[postgis-tickets] r17498 - Pull gserialized_read_gbox_p and gserialized_peek_gbox_p back in favour of a public gserialized_fast_gbox_p. Pull liblwgeom_internal out of mvt.c
Paul Ramsey pramsey at cleverelephant.ca
Tue Jun 11 11:24:40 PDT 2019
Author: pramsey
Date: 2019-06-11 11:24:40 -0700 (Tue, 11 Jun 2019)
New Revision: 17498
   trunk/liblwgeom/g_serialized.c
   trunk/liblwgeom/liblwgeom.h.in
   trunk/liblwgeom/liblwgeom_internal.h
   trunk/postgis/gserialized_gist_2d.c
   trunk/postgis/lwgeom_out_mvt.c
   trunk/postgis/mvt.c
   trunk/postgis/mvt.h
Modified: trunk/liblwgeom/g_serialized.c
--- trunk/liblwgeom/g_serialized.c	2019-06-11 18:09:50 UTC (rev 17497)
+++ trunk/liblwgeom/g_serialized.c	2019-06-11 18:24:40 UTC (rev 17498)
@@ -677,7 +677,32 @@
+* Read the bounding box off a serialization and fail if
+* it is not already there.
+int gserialized_fast_gbox_p(const GSERIALIZED *g, GBOX *box)
+	/* Try to just read the serialized box. */
+	if ( gserialized_read_gbox_p(g, box) == LW_SUCCESS )
+		return LW_SUCCESS;
+	/* No box? Try to peek into simpler geometries and */
+	/* derive a box without creating an lwgeom */
+	else if ( gserialized_peek_gbox_p(g, box) == LW_SUCCESS )
+	else
+		return LW_FAILURE;
 * Calculate the GSERIALIZED size for an LWGEOM.
Modified: trunk/liblwgeom/liblwgeom.h.in
--- trunk/liblwgeom/liblwgeom.h.in	2019-06-11 18:09:50 UTC (rev 17497)
+++ trunk/liblwgeom/liblwgeom.h.in	2019-06-11 18:24:40 UTC (rev 17498)
@@ -1239,9 +1239,32 @@
 extern int lwgeom_is_clockwise(LWGEOM *lwgeom);
+* Simplification
 extern LWGEOM* lwgeom_simplify(const LWGEOM *igeom, double dist, int preserve_collapsed);
 extern LWGEOM* lwgeom_remove_repeated_points(const LWGEOM *in, double tolerance);
+* Snap-to-grid
+typedef struct gridspec_t
+    double ipx;
+    double ipy;
+    double ipz;
+    double ipm;
+    double xsize;
+    double ysize;
+    double zsize;
+    double msize;
+gridspec;
+extern LWGEOM* lwgeom_grid(const LWGEOM *lwgeom, const gridspec *grid);
+extern void lwgeom_grid_in_place(LWGEOM *lwgeom, const gridspec *grid);
 * READ/WRITE FUNCTIONS
@@ -1951,9 +1974,15 @@
 * it is not, calculate it from the geometry. If that doesn't work (null
 * or empty) return LW_FAILURE.
-extern int gserialized_get_gbox_p(const GSERIALIZED *g, GBOX *gbox);
+extern int gserialized_get_gbox_p(const GSERIALIZED *g, GBOX *box);
+* Pull a #GBOX from the header of a #GSERIALIZED, if one is available. If
+* it is not, return LW_FAILURE.
+extern int gserialized_fast_gbox_p(const GSERIALIZED *g, GBOX *box);
  * Parser check flags
Modified: trunk/liblwgeom/liblwgeom_internal.h
--- trunk/liblwgeom/liblwgeom_internal.h	2019-06-11 18:09:50 UTC (rev 17497)
+++ trunk/liblwgeom/liblwgeom_internal.h	2019-06-11 18:24:40 UTC (rev 17498)
@@ -398,25 +398,6 @@
 * Snap to grid
-* Snap-to-grid Support
-typedef struct gridspec_t
-	double ipx;
-	double ipy;
-	double ipz;
-	double ipm;
-	double xsize;
-	double ysize;
-	double zsize;
-	double msize;
-gridspec;
-LWGEOM* lwgeom_grid(const LWGEOM *lwgeom, const gridspec *grid);
-void lwgeom_grid_in_place(LWGEOM *lwgeom, const gridspec *grid);
 void ptarray_grid_in_place(POINTARRAY *pa, const gridspec *grid);
Modified: trunk/postgis/gserialized_gist_2d.c
--- trunk/postgis/gserialized_gist_2d.c	2019-06-11 18:09:50 UTC (rev 17497)
+++ trunk/postgis/gserialized_gist_2d.c	2019-06-11 18:24:40 UTC (rev 17498)
@@ -571,9 +571,10 @@
 	** enough to take serious advantage of PG_DETOAST_DATUM_SLICE will have
 	** already been compressed, which means the entire object will be
 	** fetched and decompressed before a slice is taken, thus removing
-	** any efficiencies gained from slicing. We need to move to
-	** "storage = external" and implement our own geometry compressor
-	** before we can take advantage of sliced retrieval.
+	** any efficiencies gained from slicing.
+	** As of Pg12 we can partially decompress a toasted object
+	** (though we still need to fully retrieve it from TOAST)
+	** which makes slicing worthwhile.
 	gpart = (GSERIALIZED*)PG_DETOAST_DATUM(gsdatum);
 	flags = gpart->flags;
Modified: trunk/postgis/lwgeom_out_mvt.c
--- trunk/postgis/lwgeom_out_mvt.c	2019-06-11 18:09:50 UTC (rev 17497)
+++ trunk/postgis/lwgeom_out_mvt.c	2019-06-11 18:24:40 UTC (rev 17498)
@@ -89,8 +89,7 @@
 		GBOX gserialized_box;
 		/* We only apply the optimization if the bounding box is available */
-		if ((gserialized_read_gbox_p(geom_in, &gserialized_box) == LW_SUCCESS) ||
-		    (gserialized_peek_gbox_p(geom_in, &gserialized_box) == LW_SUCCESS))
+		if (gserialized_fast_gbox_p(geom_in, &gserialized_box) == LW_SUCCESS)
 			/* Shortcut to drop geometries smaller than the resolution */
 			double geom_width = gserialized_box.xmax - gserialized_box.xmin;
Modified: trunk/postgis/mvt.c
--- trunk/postgis/mvt.c	2019-06-11 18:09:50 UTC (rev 17497)
+++ trunk/postgis/mvt.c	2019-06-11 18:24:40 UTC (rev 17498)
@@ -23,6 +23,7 @@
 #include <string.h>
+#include <float.h>
 #include "mvt.h"
 #include "lwgeom_geos.h"
@@ -619,7 +620,8 @@
 					PointerGetDatum(v.val.numeric)));
 				d = strtod(str, NULL);
 				l = strtol(str, NULL, 10);
-				if (FP_NEQUALS(d, (double)l))
+				if (fabs(d - (double)l) > FLT_EPSILON)
 					MVT_PARSE_VALUE(d, mvt_kv_double_value, double_values_hash,
 						double_value, sizeof(double));
Modified: trunk/postgis/mvt.h
--- trunk/postgis/mvt.h	2019-06-11 18:09:50 UTC (rev 17497)
+++ trunk/postgis/mvt.h	2019-06-11 18:24:40 UTC (rev 17498)
@@ -38,7 +38,6 @@
 #include "access/htup.h"
 #include "../postgis_config.h"
 #include "liblwgeom.h"
-#include "liblwgeom_internal.h"
 #include "lwgeom_pg.h"
 #include "lwgeom_log.h"
