}==>${x} Detecting git/mercurial file structure"
-  network=$(cd "$git_root" && git ls-files 2>/dev/null || hg locate 2>/dev/null || echo "")
-  if [ "$network" = "" ];
-  then
-    network=$(find "$git_root" \( \
-                   -name virtualenv \
-                   -name .virtualenv \
-                   -name virtualenvs \
-                   -name .virtualenvs \
-                   -name '*.png' \
-                   -name '*.gif' \
-                   -name '*.jpg' \
-                   -name '*.jpeg' \
-                   -name '*.md' \
-                   -name .env \
-                   -name .envs \
-                   -name env \
-                   -name envs \
-                   -name .venv \
-                   -name .venvs \
-                   -name venv \
-                   -name venvs \
-                   -name .git \
-                   -name .egg-info \
-                   -name shunit2-2.1.6 \
-                   -name vendor \
-                   -name __pycache__ \
-                   -name node_modules \
-                   -path '*/$bower_components/*' \
-                   -path '*/target/delombok/*' \
-                   -path '*/build/lib/*' \
-                   -path '*/js/generated/coverage/*' \
-                    \) -prune -or \
-                    -type f -print 2>/dev/null || echo '')
-  fi
-  if [ "$prefix_o" != "" ];
-  then
-      network=$(echo "$network" | awk "{print \"$prefix_o/\"\$0}")
-  fi
-fi
-upload_file=`mktemp /tmp/codecov.XXXXXX`
-adjustments_file=`mktemp /tmp/codecov.adjustments.XXXXXX`
-cleanup() {
-    rm -f $upload_file $adjustments_file $upload_file.gz
-trap cleanup INT ABRT TERM
-if [ "$env" != "" ];
-then
-  inc_env=""
-  say "${e}==>${x} Appending build variables"
-  for varname in $(echo "$env" | tr ',' ' ')
-  do
-    if [ "$varname" != "" ];
-    then
-      say "    ${g}+${x} $varname"
-      inc_env="${inc_env}${varname}=$(eval echo "\$${varname}")
-    fi
-  done
-echo "$inc_env<<<<<< ENV" >> $upload_file
-fi
-# Append git file list
-# write discovered yaml location
-echo "$yaml" >> $upload_file
-then
-  i="woff|eot|otf"  # fonts
-  i="$i|gif|png|jpg|jpeg|psd"  # images
-  i="$i|ptt|pptx|numbers|pages|md|txt|xlsx|docx|doc|pdf|html|csv"  # docs
-  i="$i|yml|yaml|.gitignore"  # supporting docs
-  echo "$network" | grep -vwE "($i)$" >> $upload_file
-fi
-echo "<<<<<< network" >> $upload_file
-fr=0
-say "${e}==>${x} Reading reports"
-while IFS='' read -r file;
-do
-  # read the coverage file
-  if [ "$(echo "$file" | tr -d ' ')" != '' ];
-  then
-    if [ -f "$file" ];
-    then
-      report_len=$(wc -c < "$file")
-      if [ "$report_len" -ne 0 ];
-      then
-        say "    ${g}+${x} $file ${e}bytes=$(echo "$report_len" | tr -d ' ')${x}"
-        # append to to upload
-        _filename=$(basename "$file")
-        if [ "${_filename##*.}" = 'gcov' ];
-        then
-          echo "# path=$(echo "$file.reduced" | sed "s|^$git_root/||")" >> $upload_file
-          # get file name
-          head -1 $file >> $upload_file
-          # 1. remove source code
-          # 2. remove ending bracket lines
-          # 3. remove whitespace
-          # 4. remove contextual lines
-          # 5. remove function names
-          awk -F': *' '{print $1":"$2":"}' $file \
-            | sed '\/: *} *$/d' \
-            | sed 's/^ *//' \
-            | sed '/^-/d' \
-            | sed 's/^function.*/func/' >> $upload_file
-        else
-          echo "# path=$(echo "$file" | sed "s|^$git_root/||")" >> $upload_file
-          cat "$file" >> $upload_file
-        fi
-        echo "<<<<<< EOF" >> $upload_file
-        fr=1
-        if [ "$clean" = "1" ];
-        then
-          rm "$file"
-        fi
-      else
-        say "    ${r}-${x} Skipping empty file $file"
-      fi
-    else
-      say "    ${r}-${x} file not found at $file"
-    fi
-  fi
-done <<< "$(echo -e "$files")"
-if [ "$fr" = "0" ];
-then
-  say "${r}-->${x} No coverage data found."
