[postgis-tickets] [PostGIS] #4417: EPSG:54009 not in spatial_ref_sys
trac at osgeo.org
Tue Jun 4 00:09:35 PDT 2019
Reporter: komzpa | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.5.3
Component: postgis | Version: 2.4.x
Keywords: |
GHSL popluation raster is distributed this way.
insert into
spatial_ref_sys (srid, auth_name, auth_srid, proj4text, srtext)
values
(54009, 'ESRI', 54009, '+proj=moll +lon_0=0 +x_0=0 +y_0=0 +datum=WGS84
+units=m +no_defs',
'PROJCS["World_Mollweide",GEOGCS["GCS_WGS_1984",DATUM["WGS_1984",SPHEROID["WGS_1984",6378137,298.257223563]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Mollweide"],PARAMETER["False_Easting",0],PARAMETER["False_Northing",0],PARAMETER["Central_Meridian",0],UNIT["Meter",1],AUTHORITY["EPSG","54009"]]');
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4417>
