[postgis-tickets] [PostGIS] #4410: wagyu seems to break image building
trac at osgeo.org
Sat Jun 1 20:47:55 PDT 2019
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.0.0
Component: buildbots | Version: trunk
Keywords: |
I'm not sure why, but I think enabling wagyu broke debbie image building
and pdf building.
Just noticed it when I had no pdf generated for the alpha2 release.
to confirm that was the issue, I changed her dist scripts to --without-
wagyu at r17460
and she seems to be building now.
When wagyu was enabled, got this error:
https://debbie.postgis.net/job/PostGIS_Make_Dist/label=debbie/1034/console
23:06:23 lwin_geojson.c:36:10: fatal error: json.h: No such file or
directory
23:06:23 #include <json.h>
23:06:23 ^~~~~~~~
23:06:23 compilation terminated.
23:06:23 make[2]: *** [Makefile:199: lwin_geojson.lo] Error 1
23:06:23 make[2]: Leaving directory
'/var/lib/jenkins/workspace/PostGIS_Make_Dist/label/debbie/6a1a4284093100b6282298ba4cdd32799d9e68a0/liblwgeom'
23:06:23 make[1]: *** [Makefile:196: ../../../liblwgeom/.libs/liblwgeom.a]
Error 2
23:06:23 make[1]: Leaving directory
'/var/lib/jenkins/workspace/PostGIS_Make_Dist/label/debbie/6a1a4284093100b6282298ba4cdd32799d9e68a0/doc/html/image_src'
23:06:23 make: *** [Makefile:341: images] Error 2
23:06:23 /usr/bin/xsltproc --novalid ./xsl/postgis_aggs_mm.xml.xsl
postgis-out.xml > postgis_aggs_mm.xml
23:06:24 if test x"dbtoepub" = x; then \
23:06:24 echo "Error: dbtoepub not found, can't build epub"; \
23:06:24 echo " try installing dbtoepub"; \
23:06:24 false; \
23:06:24 else \
23:06:24 dbtoepub -c
"/var/lib/jenkins/workspace/PostGIS_Make_Dist/label/debbie/6a1a4284093100b6282298ba4cdd32799d9e68a0/doc/html/style.css"
23:06:24 -o postgis-3.0.0alpha2.epub \
23:06:24 postgis-out.xml; \
23:06:24 fi
23:07:49 /usr/lib/ruby/2.5.0/fileutils.rb:1291:in `initialize': No such
file or directory @ rb_sysopen -
/var/lib/jenkins/workspace/PostGIS_Make_Dist/label/debbie/6a1a4284093100b6282298ba4cdd32799d9e68a0/doc/images/st_issimple01.png
(Errno::ENOENT)
23:07:49 from /usr/lib/ruby/2.5.0/fileutils.rb:1291:in `open'
23:07:49 from /usr/lib/ruby/2.5.0/fileutils.rb:1291:in `copy_file'
23:07:49 from /usr/lib/ruby/2.5.0/fileutils.rb:432:in `copy_file'
23:07:49 from /usr/lib/ruby/2.5.0/fileutils.rb:359:in `block in cp'
23:07:49 from /usr/lib/ruby/2.5.0/fileutils.rb:1463:in `block in
fu_each_src_dest'
23:07:49 from /usr/lib/ruby/2.5.0/fileutils.rb:1479:in
`fu_each_src_dest0'
23:07:49 from /usr/lib/ruby/2.5.0/fileutils.rb:1461:in
`fu_each_src_dest'
23:07:49 from /usr/lib/ruby/2.5.0/fileutils.rb:358:in `cp'
23:07:49 from /usr/lib/ruby/vendor_ruby/dbtoepub/docbook.rb:190:in
`block in copy_images'
23:07:49 from /usr/lib/ruby/vendor_ruby/dbtoepub/docbook.rb:180:in
`each'
`copy_images'
23:07:49 from /usr/lib/ruby/vendor_ruby/dbtoepub/docbook.rb:112:in
`bundle_epub'
23:07:49 from /usr/lib/ruby/vendor_ruby/dbtoepub/docbook.rb:54:in
`render_to_file'
23:07:49 from /usr/bin/dbtoepub:72:in `block in <main>'
What's annoying is the run shows success, so it's not triggering a fail
when it should be. That another issue.
The make document scripts haven't been touched for a while, so maybe they
are using old syntax for enabling json.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4410>
