[postgis-tickets] r17472 - Remove extraneous UTF8 characters
Sandro Santilli
strk at kbt.io
Wed Jun 5 11:51:11 PDT 2019
Author: strk
Date: 2019-06-05 23:51:11 -0700 (Wed, 05 Jun 2019)
New Revision: 17472
branches/2.3/NEWS
Modified: branches/2.3/NEWS
--- branches/2.3/NEWS 2019-06-04 23:40:25 UTC (rev 17471)
+++ branches/2.3/NEWS 2019-06-06 06:51:11 UTC (rev 17472)
@@ -1,8 +1,8 @@
PostGIS 2.3.10
2019/XX/XX
* Bug Fixes and Enchantments *
- #4361, Fix postgis_type_name with (GEOMETRYM,3) (Matt Bretl)
- #4326, Fix circular arc distance calculation (Paul Ramsey)
@@ -9,12 +9,12 @@
PostGIS 2.3.9
2019/03/11
- #4139, Make mixed-dimension ND index build tree correctly.
- WARNING: REINDEX your ND index on tables that have records with different M/Z
- dimensions for &&& operator to work predictably.
+ WARNING: REINDEX your ND index on tables that have records with
+ different M/Z dimensions for &&& operator to work predictably.
(Darafei Praliaskouski, Arthur Lesuisse, Andrew Gierth, Raúl Marín)
- #4290, More robust distance calculations in geography (Paul Ramsey)
- #4267, Enable Proj 6 deprecated APIs (Darafei Praliaskouski, Raúl Marín)
