[postgis-tickets] r17479 - Modernize Python 2 code to get ready for Python 3
Darafei
komzpa at gmail.com
Sun Jun 9 04:31:35 PDT 2019
Author: komzpa
Date: 2019-06-09 04:31:34 -0700 (Sun, 09 Jun 2019)
New Revision: 17479
trunk/NEWS
trunk/raster/scripts/python/genraster.py
trunk/raster/scripts/python/ovdump.py
trunk/raster/scripts/python/pixval.py
trunk/raster/scripts/python/raster2pgsql.py
trunk/raster/scripts/python/rtgdalraster.py
trunk/raster/scripts/python/rtpixdump.py
trunk/raster/scripts/python/rtrowdump.py
trunk/raster/scripts/python/window.py
Patch by Christian Clauss
Closes #4422
Closes https://github.com/postgis/postgis/pull/410
Modified: trunk/NEWS
--- trunk/NEWS 2019-06-06 10:24:48 UTC (rev 17478)
+++ trunk/NEWS 2019-06-09 11:31:34 UTC (rev 17479)
@@ -155,9 +155,9 @@
- #4412, Support ingesting rasters with NODATA=NaN (Darafei Praliaskouski)
- #4413, Raster tile size follows GeoTIFF block size on raster2pgsql -t auto
+ - #4422, Modernize Python 2 code to get ready for Python 3 (Christian Clauss)
PostGIS 2.5.0
2018/09/23
WARNING: If compiling with PostgreSQL+JIT, LLVM >= 6 is required
Modified: trunk/raster/scripts/python/genraster.py
--- trunk/raster/scripts/python/genraster.py 2019-06-06 10:24:48 UTC (rev 17478)
+++ trunk/raster/scripts/python/genraster.py 2019-06-09 11:31:34 UTC (rev 17479)
@@ -26,6 +26,7 @@
# Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301, USA.
+from __future__ import print_function
import Image
import ImageDraw
import ImageFont
@@ -33,8 +34,8 @@
import sys
if len(sys.argv) < 5 or len(sys.argv) > 6:
- print 'Usage: genraster.py <xsize> <ysize> <xsizecell> <ysizecell> <outline colour>'
- print 'Note: Generated image is saved as out.png'
+ print('Usage: genraster.py <xsize> <ysize> <xsizecell> <ysizecell> <outline colour>')
+ print('Note: Generated image is saved as out.png')
sys.exit(1)
g_file = "out.png"
@@ -46,8 +47,8 @@
g_outline = None
ncells = (g_size[0] / g_cell_size[0]) * (g_size[1] / g_cell_size[1])
-print 'Number of cells: ',ncells
-print 'ID \tULX\tULY\tCLR\tTXTCLR\tOUTCLR'
+print('Number of cells: ',ncells)
+print('ID \tULX\tULY\tCLR\tTXTCLR\tOUTCLR')
img = Image.new("L", g_size, 255)
draw = ImageDraw.Draw(img)
@@ -74,9 +75,9 @@
draw.rectangle( [(i,j), (i + g_cell_size[0], j + g_cell_size[1])], fill=value, outline=g_outline)
draw.text( (i,j), ('%d' % count), fill=value_text, font=font)
- print '%d:\t%d\t%d\t%d\t%d\t%s' % (count, i, j, value, value_text, str(g_outline))
+ print('%d:\t%d\t%d\t%d\t%d\t%s' % (count, i, j, value, value_text, str(g_outline)))
count = count + 1
del draw
img.save(g_file, 'PNG')
-print 'Output saved: %s' % g_file
+print('Output saved: %s' % g_file)
Modified: trunk/raster/scripts/python/ovdump.py
--- trunk/raster/scripts/python/ovdump.py 2019-06-06 10:24:48 UTC (rev 17478)
+++ trunk/raster/scripts/python/ovdump.py 2019-06-09 11:31:34 UTC (rev 17479)
@@ -24,6 +24,7 @@
from osgeo import gdal
from osgeo import osr
import osgeo.gdalconst as gdalc
@@ -66,13 +67,13 @@
band = src_ds.GetRasterBand(1)
if nv < 0 and nv >= band.GetOverviewCount():
- print "ERROR: Failed to find overview %d" % nv
+ print("ERROR: Failed to find overview %d" % nv)
sys.exit(1)
ov_band = band.GetOverview(nv)
