[postgis-tickets] r17500 - Rename cu_tests for gserialized to version 1
Paul Ramsey
pramsey at cleverelephant.ca
Tue Jun 11 11:39:07 PDT 2019
Author: pramsey
Date: 2019-06-11 11:39:07 -0700 (Tue, 11 Jun 2019)
New Revision: 17500
Added:
trunk/liblwgeom/cunit/cu_gserialized1.c
Removed:
trunk/liblwgeom/cunit/cu_libgeom.c
trunk/liblwgeom/cunit/Makefile.in
Modified: trunk/liblwgeom/cunit/Makefile.in
--- trunk/liblwgeom/cunit/Makefile.in 2019-06-11 18:31:23 UTC (rev 17499)
+++ trunk/liblwgeom/cunit/Makefile.in 2019-06-11 18:39:07 UTC (rev 17500)
@@ -43,7 +43,7 @@
cu_filterm.o \
cu_node.o \
cu_clip_by_rect.o \
- cu_libgeom.o \
+ cu_gserialized1.o \
cu_lwstroke.o \
cu_split.o \
cu_stringbuffer.o \
Copied: trunk/liblwgeom/cunit/cu_gserialized1.c (from rev 17499, trunk/liblwgeom/cunit/cu_libgeom.c)
--- trunk/liblwgeom/cunit/cu_gserialized1.c (rev 0)
+++ trunk/liblwgeom/cunit/cu_gserialized1.c 2019-06-11 18:39:07 UTC (rev 17500)
@@ -0,0 +1,1266 @@
+ * PostGIS - Spatial Types for PostgreSQL
+ * http://postgis.net
+ * Copyright 2009 Paul Ramsey <pramsey at cleverelephant.ca>
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU General Public Licence. See the COPYING file.
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include "CUnit/Basic.h"
+#include "liblwgeom_internal.h"
+#include "g_serialized.c" /* for gserialized_peek_gbox_p */
+#include "cu_tester.h"
+static void test_typmod_macros(void)
+ int32_t typmod = 0;
+ int32_t srid = 4326;
+ int type = 6;
+ int z = 1;
+ int rv;
+ TYPMOD_SET_SRID(typmod,srid);
+ rv = TYPMOD_GET_SRID(typmod);
+ CU_ASSERT_EQUAL(rv, srid);
+ srid = -5005;
+ srid = 999999;
+ srid = -999999;
+ srid = SRID_UNKNOWN;
+ srid = 0;
+ srid = 1;
+ TYPMOD_SET_TYPE(typmod,type);
+ rv = TYPMOD_GET_TYPE(typmod);
+ CU_ASSERT_EQUAL(rv,type);
+ TYPMOD_SET_Z(typmod);
+ rv = TYPMOD_GET_Z(typmod);
+ CU_ASSERT_EQUAL(rv,z);
+ rv = TYPMOD_GET_M(typmod);
+ CU_ASSERT_EQUAL(rv,0);
+static void test_flags_macros(void)
+ uint8_t flags = 0;
+ CU_ASSERT_EQUAL(0, FLAGS_GET_Z(flags));
+ FLAGS_SET_Z(flags, 1);
+ CU_ASSERT_EQUAL(1, FLAGS_GET_Z(flags));
+ FLAGS_SET_Z(flags, 0);
+ CU_ASSERT_EQUAL(0, FLAGS_GET_BBOX(flags));
+ CU_ASSERT_EQUAL(0, FLAGS_GET_M(flags));
+ FLAGS_SET_M(flags, 1);
+ CU_ASSERT_EQUAL(1, FLAGS_GET_M(flags));
+ FLAGS_SET_BBOX(flags, 1);
+ CU_ASSERT_EQUAL(1, FLAGS_GET_BBOX(flags));
+ CU_ASSERT_EQUAL(0, FLAGS_GET_READONLY(flags));
+ FLAGS_SET_READONLY(flags, 1);
+ CU_ASSERT_EQUAL(1, FLAGS_GET_READONLY(flags));
