[postgis-tickets] r17491 - Remove gserialized_get_zm() since it's barely used
Paul Ramsey pramsey at cleverelephant.ca
Tue Jun 11 08:42:04 PDT 2019
Author: pramsey
Date: 2019-06-11 08:42:03 -0700 (Tue, 11 Jun 2019)
New Revision: 17491
   trunk/liblwgeom/g_serialized.c
   trunk/liblwgeom/liblwgeom.h.in
   trunk/postgis/lwgeom_functions_basic.c
   trunk/raster/rt_pg/rtpg_mapalgebra.c
Modified: trunk/liblwgeom/g_serialized.c
--- trunk/liblwgeom/g_serialized.c	2019-06-11 15:06:12 UTC (rev 17490)
+++ trunk/liblwgeom/g_serialized.c	2019-06-11 15:42:03 UTC (rev 17491)
@@ -52,11 +52,6 @@
 	return FLAGS_GET_M(gser->flags);
-int gserialized_get_zm(const GSERIALIZED *gser)
-	return 2 * FLAGS_GET_Z(gser->flags) + FLAGS_GET_M(gser->flags);
 int gserialized_ndims(const GSERIALIZED *gser)
 	return FLAGS_NDIMS(gser->flags);
Modified: trunk/liblwgeom/liblwgeom.h.in
--- trunk/liblwgeom/liblwgeom.h.in	2019-06-11 15:06:12 UTC (rev 17490)
+++ trunk/liblwgeom/liblwgeom.h.in	2019-06-11 15:42:03 UTC (rev 17491)
@@ -730,12 +730,6 @@
 extern int gserialized_is_geodetic(const GSERIALIZED *gser);
-* Return a number indicating presence of Z and M coordinates.
-* 0 = None, 1 = M, 2 = Z, 3 = ZM
-extern int gserialized_get_zm(const GSERIALIZED *gser);
 * Return the number of dimensions (2, 3, 4) in a geometry
 extern int gserialized_ndims(const GSERIALIZED *gser);
Modified: trunk/postgis/lwgeom_functions_basic.c
--- trunk/postgis/lwgeom_functions_basic.c	2019-06-11 15:06:12 UTC (rev 17490)
+++ trunk/postgis/lwgeom_functions_basic.c	2019-06-11 15:42:03 UTC (rev 17491)
@@ -1903,22 +1903,11 @@
 PG_FUNCTION_INFO_V1(LWGEOM_noop);
 Datum LWGEOM_noop(PG_FUNCTION_ARGS)
-	GSERIALIZED *in, *out;
-	LWGEOM *lwgeom;
-	POSTGIS_DEBUG(2, "LWGEOM_noop called");
-	in = PG_GETARG_GSERIALIZED_P(0);
-	lwgeom = lwgeom_from_gserialized(in);
-	POSTGIS_DEBUGF(3, "Deserialized: %s", lwgeom_summary(lwgeom, 0));
-	out = geometry_serialize(lwgeom);
+	GSERIALIZED *in = PG_GETARG_GSERIALIZED_P(0);
+	LWGEOM *lwgeom = lwgeom_from_gserialized(in);
+	GSERIALIZED *out = geometry_serialize(lwgeom);;
 	lwgeom_free(lwgeom);
 	PG_FREE_IF_COPY(in, 0);
 	PG_RETURN_POINTER(out);
@@ -1958,10 +1947,9 @@
 PG_FUNCTION_INFO_V1(LWGEOM_zmflag);
 Datum LWGEOM_zmflag(PG_FUNCTION_ARGS)
-	GSERIALIZED *in;
+	GSERIALIZED *in = PG_GETARG_GSERIALIZED_P(0);;
 	int ret = 0;
 	if (gserialized_has_z(in))
 		ret += 2;
 	if (gserialized_has_m(in))
@@ -1997,11 +1985,8 @@
 PG_FUNCTION_INFO_V1(LWGEOM_ndims);
 Datum LWGEOM_ndims(PG_FUNCTION_ARGS)
-	GSERIALIZED *in;
-	int ret;
-	ret = (gserialized_ndims(in));
+	int ret = gserialized_ndims(in);
 	PG_RETURN_INT16(ret);
@@ -2015,20 +2000,15 @@
 	LWGEOM *lwg1, *lwg2;
 	bool result;
-	if (gserialized_get_type(g1) != gserialized_get_type(g2))
+	if ((gserialized_get_type(g1) != gserialized_get_type(g2)) ||
+		(gserialized_has_z(g1) != gserialized_has_z(g2)) ||
+		(gserialized_has_m(g1) != gserialized_has_m(g2)))
 		PG_FREE_IF_COPY(g1, 0);
 		PG_FREE_IF_COPY(g2, 1);
-		PG_RETURN_BOOL(false); /* different types */
+		PG_RETURN_BOOL(false); /* different type or dimensionality */
-	if (gserialized_get_zm(g1) != gserialized_get_zm(g2))
-		PG_FREE_IF_COPY(g1, 0);
-		PG_FREE_IF_COPY(g2, 1);
-		PG_RETURN_BOOL(false); /* different dimensions */
 	/* ok, deserialize. */
 	lwg1 = lwgeom_from_gserialized(g1);
 	lwg2 = lwgeom_from_gserialized(g2);
Modified: trunk/raster/rt_pg/rtpg_mapalgebra.c
--- trunk/raster/rt_pg/rtpg_mapalgebra.c	2019-06-11 15:06:12 UTC (rev 17490)
+++ trunk/raster/rt_pg/rtpg_mapalgebra.c	2019-06-11 15:42:03 UTC (rev 17491)
@@ -77,6 +77,10 @@
 /*  n-raster MapAlgebra                                             */
+/* Quiet warning */
+#pragma clang diagnostic push
+#pragma clang diagnostic ignored "-Wgnu-variable-sized-type-not-at-end"
 typedef struct {
 	Oid ufc_noid;
 	Oid ufc_rettype;
@@ -93,6 +97,9 @@
 #endif
 } rtpg_nmapalgebra_callback_arg;
+#pragma clang diagnostic pop
+/* ! Quiet warning */
 typedef struct rtpg_nmapalgebra_arg_t *rtpg_nmapalgebra_arg;
 struct rtpg_nmapalgebra_arg_t {
 	int numraster;
