[postgis-tickets] r17457 - Prepping for PostGIS 3.0.0alpha2 release
Regina Obe
lr at pcorp.us
Sat Jun 1 07:19:51 PDT 2019
Author: robe
Date: 2019-06-01 19:19:51 -0700 (Sat, 01 Jun 2019)
New Revision: 17457
trunk/ChangeLog
trunk/NEWS
trunk/README.postgis
trunk/Version.config
trunk/doc/release_notes.xml
Modified: trunk/ChangeLog
--- trunk/ChangeLog 2019-06-02 01:21:03 UTC (rev 17456)
+++ trunk/ChangeLog 2019-06-02 02:19:51 UTC (rev 17457)
@@ -1,3 +1,99 @@
+2019-06-01 17:32 Darafei Praliaskouski <me at komzpa.net>
+ * [r17455] doc/reference_output.xml: [doc] ST_AsGeoJSON
+ FeatureCollection example
+2019-06-01 16:24 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17454] ci/travis/run_nowagyu.sh: Add removed file
+2019-06-01 13:02 Darafei Praliaskouski <me at komzpa.net>
+ * [r17453] postgis/postgis.sql.in: Make upgrade finish notification
+ copy-paste friendly.
+2019-06-01 02:10 Regina Obe <lr at pcorp.us>
+ * [r17452] ci/bessie/postgis_regress.sh,
+ ci/bessie32/postgis_regress.sh, ci/debbie/postgis_regress.sh,
+ ci/winnie/build_postgis.sh, ci/winnie/regress_postgis.sh: take
+ off --with-wagyu on buildbots now that's the default no longer
+ necessary
+ Revise winnie's builds to use pkgconfig where available instead
+ of the --with-<something>=path commands
+2019-06-01 01:29 Regina Obe <lr at pcorp.us>
+ * [r17451] .travis.yml, NEWS, ci/travis/run_wagyu.sh, configure.ac,
+ doc/installation.xml: Make build with wagyu the default when
+ protobuf is also enabled
+ Closes https://github.com/postgis/postgis/pull/406
+2019-05-31 21:37 Regina Obe <lr at pcorp.us>
+ * [r17450] ci/bessie32/postgis_regress.sh,
+ ci/winnie/regress_postgis.sh: reorder wagyu line in bessie
+ regress
+ configure winnie to test with wagyu to better troubleshoot issue
+ References #4408
+2019-05-31 20:01 Regina Obe <lr at pcorp.us>
+ * [r17449] ci/bessie/postgis_regress.sh,
+ ci/bessie32/postgis_regress.sh, ci/debbie/postgis_regress.sh:
+ Change bessies and debbie to build with wagyu
+ For testing what happens when wagyu becomes the default
+ References https://github.com/postgis/postgis/pull/406
+2019-05-31 19:59 Darafei Praliaskouski <me at komzpa.net>
+ * [r17448] NEWS, doc/html/image_src/Makefile.in,
+ doc/html/image_src/st_constraineddelaunaytriangles01.wkt,
+ doc/html/image_src/st_constraineddelaunaytriangles02.wkt,
+ doc/html/image_src/styles.conf, doc/reference_processing.xml,
+ doc/reference_sfcgal.xml, postgis/lwgeom_sfcgal.c,
+ postgis/sfcgal.sql.in, regress/sfcgal/regress_sfcgal.sql,
+ regress/sfcgal/regress_sfcgal_expected: [sfcgal] Expose
+ ST_ConstrainedDelaunayTriangles
+ Closes #4198
+ Closes https://github.com/postgis/postgis/pull/405
+2019-05-29 13:57 Sandro Santilli <strk at kbt.io>
+ * [r17447] configure.ac: Update GEOS recommendation to 3.7.0
+ Doesn't make sense to recommend 3.6 if it takes 3.7 to use all
+ features of PostGIS...
+2019-05-27 21:28 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r17446] postgis/geography_centroid.c, postgis/geography_inout.c,
+ postgis/gserialized_estimate.c, postgis/gserialized_supportfn.c:
+ Fix selectivity issue with support functions, wherein... default
+ selectivities were the only thing we were returning.
+ Closes #4404
+2019-05-26 20:51 Regina Obe <lr at pcorp.us>
+ * [r17445] Version.config, extensions/upgradeable_versions.mk: Flip
+ version to alpha2dev (hopefully we won't need another alpha), but
+ just in case
+2019-05-26 11:37 Regina Obe <lr at pcorp.us>
+ * [r17443] doc/release_notes.xml: put in date
+2019-05-26 01:02 Regina Obe <lr at pcorp.us>
+ * [r17442] ChangeLog, NEWS, Version.config, doc/release_notes.xml,
+ extensions/upgradeable_versions.mk: Prep for 3.0.0alpha1 release
+2019-05-26 00:59 Regina Obe <lr at pcorp.us>
+ * [r17441] extras/tiger_geocoder/tiger_loader_2018.sql: schema
+ qualify usage
2019-05-21 23:56 Martin Davis <mtnclimb at gmail.com>
* [r17440] doc/reference_processing.xml: Improve ST_ConvexHull doc
Modified: trunk/NEWS
--- trunk/NEWS 2019-06-02 01:21:03 UTC (rev 17456)
+++ trunk/NEWS 2019-06-02 02:19:51 UTC (rev 17457)
@@ -1,5 +1,5 @@
PostGIS 3.0.0alpha2
-2019/XX/XX
+2019/06/02
For full changes and enhancements, refer to PostGIS 3.0.0 section.
