[postgis-tickets] r17460 - Disable wagyu for dist building -- might be unrelated (or result of some other library upgrade when installing mvt stuff) but seems debbie's doc building started failing after she started building with wagyu
Regina Obe
lr at pcorp.us
Sat Jun 1 08:35:09 PDT 2019
Author: robe
Date: 2019-06-01 20:35:09 -0700 (Sat, 01 Jun 2019)
New Revision: 17460
trunk/ci/debbie/postgis_doc_translations.sh
trunk/ci/debbie/postgis_make_dist.sh
trunk/ci/debbie/postgis_release_docs.sh
Modified: trunk/ci/debbie/postgis_doc_translations.sh
--- trunk/ci/debbie/postgis_doc_translations.sh 2019-06-02 02:35:12 UTC (rev 17459)
+++ trunk/ci/debbie/postgis_doc_translations.sh 2019-06-02 03:35:09 UTC (rev 17460)
@@ -36,7 +36,7 @@
LDFLAGS="-L${PGPATH}/lib" ./configure \
--with-pgconfig=${PGPATH}/bin/pg_config \
--with-geosconfig=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}/bin/geos-config \
- --without-raster
+ --without-raster --without-wagyu
make clean
cd doc
make update-pot
Modified: trunk/ci/debbie/postgis_make_dist.sh
--- trunk/ci/debbie/postgis_make_dist.sh 2019-06-02 02:35:12 UTC (rev 17459)
+++ trunk/ci/debbie/postgis_make_dist.sh 2019-06-02 03:35:09 UTC (rev 17460)
@@ -21,7 +21,7 @@
#export CONFIGURE_ARGS="--with-pgconfig=${PROJECTS}/pg/rel/pg${PG_VER}w${OS_BUILD}/bin/pg_config --with-geosconfig=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}/bin/geos-config --with-gdalconfig=${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}/bin/gdal-config --prefix=${PROJECTS}/pg/rel/pg${PG_VER}w${OS_BUILD}"
-export CONFIGURE_ARGS="--with-pgconfig=${PROJECTS}/pg/rel/pg${PG_VER}w${OS_BUILD}/bin/pg_config --with-geosconfig=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}/bin/geos-config --without-raster --prefix=${PROJECTS}/pg/rel/pg${PG_VER}w${OS_BUILD}"
+export CONFIGURE_ARGS="--with-pgconfig=${PROJECTS}/pg/rel/pg${PG_VER}w${OS_BUILD}/bin/pg_config --with-geosconfig=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}/bin/geos-config --without-raster --without-wagyu --prefix=${PROJECTS}/pg/rel/pg${PG_VER}w${OS_BUILD}"
#override the checkout folder used for building tar ball
export newoutdir="postgis-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}"
Modified: trunk/ci/debbie/postgis_release_docs.sh
--- trunk/ci/debbie/postgis_release_docs.sh 2019-06-02 02:35:12 UTC (rev 17459)
+++ trunk/ci/debbie/postgis_release_docs.sh 2019-06-02 03:35:09 UTC (rev 17460)
@@ -35,7 +35,7 @@
- --without-raster
make clean
# generating postgis_svn_revision.h in case hasn't been generated
