[postgis-tickets] r17478 - [drone] Add drone-1.0 config
Sandro Santilli
strk at kbt.io
Thu Jun 6 03:24:49 PDT 2019
Author: strk
Date: 2019-06-06 03:24:48 -0700 (Thu, 06 Jun 2019)
New Revision: 17478
Added:
branches/2.3/.drone-1.0.yml
Added: branches/2.3/.drone-1.0.yml
--- branches/2.3/.drone-1.0.yml (rev 0)
+++ branches/2.3/.drone-1.0.yml 2019-06-06 10:24:48 UTC (rev 17478)
@@ -0,0 +1,121 @@
+# This is for the drone 1.0 agent
+# https://docs.drone.io/user-guide/pipeline/steps/
+# https://dronie.osgeo.org #1.0 server
+# See https://git.osgeo.org/gitea/postgis/postgis-docker
+# todo: add docker images from https://hub.docker.com/r/postgis/postgis-build-env/tags/
+test-image: &test-image docker.kbt.io/postgis/build-test:trisquel2
+kind: pipeline
+name: pg-9.3
+steps:
+ - name: build
+ image: *test-image
+ pull: true
+ commands:
+ - export PGVER=9.3
+ - service postgresql start $PGVER
+ - export PGPORT=`grep ^port /etc/postgresql/$PGVER/main/postgresql.conf | awk '{print $3}'`
+ - export PATH=/usr/lib/postgresql/$PGVER/bin:$PATH
+ - psql --version
+ - ./autogen.sh
+ - ./configure CFLAGS="-O0 -Wall -fno-omit-frame-pointer" --without-interrupt-tests
+ - make -j
+ # we should maybe wait for postgresql service to startup here...
+ - psql -c "select version()" template1
+ - make check RUNTESTFLAGS=-v
+ - make install
+ - utils/check_all_upgrades.sh -s
+ `grep '^POSTGIS_' Version.config | cut -d= -f2 | paste -sd '.'`
+kind: pipeline
+name: pg-9.4
+steps:
+ - name: build
+ pull: true
+ commands:
+ - export PGVER=9.4
+ - psql --version
+ - ./autogen.sh
+ - make -j
+ - make install
+kind: pipeline
+name: pg-9.5
+steps:
+ - name: build
+ pull: true
+ commands:
+ - export PGVER=9.5
+ - psql --version
+ - ./autogen.sh
+ - make -j
+ - make install
+kind: pipeline
+name: pg-9.6
+steps:
+ - name: build
+ pull: true
+ commands:
+ - export PGVER=9.6
+ - psql --version
+ - ./autogen.sh
+ - make -j
+ - make install
+kind: pipeline
+name: pg-10
+steps:
+ - name: build
+ pull: true
+ commands:
+ - export PGVER=10
+ - psql --version
+ - ./autogen.sh
+ - make -j
+ - make install