This version requires PostgreSQL 9.5+-12 and GEOS >= 3.6+
@@ -9,10 +9,12 @@
- #4404, Fix selectivity issue with support functions (Paul Ramsey)
- #4311, Make wagyu the default option to validate polygons.
This option requires a C++11 compiler and will use CXXFLAGS (not CFLAGS).
+ It only enabled if built with MVT support (protobuf)
Add `--without-wagyu` to disable this option and keep the behaviour
from 2.5 (Raúl Marín)
+ - #4198, Add ST_ConstrainedDelaunayTriangles SFCGAL function (Darafei
+ Praliaskouski)
PostGIS 3.0.0alpha1
2019/05/26
Modified: trunk/README.postgis
--- trunk/README.postgis 2019-06-02 01:21:03 UTC (rev 17456)
+++ trunk/README.postgis 2019-06-02 02:19:51 UTC (rev 17457)
@@ -1,9 +1,9 @@
PostGIS - Geographic Information Systems Extensions to PostgreSQL
-:Version: 2.5.0rc1
-:Date: 2018-08-19
-:Website: http://postgis.net
+:Version: 3.0.0alpah2
+:Date: 2019-06-02
+:Website: https://postgis.net
This distribution contains a module which implements GIS simple features, ties
the features to R-tree indexing, and provides many spatial functions for
@@ -12,10 +12,12 @@
Directory structure::
./ Build scripts and install directions
+ ./deps Extra dependencies (currently only mapbox wagyu)
./doc PostGIS Documentation
./extensions Support for the PostgreSQL Extensions framework
./extras Various pieces that didn't belong to mainstream
- (package management specfiles, WFS_locks, sample WKB parser)
+ (package management specfiles, WFS_locks
+ , sample WKB parser, postgis_tiger_geocoder)
./liblwgeom LWGEOM geometry library
./libpgcommon PostGIS library to bridge LWGEOM to PostgreSQL
./loader A program to convert ESRI Shape files into SQL text suitable
@@ -31,7 +33,7 @@
REQUIREMENTS
-PostGIS is compatible with PostgreSQL 9.4 and above.
+PostGIS is compatible with PostgreSQL 9.5 and above.
You *must* have the full PostgreSQL - including server headers - installed for
this to work.
Modified: trunk/Version.config
--- trunk/Version.config 2019-06-02 01:21:03 UTC (rev 17456)
+++ trunk/Version.config 2019-06-02 02:19:51 UTC (rev 17457)
@@ -5,7 +5,7 @@
POSTGIS_MAJOR_VERSION=3
POSTGIS_MINOR_VERSION=0
-POSTGIS_MICRO_VERSION=0alpha2dev
+POSTGIS_MICRO_VERSION=0alpha2
# Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
# when changing POSTGIS_MINOR_VERSION
Modified: trunk/doc/release_notes.xml
--- trunk/doc/release_notes.xml 2019-06-02 01:21:03 UTC (rev 17456)
+++ trunk/doc/release_notes.xml 2019-06-02 02:19:51 UTC (rev 17457)
@@ -3,6 +3,25 @@
<title>Appendix</title>
<subtitle>Release Notes</subtitle>
<sect1>
+ <title>Release 3.0.0alpha2</title>
+ <para>Release date: 2019/06/02</para>
+ <para>If compiling with PostgreSQL+JIT, LLVM >= 6 is required</para>
+ <para>Supported PostgreSQL versions for this release are:
+ PostgreSQL 9.5 - PostgreSQL 12
+ GEOS >= 3.6</para>
+ <simplesect>
+ <title>Major highlights</title>
+ <para>#4404, Fix selectivity issue with support functions (Paul Ramsey)</para>
+ <para>#4311, Make wagyu the default option to validate polygons.
+ This option requires a C++11 compiler and will use CXXFLAGS (not CFLAGS).
+ It is only enabled if built with MVT support (protobuf)
+ Add `--without-wagyu` to disable this option and keep the behaviour
+ from 2.5 (Raúl Marín)</para>
+ <para>#4198, Add ST_ConstrainedDelaunayTriangles SFCGAL function (Darafei
+ Praliaskouski)</para>
+ </simplesect>
+ </sect1>
+ <sect1>
<title>Release 3.0.0alpha1</title>
<para>Release date: 2019/05/26</para>
