[postgis-tickets] [PostGIS] #4334: Can't upgrade with a view based on ST_AsMVTGeom
trac at osgeo.org
Tue Jun 4 09:35:21 PDT 2019
Reporter: Algunenano | Owner: Algunenano
Type: defect | Status: new
Priority: high | Milestone: PostGIS 3.0.0
Component: build/upgrade/install | Version: 2.4.x
Resolution: | Keywords:
Comment (by Algunenano):
This also applies to aggregates, for example a view over the ST_Makeline
aggregation also breaks:
cannot drop function st_makeline(geometry) because other objects depend on
it
This aggregation is being dropped unconditionally since 2.5:
$postgis_proc_upgrade$;
-- Aggregate ST_MakeLine (geometry) -- LastUpdated: 205
DO LANGUAGE 'plpgsql'
BEGIN
IF 205 > version_from_num OR (
205 = version_from_num AND version_from_isdev
) FROM _postgis_upgrade_info
THEN
EXECUTE 'DROP AGGREGATE IF EXISTS ST_MakeLine (geometry)';
EXECUTE $postgis_proc_upgrade_parsed_def$ CREATE AGGREGATE ST_MakeLine
(geometry) (
SFUNC = pgis_geometry_accum_transfn,
STYPE = internal,
parallel = safe,
FINALFUNC = pgis_geometry_makeline_finalfn
$postgis_proc_upgrade_parsed_def$;
END IF;
END
The exact same issue for ST_Collect:
cartodb_user_d404665e-f81e-49c3-a4f2-86d7b3a96f24_db
-- Aggregate ST_Collect (geometry) -- LastUpdated: 205
BEGIN
THEN
EXECUTE 'DROP AGGREGATE IF EXISTS ST_Collect (geometry)';
EXECUTE $postgis_proc_upgrade_parsed_def$ CREATE AGGREGATE ST_Collect
(geometry) (
STYPE = internal,
parallel = safe,
FINALFUNC = pgis_geometry_collect_finalfn
END IF;
END
I guess this was done because it was considered simpler that updating
postgresql system tables.
As with the previous issue, since this is executed with every update it's
an infinite issue, but the good thing is that starting from PG12 this
could be changed by `CREATE OR REPLACE` without dropping anything.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4334#comment:9>
