[postgis-tickets] [PostGIS] #4334: Can't upgrade with a view based on ST_AsMVTGeom
trac at osgeo.org
Tue Jun 11 05:30:39 PDT 2019
Reporter: Algunenano | Owner: Algunenano
Type: defect | Status: new
Priority: high | Milestone: PostGIS 3.0.0
Component: build/upgrade/install | Version: 2.4.x
Resolution: | Keywords:
Comment (by Algunenano):
I plan to clean this file (`postgis/postgis_drop_before.sql`) a bit,
document things as much as possible there and try to drop functions /
aggregates that continue to exists (renamed parameters or added defaults).
The fist step is to review the drops and check when and why are there:
- `addgeometrycolumn`: A signature was dropped and it's not substituted by
another. Keeping the DROP is fine.
- `ST_MakeEnvelope`: A new signature was added `(float8, float8, float8,
float8)` during the 2.0 development, but it was replaced by a default
`(float8, float8, float8, float8, int)` which already existed. I'm
dropping the drop (o_O) since I don't think nobody is going to upgrade
from 2.0.0dev.
- `ST_AsX3D`: Signature changed (the old one is no longer valid). Keeping
the DROP is fine.
- `UpdateGeometrySRID`: Changed parameter name. Needs to be dropped
conditionally (only if the params match the old signature, not the new
one).
- Operators changed between 2.0 and 2.1: They are being renamed manually.
Keeping them from now.
- `geometry_gist_sel_2d` -> `gserialized_gist_sel_2d`
- `geometry_gist_joinsel_2d` -> `gserialized_gist_joinsel_2d`
- `geography_gist_selectivity` -> `gserialized_gist_sel_nd`.
- `geography_gist_join_selectivity` -> `gserialized_gist_joinsel_nd`
- `ST_AsLatLonText`: When from multiple functions to one with default
args. One signature can be dropped but the other has to be dropped
conditionally.
- `ST_AsTWKB`: Same as ST_AsLatLonText.
- `_st_linecrossingdirection` / `ST_LineCrossingDirection` /
`_st_orderingequals`/ `st_orderingequals`: Named to unnamed. Needs to be
dropped conditionally.
- `st_askml`: Changed with defaults, but these signatures don't conflict
with the current one. Simple DROP can be kept.
- `st_buffer`: Changed with defaults, but the signature doesn't conflict
- `ST_AsMVT` / `ST_AsMVTGeom` / `ST_AsGeobuf` / `pgis_asgeobuf_transfn` /
`pgis_asmvt_transfn`: Signatures were changed during dev / RC development
during 2.4.0. Dropping the DROPS as they shouldn't be necessary any
longer.
- `ST_CurveToLine`: Changed with defaults, but these signatures don't
conflict with the current one. Simple DROP can be kept.
- `geometry_columns VIEW`: We are already using `CREATE OR REPLACE VIEW`
so we can drop this.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4334#comment:13>