-  say "    search for your projects language to learn how to collect reports."
-fi
-if [ "$ft_fix" = "1" ];
-then
-  say "${e}==>${x} Appending adjustments"
-  say "    ${b}http://docs.codecov.io/docs/fixing-reports${x}"
-  empty_line='^[[:space:]]*$'
-  syntax_comment='^[[:space:]]*//.*'
-  # /* or */
-  syntax_comment_block='^[[:space:]]*(\/\*|\*\/)[[:space:]]*$'
-  # { or }
-  syntax_bracket='^[[:space:]]*[\{\}][[:space:]]*(//.*)?$'
-  # [ or ]
-  syntax_list='^[[:space:]]*[][][[:space:]]*(//.*)?$'
-  skip_dirs="-not -path '*/$bower_components/*' \
-             -not -path '*/node_modules/*'"
-  cut_and_join() {
-    awk 'BEGIN { FS=":" }
-         $3 ~ /\/\*/ || $3 ~ /\*\// { print $0 ; next }
-         $1!=key { if (key!="") print out ; key=$1 ; out=$1":"$2 ; next }
-         { out=out","$2 }
-         END { print out }' 2>/dev/null
-  if echo "$network" | grep -m1 '.kt$' 1>/dev/null;
-  then
-    # skip brackets and comments
-    find "$git_root" -type f \
-                     -name '*.kt' \
-                     -exec \
-      grep -nIHE -e $syntax_bracket \
-                 -e $syntax_comment_block {} \; \
-      | cut_and_join \
-      >> $adjustments_file \
-      || echo ''
-    # last line in file
-                     -name '*.kt' -exec \
-      wc -l {} \; \
-      | while read l; do echo "EOF: $l"; done \
-      2>/dev/null \
-      || echo ''
-  fi
-  if echo "$network" | grep -m1 '.go$' 1>/dev/null;
-  then
-    # skip empty lines, comments, and brackets
-    find "$git_root" -not -path '*/vendor/*' \
-                     -type f \
-                     -name '*.go' \
-                     -exec \
-      grep -nIHE \
-           -e $empty_line \
-           -e $syntax_comment \
-           -e $syntax_comment_block \
-           -e $syntax_bracket \
-      | cut_and_join \
-      || echo ''
-  fi
-  if echo "$network" | grep -m1 '.dart$' 1>/dev/null;
-  then
-    # skip brackets
-                     -name '*.dart' \
-                     -exec \
-      grep -nIHE \
-      | cut_and_join \
-      || echo ''
-  fi
-  if echo "$network" | grep -m1 '.php$' 1>/dev/null;
-  then
-    find "$git_root" -not -path "*/vendor/*" \
-                     -type f \
-                     -name '*.php' \
-                     -exec \
-      grep -nIHE \
-           -e $syntax_list \
-           -e '^[[:space:]]*\);[[:space:]]*(//.*)?$' \
-      | cut_and_join \
-      || echo ''
-  fi
-  if echo "$network" | grep -m1 '\(.cpp\|.h\|.cxx\|.c\|.hpp\|.m\)$' 1>/dev/null;
-  then
-    # skip brackets
-                     $skip_dirs \
-           -name '*.h' \
-           -or -name '*.cpp' \
-           -or -name '*.cxx' \
-           -or -name '*.m' \
-           -or -name '*.c' \
-           -or -name '*.hpp' \
-         \) -exec \
-      grep -nIHE \
-           -e $empty_line \
-           -e '// LCOV_EXCL' \
-      | cut_and_join \
-      || echo ''
-    # skip brackets
-                     $skip_dirs \
-           -name '*.h' \
-           -or -name '*.m' \
-           -or -name '*.c' \
-         \) -exec \
-      grep -nIH '// LCOV_EXCL' \
-      || echo ''
-  fi
-  found=$(cat $adjustments_file | tr -d ' ')
-  if [ "$found" != "" ];
-  then
-    say "    ${g}+${x} Found adjustments"