+ FLAGS_SET_READONLY(flags, 0);
+ CU_ASSERT_EQUAL(0, FLAGS_GET_GEODETIC(flags));
+ FLAGS_SET_GEODETIC(flags, 1);
+ CU_ASSERT_EQUAL(1, FLAGS_GET_GEODETIC(flags));
+ flags = gflags(1, 0, 1); /* z=1, m=0, geodetic=1 */
+ CU_ASSERT_EQUAL(2, FLAGS_GET_ZM(flags));
+ flags = gflags(1, 1, 1); /* z=1, m=1, geodetic=1 */
+ CU_ASSERT_EQUAL(3, FLAGS_GET_ZM(flags));
+ flags = gflags(0, 1, 0); /* z=0, m=1, geodetic=0 */
+ CU_ASSERT_EQUAL(1, FLAGS_GET_ZM(flags));
+static void test_serialized_srid(void)
+ GSERIALIZED s;
+ int32_t srid, rv;
+ srid = 4326;
+ gserialized_set_srid(&s, srid);
+ rv = gserialized_get_srid(&s);
+ srid = -3005;
+ //printf("srid=%d rv=%d\n",srid,rv);
+ CU_ASSERT_EQUAL(rv, SRID_UNKNOWN);
+ srid = 100000;
+static void test_gserialized_from_lwgeom_size(void)
+ LWGEOM *g;
+ size_t size = 0;
+ g = lwgeom_from_wkt("POINT(0 0)", LW_PARSER_CHECK_NONE);
+ size = gserialized_from_lwgeom_size(g);
+ CU_ASSERT_EQUAL( size, 32 );
+ lwgeom_free(g);
+ g = lwgeom_from_wkt("POINT(0 0 0)", LW_PARSER_CHECK_NONE);
+ CU_ASSERT_EQUAL( size, 40 );
+ lwgeom_free(g);
+ g = lwgeom_from_wkt("MULTIPOINT(0 0 0, 1 1 1)", LW_PARSER_CHECK_NONE);
+ CU_ASSERT_EQUAL( size, 80 );
+ lwgeom_free(g);
+ g = lwgeom_from_wkt("LINESTRING(0 0, 1 1)", LW_PARSER_CHECK_NONE);
+ CU_ASSERT_EQUAL( size, 48 );
+ lwgeom_free(g);
+ g = lwgeom_from_wkt("MULTILINESTRING((0 0, 1 1),(0 0, 1 1))", LW_PARSER_CHECK_NONE);
+ CU_ASSERT_EQUAL( size, 96 );
+ lwgeom_free(g);
+ g = lwgeom_from_wkt("POLYGON((0 0, 0 1, 1 1, 1 0, 0 0))", LW_PARSER_CHECK_NONE);
+ CU_ASSERT_EQUAL( size, 104 );
+ lwgeom_free(g);
+ g = lwgeom_from_wkt("POLYGON((-1 -1, -1 2, 2 2, 2 -1, -1 -1), (0 0, 0 1, 1 1, 1 0, 0 0))", LW_PARSER_CHECK_NONE);
+ CU_ASSERT_EQUAL( size, 184 );
+ lwgeom_free(g);
+static void test_lwgeom_calculate_gbox(void)
+ LWGEOM *g;
+ GBOX b;
+ lwgeom_calculate_gbox_cartesian(g, &b);
+ CU_ASSERT_DOUBLE_EQUAL(b.xmin, 0.0, 0.0000001);
+ lwgeom_free(g);
+ /* Inf = 0x7FF0000000000000 */
+ /* POINT(0 0) = 00 00000001 0000000000000000 0000000000000000 */
+ /* POINT(0 Inf) = 00 00000001 0000000000000000 7FF0000000000000 */
+ g = lwgeom_from_hexwkb("000000000100000000000000007FF0000000000000", LW_PARSER_CHECK_NONE);
+ CU_ASSERT(isinf(b.ymax));
+ lwgeom_free(g);
+ /* LINESTRING(0 0, 0 Inf) = 00 00000002 00000002 0000000000000000 7FF0000000000000 0000000000000000 0000000000000000 */
+ /* Inf should show up in bbox */