ovf = int(0.5 + band.XSize / float(ov_band.XSize))
- print "--- OVERVIEW #%d level = %d ---------------------------------------" % (nv + 1, ovf)
+ print("--- OVERVIEW #%d level = %d ---------------------------------------" % (nv + 1, ovf))
# Destination
dst_file = os.path.basename(opts.raster) + "_ov_" + str(ovf) + ".tif"
@@ -80,9 +81,9 @@
dst_drv = gdal.GetDriverByName(dst_format)
dst_ds = dst_drv.Create(dst_file, ov_band.XSize, ov_band.YSize, src_ds.RasterCount, ov_band.DataType)
- print "Source: " + opts.raster
- print "Target: " + dst_file
- print "Exporting %d bands of size %d x %d" % (src_ds.RasterCount, ov_band.XSize, ov_band.YSize)
+ print("Source: " + opts.raster)
+ print("Target: " + dst_file)
+ print("Exporting %d bands of size %d x %d" % (src_ds.RasterCount, ov_band.XSize, ov_band.YSize))
# Rewrite bands of overview to output file
ov_band = None
@@ -95,8 +96,8 @@
assert ov_band is not None
- print " Band #%d (%s) (%d x %d)" % \
- (nb, gdal.GetDataTypeName(ov_band.DataType), ov_band.XSize, ov_band.YSize)
+ print(" Band #%d (%s) (%d x %d)" % \
+ (nb, gdal.GetDataTypeName(ov_band.DataType), ov_band.XSize, ov_band.YSize))
dst_band = dst_ds.GetRasterBand(nb)
assert dst_band is not None
Modified: trunk/raster/scripts/python/pixval.py
--- trunk/raster/scripts/python/pixval.py 2019-06-06 10:24:48 UTC (rev 17478)
+++ trunk/raster/scripts/python/pixval.py 2019-06-09 11:31:34 UTC (rev 17479)
@@ -21,6 +21,7 @@
@@ -40,12 +41,12 @@
return fmttypes.get(pt, 'x')
- print "Usage: pixval.py <raster> <band> <x> <y>"
- print "\traster - GDAL supported dataset"
- print "\tband - 1-based number of band"
- print "\toverview - optional 1-based number of overview"
- print "\tx - Pixel column - 1..N where N is raster X dimension"
- print "\ty - Pixel row - 1..N where N is raster Y dimension"
+ print("Usage: pixval.py <raster> <band> <x> <y>")
+ print("\traster - GDAL supported dataset")
+ print("\tband - 1-based number of band")
+ print("\toverview - optional 1-based number of overview")
+ print("\tx - Pixel column - 1..N where N is raster X dimension")
+ print("\ty - Pixel row - 1..N where N is raster Y dimension")
sys.exit(0)
infile = sys.argv[1]
@@ -57,11 +58,11 @@
else:
noverview = None
-print "File : %s" % infile
-print "Band : %d" % nband
+print("File : %s" % infile)
+print("Band : %d" % nband)
if noverview is not None:
- print "Overview: %d" % noverview
-print "Pixel: %d x %d" % (x, y)
+ print("Overview: %d" % noverview)
+print("Pixel: %d x %d" % (x, y))
ds = gdal.Open(infile, gdalc.GA_ReadOnly);
if ds is None:
@@ -77,13 +78,13 @@
if noverview > 0 and noverview <= band.GetOverviewCount():
src_band = band.GetOverview(noverview - 1)
else:
- print "ERROR: Invalid overview index"
- print "Band %d consists of %d overivews" % (nband, band.GetOverviewCount())
+ print("ERROR: Invalid overview index")
+ print("Band %d consists of %d overivews" % (nband, band.GetOverviewCount()))
sys.exit(1)
if x <= 0 or x > src_band.XSize or y <= 0 or y > src_band.YSize:
- print "ERROR: Invalid pixel coordinates"
- print "Band or overview dimensions are %d x %d" % (src_band.XSize, src_band.YSize)
+ print("ERROR: Invalid pixel coordinates")
+ print("Band or overview dimensions are %d x %d" % (src_band.XSize, src_band.YSize))