-    echo "# path=fixes" >> $upload_file
-    cat $adjustments_file >> $upload_file
-    rm -rf $adjustments_file
-  else
-    say "    ${e}->${x} No adjustments found"
-  fi
-fi
-if [ "$url_o" != "" ];
-then
-  url="$url_o"
-fi
-if [ "$dump" != "0" ];
-then
-  # trim whitespace from query
-  say "    ${e}->${x} Dumping upload file (no upload)"
-  echo "$url/upload/v4?$(echo "package=bash-$VERSION&token=$token&$query" | tr -d ' ')"
-  cat $upload_file
-else
-  say "${e}==>${x} Gzipping contents"
-  gzip -nf9 $upload_file
-  query=$(echo "${query}" | tr -d ' ')
-  say "${e}==>${x} Uploading reports"
-  say "    ${e}url:${x} $url"
-  say "    ${e}query:${x} $query"
-  # now add token to query
-  query=$(echo "package=bash-$VERSION&token=$token&$query" | tr -d ' ')
-  if [ "$ft_s3" = "1" ];
-  then
-    i="0"
-    while [ $i -lt 4 ]
-    do
-      i=$[$i+1]
-      say "    ${e}->${x} Pinging Codecov"
-      res=$(curl $curl_s -X POST $curlargs $cacert \
-            -H 'X-Reduced-Redundancy: false' \
-            -H 'X-Content-Type: application/x-gzip' \
-            "$url/upload/v4?$query" || true)
-      # a good replay is "https://codecov.io" + "\n" + "https://codecov.s3.amazonaws.com/..."
-      status=$(echo "$res" | head -1 | grep 'HTTP ' | cut -d' ' -f2)
-      if [ "$status" = "" ];
-      then
-        s3target=$(echo "$res" | sed -n 2p)
-        say "    ${e}->${x} Uploading"
-        s3=$(curl $curl_s -fiX PUT $curlawsargs \
-                  --data-binary @$upload_file.gz \
-                  -H 'Content-Type: application/x-gzip' \
-                  -H 'Content-Encoding: gzip' \
-                  -H 'x-amz-acl: public-read' \
-                  "$s3target" || true)
-        if [ "$s3" != "" ];
-        then
-          say "    ${g}->${x} View reports at ${b}$(echo "$res" | sed -n 1p)${x}"
-          exit 0
-        else
-          say "    ${r}X>${x} Failed to upload"
-        fi
-      elif [ "$status" = "400" ];
-      then
-          # 400 Error
-          say "${g}${res}${x}"
-          exit ${exit_with}
-      fi
-      say "    ${e}->${x} Sleeping for 30s and trying again..."
-      sleep 30
-    done
-  fi
-  say "    ${e}->${x} Uploading to Codecov"
-  i="0"
-  do
-    i=$[$i+1]
-          -H 'Content-Type: text/plain' \
-          -H 'X-Content-Encoding: gzip' \
-          -H 'Accept: text/plain' \
-          "$url/upload/v2?$query" || echo 'HTTP 500')
-    # HTTP 200
-    # http://....
-    status=$(echo "$res" | head -1 | cut -d' ' -f2)
-    then
-      say "    View reports at ${b}$(echo "$res" | head -2 | tail -1)${x}"
-      exit 0
-    elif [ "${status:0:1}" = "5" ];
-    then
-      sleep 30
-    else
-      say "    ${g}${res}${x}"
-      exit 0
-      exit ${exit_with}
-    fi
-  done
-  say "    ${r}X> Failed to upload coverage reports${x}"
-fi
-exit ${exit_with}
Modified: trunk/ci/travis/run_coverage.sh
--- trunk/ci/travis/run_coverage.sh	2019-01-30 19:17:05 UTC (rev 17221)
+++ trunk/ci/travis/run_coverage.sh	2019-01-30 19:36:30 UTC (rev 17222)
@@ -9,4 +9,5 @@
 ./autogen.sh
 ./configure CFLAGS="${CFLAGS_COV}" LDFLAGS="${LDFLAGS_COV}" --enable-debug
 make -j check
+curl -S -f https://codecov.io/bash -o .github/codecov.bash
 bash .github/codecov.bash