+ g = lwgeom_from_hexwkb("00000000020000000200000000000000007FF000000000000000000000000000000000000000000000", LW_PARSER_CHECK_NONE);
+ lwgeom_free(g);
+ /* Geometry with NaN 0101000020E8640000000000000000F8FF000000000000F8FF */
+ /* NaN should show up in bbox for "SRID=4326;POINT(0 NaN)" */
+ g = lwgeom_from_hexwkb("0101000020E86400000000000000000000000000000000F8FF", LW_PARSER_CHECK_NONE);
+ CU_ASSERT(isnan(b.ymax));
+ lwgeom_free(g);
+static void test_gbox_serialized_size(void)
+ uint8_t flags = gflags(0, 0, 0);
+ CU_ASSERT_EQUAL(gbox_serialized_size(flags),16);
+ CU_ASSERT_EQUAL(gbox_serialized_size(flags),24);
+ CU_ASSERT_EQUAL(gbox_serialized_size(flags),32);
+static void test_lwgeom_from_gserialized(void)
+ LWGEOM *geom;
+ GSERIALIZED *g;
+ char *in_ewkt;
+ char *out_ewkt;
+ size_t i = 0;
+ char *ewkt[] =
+ "POINT EMPTY",
+ "POINT(0 0.2)",
+ "LINESTRING EMPTY",
+ "LINESTRING(-1 -1,-1 2.5,2 2,2 -1)",
+ "MULTIPOINT EMPTY",
+ "MULTIPOINT(0.9 0.9,0.9 0.9,0.9 0.9,0.9 0.9,0.9 0.9,0.9 0.9)",
+ "SRID=1;MULTILINESTRING EMPTY",
+ "SRID=1;MULTILINESTRING((-1 -1,-1 2.5,2 2,2 -1),(-1 -1,-1 2.5,2 2,2 -1),(-1 -1,-1 2.5,2 2,2 -1),(-1 -1,-1 2.5,2 2,2 -1))",
+ "POLYGON((-1 -1,-1 2.5,2 2,2 -1,-1 -1),(0 0,0 1,1 1,1 0,0 0))",
+ "POLYGON EMPTY",
+ "SRID=4326;POLYGON((-1 -1,-1 2.5,2 2,2 -1,-1 -1),(0 0,0 1,1 1,1 0,0 0))",
+ "SRID=4326;POLYGON EMPTY",
+ "SRID=4326;POLYGON((-1 -1,-1 2.5,2 2,2 -1,-1 -1),(0 0,0 1,1 1,1 0,0 0),(-0.5 -0.5,-0.5 -0.4,-0.4 -0.4,-0.4 -0.5,-0.5 -0.5))",
+ "SRID=100000;POLYGON((-1 -1 3,-1 2.5 3,2 2 3,2 -1 3,-1 -1 3),(0 0 3,0 1 3,1 1 3,1 0 3,0 0 3),(-0.5 -0.5 3,-0.5 -0.4 3,-0.4 -0.4 3,-0.4 -0.5 3,-0.5 -0.5 3))",
+ "SRID=4326;MULTIPOLYGON(((-1 -1,-1 2.5,2 2,2 -1,-1 -1),(0 0,0 1,1 1,1 0,0 0),(-0.5 -0.5,-0.5 -0.4,-0.4 -0.4,-0.4 -0.5,-0.5 -0.5)),((-1 -1,-1 2.5,2 2,2 -1,-1 -1),(0 0,0 1,1 1,1 0,0 0),(-0.5 -0.5,-0.5 -0.4,-0.4 -0.4,-0.4 -0.5,-0.5 -0.5)))",
+ "SRID=4326;MULTIPOLYGON EMPTY",
+ "SRID=4326;GEOMETRYCOLLECTION(POINT(0 1),POLYGON((-1 -1,-1 2.5,2 2,2 -1,-1 -1),(0 0,0 1,1 1,1 0,0 0)),MULTIPOLYGON(((-1 -1,-1 2.5,2 2,2 -1,-1 -1),(0 0,0 1,1 1,1 0,0 0),(-0.5 -0.5,-0.5 -0.4,-0.4 -0.4,-0.4 -0.5,-0.5 -0.5))))",
+ "SRID=4326;GEOMETRYCOLLECTION EMPTY",
+ "SRID=4326;GEOMETRYCOLLECTION(POINT EMPTY,MULTIPOLYGON EMPTY)",
+ "MULTICURVE((5 5 1 3,3 5 2 2,3 3 3 1,0 3 1 1),CIRCULARSTRING(0 0 0 0,0.26794 1 3 -2,0.5857864 1.414213 1 2))",
+ "MULTISURFACE(CURVEPOLYGON(CIRCULARSTRING(-2 0,-1 -1,0 0,1 -1,2 0,0 2,-2 0),(-1 0,0 0.5,1 0,0 1,-1 0)),((7 8,10 10,6 14,4 11,7 8)))",
