[postgis-tickets] r17464 - This should fix it.
Regina Obe
lr at pcorp.us
Sun Jun 2 11:43:18 PDT 2019
Author: robe
Date: 2019-06-02 11:43:17 -0700 (Sun, 02 Jun 2019)
New Revision: 17464
trunk/ci/winnie/build_postgis.sh
This should fix it.
Modified: trunk/ci/winnie/build_postgis.sh
--- trunk/ci/winnie/build_postgis.sh 2019-06-02 17:29:09 UTC (rev 17463)
+++ trunk/ci/winnie/build_postgis.sh 2019-06-02 18:43:17 UTC (rev 17464)
@@ -1,37 +1,25 @@
#!/bin/bash
set -e
-#### $Id:build_postgis210.sh 10208 2012-08-30 05:38:22Z robe $
-#all these get passed in by jenkins
-#export OS_BUILD=64
-#export PG_VER=9.2beta2
-#export PGHOST=localhost
-#export PGPORT=8442
-#export PGUSER=postgres
-#POSTGIS_SVN_REVISION=passed_in_by_buildbot
-#POSTGIS_MAJOR_VERSION=2
-#POSTGIS_MINOR_VERSION=1
-#POSTGIS_MICRO_VERSION=0SVN
-#export GCC_TYPE=gcc48 #for pre-4.8.0 compiles this is blank
export GEOS_VER=3.8
+export SFCGAL_VER=1.3.2
+export PCRE_VER=8.33
+export PROTOBUF_VER=3.2.0
+export PROTOBUFC_VER=1.2.1
+export CGAL_VER=4.11
+export LIBXML_VER=2.7.8
+#export GDAL_VER=2.4.0
export GDAL_VER=2.2.4
export PROJ_VER=4.9.3
+#export PROJ_VER=5.2.0
-export LIBXML_VER=2.7.8
+export ICON_VER=1.15
-if [[ "${GCC_TYPE}" == *gcc48* ]] ; then
- export PROJECTS=/projects
- export MINGPROJECTS=/projects
- export PATHOLD=$PATH
-else
- #export JSON_VER=0.9
-fi;
+export PROJECTS=/projects
+export MINGPROJECTS=/projects
@@ -41,20 +29,23 @@
export MINGHOST=i686-w64-mingw32
fi;
-export PATHOLD="/mingw/bin:/mingw/include:/c/Windows/system32:/c/Windows:.:/bin:/include:/usr/local/bin:/c/ming${OS_BUILD}/svn"
+export PATHOLD="/mingw/bin:/mingw/include:/mingw/lib:/c/Windows/system32:/c/Windows:.:/bin:/include:/usr/local/bin:/c/ming${OS_BUILD}/svn"
+#export PG_VER=9.2beta2
export PGWINVER=${PG_VER}edb
+export WORKSPACE=`pwd`
echo PATH BEFORE: $PATH
+#export PGHOST=localhost
+#export PGPORT=8442
+export PGUSER=postgres
+#export GEOS_VER=3.4.0dev
+#export GDAL_VER=1.9.1
export PGPATH=${PROJECTS}/postgresql/rel/pg${PG_VER}w${OS_BUILD}${GCC_TYPE}
-#export PROJSO=libproj-0.dll
+export PGPATHEDB=${PROJECTS}/postgresql/rel/pg${PG_VER}w${OS_BUILD}${GCC_TYPE}edb
export POSTGIS_VER=${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}
export POSTGIS_MICRO_VER=${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}
-echo POSTGIS_MICRO_VERSION: $POSTGIS_VER
if [ -n "$SOURCE_FOLDER" ]; then
export POSTGIS_SRC=${PROJECTS}/postgis/$SOURCE_FOLDER
@@ -67,38 +58,41 @@
fi;
fi;
#export POSTGIS_SRC=${PROJECTS}/postgis/trunk
export GDAL_DATA="${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/share/gdal"
-# export REL_PGVER=$(echo $PG_VER | tr '.' '')
-# echo $REL_PGVER
-# export RELDIR=${MINGPROJECTS}/postgis/builds/postgis-21
-# export RELVERDIR=postgis-pg${REL_PGVER}-binaries-${POSTGIS_MICRO_VER}w64
-#export PATH="${PATHOLD}:${PGPATH}/bin:${PGPATH}/lib"
-export PATH="${PGPATH}/bin:${PGPATH}/lib:${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/include:${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/bin:${MINGPROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/bin:${MINGPROJECTS}/gtk/bin:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin:${MINGPROJECTS}/xsltproc:${PATH}"
+export RELVERDIR=postgis-pg${REL_PGVER}-binaries-${POSTGIS_MICRO_VER}w${OS_BUILD}
+export PATH="${PATHOLD}:${PGPATH}/bin:${PGPATH}/lib"
+#PATH="${MINGPROJECTS}/gettext/rel-gettext-0.18.1/bin:${MINGPROJECTS}/xsltproc:${MINGPROJECTS}/gtk/bin:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}/bin:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}/bin:${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}/include:${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}/bin:${MINGPROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}/bin:${MINGPROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}/bin:${PATH}"
