[postgis-tickets] [PostGIS] #4334: Can't upgrade with a view based on ST_AsMVTGeom
PostGIS trac at osgeo.org
Tue Jun 4 23:09:17 PDT 2019
  Reporter:  Algunenano             |      Owner:  Algunenano
      Type:  defect                 |     Status:  new
  Priority:  high                   |  Milestone:  PostGIS 3.0.0
 Component:  build/upgrade/install  |    Version:  2.4.x
Resolution:                         |   Keywords:
Changes (by strk):
 * cc: komzpa (added)
Comment:
 The ticket to implement PG12 support for upgrade of aggregates is #4352
 (not done yet, and not planning to in the short term).
 I think komzpa was going to try (or already implemented?) a catalogue
 updating code for #4386 -
 I suggest looking at that, and if possible make the solution more general
 (for example including that approach in postgis_upgrade.pl script
 directly, maybe as part of the broather aggregate handling change to be
 done as part of #4352)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4334#comment:11>