+ "MULTISURFACE(CURVEPOLYGON(CIRCULARSTRING EMPTY))",
+ for ( i = 0; i < (sizeof ewkt/sizeof(char*)); i++ )
+ LWGEOM* geom2;
+ in_ewkt = ewkt[i];
+ geom = lwgeom_from_wkt(in_ewkt, LW_PARSER_CHECK_NONE);
+ lwgeom_add_bbox(geom);
+ if ( geom->bbox ) gbox_float_round(geom->bbox);
+ g = gserialized_from_lwgeom(geom, 0);
+ geom2 = lwgeom_from_gserialized(g);
+ out_ewkt = lwgeom_to_ewkt(geom2);
+ /* printf("\n in = %s\nout = %s\n", in_ewkt, out_ewkt); */
+ CU_ASSERT_STRING_EQUAL(in_ewkt, out_ewkt);
+ /* either both or none of the bboxes are null */
+ CU_ASSERT( (geom->bbox != NULL) || (geom2->bbox == NULL) );
+ /* either both are null or they are the same */
+ CU_ASSERT(geom->bbox == NULL || gbox_same(geom->bbox, geom2->bbox));
+ lwgeom_free(geom);
+ lwgeom_free(geom2);
+ lwfree(g);
+ lwfree(out_ewkt);
+static void test_gserialized_is_empty(void)
+ int i = 0;
+ struct gserialized_empty_cases {
+ const char* wkt;
+ int isempty;
+ struct gserialized_empty_cases cases[] = {
+ { "POINT EMPTY", 1 },
+ { "POINT(1 1)", 0 },
+ { "LINESTRING EMPTY", 1 },
+ { "MULTILINESTRING EMPTY", 1 },
+ { "MULTILINESTRING(EMPTY)", 1 },
+ { "MULTILINESTRING(EMPTY,EMPTY)", 1 },
+ { "MULTILINESTRING(EMPTY,(0 0,1 1))", 0 },
+ { "MULTILINESTRING((0 0,1 1),EMPTY)", 0 },
+ { "MULTILINESTRING(EMPTY,(0 0,1 1),EMPTY)", 0 },
+ { "MULTILINESTRING(EMPTY,EMPTY,EMPTY)", 1 },
+ { "GEOMETRYCOLLECTION(POINT EMPTY,MULTILINESTRING(EMPTY,EMPTY,EMPTY))", 1 },
+ { "GEOMETRYCOLLECTION(POINT EMPTY,MULTILINESTRING(EMPTY),POINT(1 1))", 0 },
+ { "GEOMETRYCOLLECTION(POINT EMPTY,MULTILINESTRING(EMPTY, (0 0)),POINT EMPTY)", 0 },
+ { "GEOMETRYCOLLECTION(POLYGON EMPTY,POINT EMPTY,MULTILINESTRING(EMPTY,EMPTY),POINT EMPTY)", 1 },
+ { "GEOMETRYCOLLECTION(POLYGON EMPTY,GEOMETRYCOLLECTION(POINT EMPTY),MULTILINESTRING(EMPTY,EMPTY),POINT EMPTY)", 1 },
+ { NULL, 0 }
+ while( cases[i].wkt )
+ // i = 11;
+ LWGEOM *lw = lwgeom_from_wkt(cases[i].wkt, LW_PARSER_CHECK_NONE);
+ GSERIALIZED *g = gserialized_from_lwgeom(lw, 0);
+ int ie = gserialized_is_empty(g);
+ // printf("%s: we say %d, they say %d\n", cases[i].wkt, cases[i].isempty, ie);
+ CU_ASSERT_EQUAL(ie, cases[i].isempty);
+ lwgeom_free(lw);
+ lwfree(g);
+ i++;
+static void test_geometry_type_from_string(void)
+ int rv;
+ uint8_t type = 0;
+ int z = 0, m = 0;
+ char *str;
+ str = " POINTZ";
+ rv = geometry_type_from_string(str, &type, &z, &m);