+PATH="${MINGPROJECTS}/xsltproc:${MINGPROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/bin:${MINGPROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin:${MINGPROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PATH}"
#add protobuf
export PATH="${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
+export PKG_CONFIG_PATH=${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig;
echo PATH AFTER: $PATH
-export PKG_CONFIG_PATH=${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig
+echo WORKSPACE IS $WORKSPACE
+#mkdir ${PROJECTS}/postgis/tmp
+export PGIS_REG_TMPDIR=${PROJECTS}/postgis/tmp/${POSTGIS_MICRO_VER}_pg${PG_VER}_geos${GEOS_VER}_gdal${GDAL_VER}w${OS_BUILD}
+rm -rf ${PGIS_REG_TMPDIR}
+mkdir ${PGIS_REG_TMPDIR}
+export TMPDIR=${PGIS_REG_TMPDIR}
+#rm -rf ${PGIS_REG_TMPDIR}
+#TMPDIR=${PROJECTS}/postgis/tmp/${POSTGIS_VER}_${PG_VER}_${GEOS_VERSION}_${PROJ_VER}
+echo PORT IS $PGPORT
+echo PGIS_REG_TMPDIR IS $PGIS_REG_TMPDIR
+export XSLTPROCFLAGS=
cd ${POSTGIS_SRC}
if [ -e ./GNUMakefile ]; then
make distclean
fi
-echo ${POSTGIS_SRC}
sh autogen.sh
-#hack to get around boolean incompatibility
-#-D__USE_MINGW_ANSI_STDIO=1
-if [ "$JSON_VER" == "0.9" ] ; then
- cp ${MINGPROJECTS}/json-c/rel-${JSON_VER}w${OS_BUILD}${GCC_TYPE}/include/json/json_object.h.for_configure ${MINGPROJECTS}/json-c/rel-${JSON_VER}w${OS_BUILD}${GCC_TYPE}/include/json/json_object.h
-fi
-export XSLTPROCFLAGS=
-#add PCRE for address standardizer
if [ -n "$PCRE_VER" ]; then
export PATH="${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/include:${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
fi
@@ -105,13 +99,18 @@
export PKG_CONFIG_PATH="${PROJECTS}/sqlite/rel-sqlite3w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/json-c/rel-${JSON_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig"
if [ -n "$SFCGAL_VER" ]; then
+ ##hard code versions of cgal etc. for now
+ export CGAL_VER=4.11
BOOST_VER=1.53.0
#BOOST_VER_WU=1_49_0
export BOOST_VER_WU=1_53_0
- export PATH="${PROJECTS}/CGAL/rel-cgal-${CGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/boost/rel-${BOOST_VER_WU}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
+ export PATH="${PROJECTS}/CGAL/rel-cgal-${CGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/CGAL/rel-sfcgal-${SFCGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/boost/rel-${BOOST_VER_WU}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
-#CPPFLAGS="-I${PGPATH}/include -I${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/include" \
+#note need to --enable-auto-import for LDFLAGS because wagyu fails to compile in without that.
+#See https://trac.osgeo.org/postgis/ticket/440
+#CPPFLAGS="-I${PGPATH}/include -I${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include" \
#CFLAGS="-Wall -fno-omit-frame-pointer" \
LDFLAGS="-Wl,--enable-auto-import -L${PGPATH}/lib -L${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib" \
@@ -126,7 +125,7 @@
--without-interrupt-tests \
--prefix=${PROJECTS}/postgis/liblwgeom-${POSTGIS_VER}w${OS_BUILD}${GCC_TYPE}
else
@@ -135,7 +134,7 @@
--with-pgconfig=${PGPATH}/bin/pg_config \
--with-geosconfig=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin/geos-config \
--with-gui --with-gettext=no \
- --with-libiconv=${PROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE} \
+ --with-libiconv=${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE} \
--with-xsldir=${PROJECTS}/docbook/docbook-xsl-1.76.1 \
@@ -142,6 +141,7 @@
fi;
make clean
#patch liblwgeom generated make to get rid of dynamic linking
#sed -i 's/LDFLAGS += -no-undefined//g' liblwgeom/Makefile