sys.exit(1)
# Pixel index is 0-based
@@ -92,4 +93,4 @@
fmt = pt2fmt(src_band.DataType)
pixval = struct.unpack(fmt, pixel)
-print "Pixel value -> %s" % str(pixval[0])
+print("Pixel value -> %s" % str(pixval[0]))
Modified: trunk/raster/scripts/python/raster2pgsql.py
--- trunk/raster/scripts/python/raster2pgsql.py 2019-06-06 10:24:48 UTC (rev 17478)
+++ trunk/raster/scripts/python/raster2pgsql.py 2019-06-09 11:31:34 UTC (rev 17479)
@@ -30,6 +30,7 @@
@@ -303,7 +304,7 @@
def make_sql_value_array(values):
sql = "ARRAY["
for v in values:
- if type(v) == str:
+ if isinstance(v, str):
sql += quote_sql_value(v) + ","
else:
sql += str(v) + ','
@@ -628,15 +629,15 @@
def dump_block_numpy(pixels):
assert pixels.ndim == 2
- print 'BEGIN BLOCK SCANLINES (numpy): (%d, %d)' %(len(pixels[0]), len(pixels))
+ print('BEGIN BLOCK SCANLINES (numpy): (%d, %d)' %(len(pixels[0]), len(pixels)))
i = 0
for row in range (0, len(pixels)):
s = binascii.hexlify(pixels[row])
- print '%d (%d)\t%s' % (i, (len(s) / 2), s)
+ print('%d (%d)\t%s' % (i, (len(s) / 2), s))
i = i + 1
- print 'END BLOCK SCANLINES'
+ print('END BLOCK SCANLINES')
def fetch_band_nodata(band, default = 0):
assert band is not None
@@ -962,7 +963,7 @@
SUMMARY = []
saved_out = sys.stdout
- if type(opts.output) is str:
+ if isinstance(opts.output, str):
filename = opts.output
opts.output = open(filename, "w")
@@ -1019,19 +1020,19 @@
if opts.output != sys.stdout:
sys.stdout = saved_out
- print "------------------------------------------------------------"
- print " Summary of GDAL to PostGIS Raster processing:"
+ print("------------------------------------------------------------")
+ print(" Summary of GDAL to PostGIS Raster processing:")
if i == 1:
m = '%d (%s)' % (i, infile)
else:
m = '%d' % i
- print "Number of processed raster files: " + m
- print "List of generated tables (number of tiles):"
+ print("Number of processed raster files: " + m)
+ print("List of generated tables (number of tiles):")
i = 0
for s in SUMMARY:
i += 1
- print "%d\t%s (%d)" % (i, s[0], s[1])
+ print("%d\t%s (%d)" % (i, s[0], s[1]))
Modified: trunk/raster/scripts/python/rtgdalraster.py
--- trunk/raster/scripts/python/rtgdalraster.py 2019-06-06 10:24:48 UTC (rev 17478)
+++ trunk/raster/scripts/python/rtgdalraster.py 2019-06-09 11:31:34 UTC (rev 17479)
@@ -28,6 +28,7 @@
# along with this program; if not, write to the Free Software Foundation,
from optparse import OptionParser
import sys
import os
@@ -92,7 +93,7 @@
cur.close();
conn.close();
- print "raster outputted to %s" % opts.output;
+ print("raster outputted to %s" % opts.output);
-except Exception, e:
- print "ERROR: ", e
+except Exception as e:
+ print("ERROR: ", e)
Modified: trunk/raster/scripts/python/rtpixdump.py
--- trunk/raster/scripts/python/rtpixdump.py 2019-06-06 10:24:48 UTC (rev 17478)
+++ trunk/raster/scripts/python/rtpixdump.py 2019-06-09 11:31:34 UTC (rev 17479)
@@ -21,6 +21,7 @@
import rtreader
import sys
@@ -69,8 +70,8 @@
scanline = ""
for x in range(1, rast.width + 1):
scanline += str(int(rast.get_value(band, x, y))) + '\t'
- print scanline
- print # Bands separator
+ print(scanline)
+ print() # Bands separator
-except rtreader.RasterError, e:
- print "ERROR - ", e