+ //printf("\n in type: %s\nout type: %d\n out z: %d\n out m: %d", str, type, z, m);
+ CU_ASSERT_EQUAL(rv, LW_SUCCESS);
+ CU_ASSERT_EQUAL(type, POINTTYPE);
+ CU_ASSERT_EQUAL(z, 1);
+ CU_ASSERT_EQUAL(m, 0);
+ str = "LINESTRINGM ";
+ CU_ASSERT_EQUAL(type, LINETYPE);
+ CU_ASSERT_EQUAL(z, 0);
+ CU_ASSERT_EQUAL(m, 1);
+ str = "MULTIPOLYGONZM";
+ CU_ASSERT_EQUAL(type, MULTIPOLYGONTYPE);
+ str = " GEOMETRYCOLLECTIONZM ";
+ CU_ASSERT_EQUAL(type, COLLECTIONTYPE);
+ str = " GEOMERYCOLLECTIONZM ";
+ CU_ASSERT_EQUAL(rv, LW_FAILURE);
+static void test_lwgeom_count_vertices(void)
+ LWGEOM *geom;
+ geom = lwgeom_from_wkt("MULTIPOINT(-1 -1,-1 2.5,2 2,2 -1)", LW_PARSER_CHECK_NONE);
+ CU_ASSERT_EQUAL(lwgeom_count_vertices(geom),4);
+ geom = lwgeom_from_wkt("SRID=1;MULTILINESTRING((-1 -131,-1 2.5,2 2,2 -1),(-1 -1,-1 2.5,2 2,2 -1),(-1 -1,-1 2.5,2 2,2 -1),(-1 -1,-1 2.5,2 2,2 -1))", LW_PARSER_CHECK_NONE);
+ CU_ASSERT_EQUAL(lwgeom_count_vertices(geom),16);
+ geom = lwgeom_from_wkt("SRID=4326;MULTIPOLYGON(((-1 -1,-1 2.5,211 2,2 -1,-1 -1),(0 0,0 1,1 1,1 0,0 0),(-0.5 -0.5,-0.5 -0.4,-0.4 -0.4,-0.4 -0.5,-0.5 -0.5)),((-1 -1,-1 2.5,2 2,2 -1,-1 -1),(0 0,0 1,1 1,1 0,0 0),(-0.5 -0.5,-0.5 -0.4,-0.4 -0.4,-0.4 -0.5,-0.5 -0.5)))", LW_PARSER_CHECK_NONE);
+ CU_ASSERT_EQUAL(lwgeom_count_vertices(geom),30);
+static void test_on_gser_lwgeom_count_vertices(void)
+ LWGEOM *lwgeom;
+ GSERIALIZED *g_ser1;
+ size_t ret_size;
+ lwgeom = lwgeom_from_wkt("MULTIPOINT(-1 -1,-1 2.5,2 2,2 -1,1 1,2 2,4 5)", LW_PARSER_CHECK_NONE);
+ CU_ASSERT_EQUAL(lwgeom_count_vertices(lwgeom),7);
+ g_ser1 = gserialized_from_lwgeom(lwgeom, &ret_size);
+ lwgeom_free(lwgeom);
+ lwgeom = lwgeom_from_gserialized(g_ser1);
+ lwfree(g_ser1);
+static void test_lwcollection_extract(void)
+ LWGEOM *geom;
+ LWCOLLECTION *col;
+ geom = lwgeom_from_wkt("GEOMETRYCOLLECTION(POINT(0 0))", LW_PARSER_CHECK_NONE);
+ col = lwcollection_extract((LWCOLLECTION*)geom, 1);
+ CU_ASSERT_EQUAL(col->type, MULTIPOINTTYPE);
+ lwcollection_free(col);
+ col = lwcollection_extract((LWCOLLECTION*)geom, 2);
+ CU_ASSERT_EQUAL(col->type, MULTILINETYPE);
+ col = lwcollection_extract((LWCOLLECTION*)geom, 3);
+ CU_ASSERT_EQUAL(col->type, MULTIPOLYGONTYPE);
+ geom = lwgeom_from_wkt("GEOMETRYCOLLECTION EMPTY", LW_PARSER_CHECK_NONE);
+static void test_lwgeom_free(void)
+ LWGEOM *geom;
+ /* Empty geometries don't seem to free properly (#370) */
+ CU_ASSERT_EQUAL(geom->type, COLLECTIONTYPE);
+ geom = lwgeom_from_wkt("POLYGON EMPTY", LW_PARSER_CHECK_NONE);
