[postgis-tickets] [PostGIS] #4408: can't compile --with-wagyu under mingw64
PostGIS trac at osgeo.org
Sat Jun 1 12:11:01 PDT 2019
  Reporter:  robe     |      Owner:  Algunenano
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 3.0.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Comment (by robe):
 I vaguely remember having this issue before and I think it had to do with
 the order of libs in SHLIB.  I see you have WAYGU lib in front.  I'm
 experimenting to moving it to the end to see if that fixes the issue.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4408#comment:10>