+except rtreader.RasterError as e:
+ print("ERROR - ", e)
Modified: trunk/raster/scripts/python/rtrowdump.py
--- trunk/raster/scripts/python/rtrowdump.py 2019-06-06 10:24:48 UTC (rev 17478)
+++ trunk/raster/scripts/python/rtrowdump.py 2019-06-09 11:31:34 UTC (rev 17479)
@@ -130,5 +130,5 @@
band.WriteArray(raster)
Modified: trunk/raster/scripts/python/window.py
--- trunk/raster/scripts/python/window.py 2019-06-06 10:24:48 UTC (rev 17478)
+++ trunk/raster/scripts/python/window.py 2019-06-09 11:31:34 UTC (rev 17479)
@@ -21,6 +21,7 @@
@@ -27,12 +28,12 @@
import sys
if len(sys.argv) != 6:
- print "Usage: window.py <raster> <x> <y> <xsize> <ysize>"
- print "\tx - column - 1..N where N is raster X dimension"
- print "\ty - row - 1..N where N is raster Y dimension"
- print "\txsize - x-dimension of requested window (xsize <= xsize of raster - x)"
- print "\tysize - y-dimension of requested window (ysize <= ysize of raster - y)"
+ print("Usage: window.py <raster> <x> <y> <xsize> <ysize>")
+ print("\tx - column - 1..N where N is raster X dimension")
+ print("\ty - row - 1..N where N is raster Y dimension")
+ print("\txsize - x-dimension of requested window (xsize <= xsize of raster - x)")
+ print("\tysize - y-dimension of requested window (ysize <= ysize of raster - y)")
sys.exit(0)
def is_georeferenced(gt):
@@ -55,11 +56,11 @@
inyoff = int(sys.argv[3])
inxsize = int(sys.argv[4])
inysize = int(sys.argv[5])
-print "=== INPUT ==="
-print "File: %s" % infile
-print "Window:"
-print "- upper-left: %d x %d" % (inxoff, inyoff)
-print "- dimensions: %d x %d" % (inxsize, inysize)
+print("=== INPUT ===")
+print("File: %s" % infile)
+print("Window:")
+print("- upper-left: %d x %d" % (inxoff, inyoff))
+print("- dimensions: %d x %d" % (inxsize, inysize))
if ds is None:
@@ -67,11 +68,11 @@
xsize = ds.RasterXSize
ysize = ds.RasterYSize
-print "=== RASTER ==="
-print "- dimensions: %d x %d" % (xsize, ysize)
+print("=== RASTER ===")
+print("- dimensions: %d x %d" % (xsize, ysize))
if inxsize > xsize or inysize > ysize or inxoff > xsize or inyoff > ysize:
- print "Invalid size of input window"
+ print("Invalid size of input window")
sys.exit(1)
gt = ds.GetGeoTransform()
@@ -80,16 +81,16 @@
rot = ( gt[2], gt[4] ) # X-/Y-axis rotation
if is_georeferenced(gt):
- print "- pixel size:", res
- print "- upper left:", ulp
- print "- rotation :", rot
+ print("- pixel size:", res)
+ print("- upper left:", ulp)
+ print("- rotation :", rot)
else:
- print "No georeferencing is available"
+ print("No georeferencing is available")
sys.exit(1)
-print "=== WINDOW ==="
-print "- upper-left :", calculate_corner(gt, inxoff, inyoff)
-print "- lower-left :", calculate_corner(gt, inxoff, ysize)
-print "- upper-right:", calculate_corner(gt, xsize, inyoff)
-print "- lower-right:", calculate_corner(gt, xsize, ysize)
-print "- center :", calculate_corner(gt, xsize/2, ysize/2)
+print("=== WINDOW ===")
+print("- upper-left :", calculate_corner(gt, inxoff, inyoff))
+print("- lower-left :", calculate_corner(gt, inxoff, ysize))
+print("- upper-right:", calculate_corner(gt, xsize, inyoff))
+print("- lower-right:", calculate_corner(gt, xsize, ysize))
+print("- center :", calculate_corner(gt, xsize/2, ysize/2))
