[postgis-tickets] [PostGIS] #4334: Can't upgrade with a view based on ST_AsMVTGeom
trac at osgeo.org
Tue Jun 11 08:47:16 PDT 2019
Reporter: Algunenano | Owner: Algunenano
Type: defect | Status: new
Priority: high | Milestone: PostGIS 3.0.0
Component: build/upgrade/install | Version: 2.4.x
Resolution: | Keywords:
Comment (by Algunenano):
> geometry_columns VIEW: We are already using CREATE OR REPLACE VIEW so we
can drop this.
I was wrong about this:
HINT: type `SELECT postgis_extensions_upgrade(); to finish the upgrade.
After upgrading, if you want to drop raster, run: DROP EXTENSION
postgis_raster;
ERROR: cannot change data type of view column "f_table_schema" from
character varying(256) to name
I'll see if we can we really need an unconditional DROP or we can only
drop it when the old view is found (similar to the function).
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4334#comment:16>