+ CU_ASSERT_EQUAL(geom->type, POLYGONTYPE);
+ geom = lwgeom_from_wkt("LINESTRING EMPTY", LW_PARSER_CHECK_NONE);
+ CU_ASSERT_EQUAL(geom->type, LINETYPE);
+ geom = lwgeom_from_wkt("POINT EMPTY", LW_PARSER_CHECK_NONE);
+ CU_ASSERT_EQUAL(geom->type, POINTTYPE);
+static void do_lwgeom_swap_ordinates(char *in, char *out)
+ LWGEOM *g;
+ char * t;
+ double xmax, ymax;
+ int testbox;
+ g = lwgeom_from_wkt(in, LW_PARSER_CHECK_NONE);
+ lwgeom_add_bbox(g);
+ testbox = (g->bbox != NULL);
+ if ( testbox )
+ xmax = g->bbox->xmax;
+ ymax = g->bbox->ymax;
+ lwgeom_swap_ordinates(g,LWORD_X,LWORD_Y);
+ if ( testbox )
+ CU_ASSERT_DOUBLE_EQUAL(g->bbox->xmax, ymax, 0.00001);
+ CU_ASSERT_DOUBLE_EQUAL(g->bbox->ymax, xmax, 0.00001);
+ t = lwgeom_to_wkt(g, WKT_EXTENDED, 8, NULL);
+ if (t == NULL) fprintf(stderr, "In:%s", in);
+ if (strcmp(t, out))
+ fprintf(stderr, "\nIn: %s\nOut: %s\nTheo: %s\n", in, t, out);
+ CU_ASSERT_STRING_EQUAL(t, out)
+ lwgeom_free(g);
+ lwfree(t);
+static void test_lwgeom_swap_ordinates(void)
+ * 2D geometries types
+ do_lwgeom_swap_ordinates(
+ "POINT(1 2)",
+ "POINT(2 1)"
+ "LINESTRING(1 2,3 4)",
+ "LINESTRING(2 1,4 3)"
+ "POLYGON((1 2,3 4,5 6,1 2))",
+ "POLYGON((2 1,4 3,6 5,2 1))"
+ "POLYGON((1 2,3 4,5 6,1 2),(7 8,9 10,11 12,7 8))",
+ "POLYGON((2 1,4 3,6 5,2 1),(8 7,10 9,12 11,8 7))"
+ "MULTIPOINT(1 2,3 4)",
+ "MULTIPOINT(2 1,4 3)"
+ "MULTILINESTRING((1 2,3 4),(5 6,7 8))",
+ "MULTILINESTRING((2 1,4 3),(6 5,8 7))"
+ "MULTIPOLYGON(((1 2,3 4,5 6,7 8)),((9 10,11 12,13 14,10 9)))",
+ "MULTIPOLYGON(((2 1,4 3,6 5,8 7)),((10 9,12 11,14 13,9 10)))"
+ "GEOMETRYCOLLECTION EMPTY",
+ "GEOMETRYCOLLECTION(POINT(1 2),LINESTRING(3 4,5 6))",
+ "GEOMETRYCOLLECTION(POINT(2 1),LINESTRING(4 3,6 5))"
+ "GEOMETRYCOLLECTION(POINT(1 2),GEOMETRYCOLLECTION(LINESTRING(3 4,5 6)))",
+ "GEOMETRYCOLLECTION(POINT(2 1),GEOMETRYCOLLECTION(LINESTRING(4 3,6 5)))"
+ "CIRCULARSTRING(-2 0,0 2,2 0,0 2,2 4)",
+ "CIRCULARSTRING(0 -2,2 0,0 2,2 0,4 2)"
+ "COMPOUNDCURVE(CIRCULARSTRING(0 1,1 1,1 0),(1 0,0 1))",
+ "COMPOUNDCURVE(CIRCULARSTRING(1 0,1 1,0 1),(0 1,1 0))"
+ "CURVEPOLYGON(CIRCULARSTRING(-2 0,-1 -1,0 0,1 -1,2 0,0 2,-2 0),(-1 0,0 0.5,1 0,0 1,-1 0))",
+ "CURVEPOLYGON(CIRCULARSTRING(0 -2,-1 -1,0 0,-1 1,0 2,2 0,0 -2),(0 -1,0.5 0,0 1,1 0,0 -1))"
+ "MULTICURVE((5 5,3 5,3 3,0 3),CIRCULARSTRING(0 0,2 1,2 3))",
+ "MULTICURVE((5 5,5 3,3 3,3 0),CIRCULARSTRING(0 0,1 2,3 2))"
+ "MULTISURFACE(CURVEPOLYGON(CIRCULARSTRING(0 -2,-1 -1,0 0,-1 1,0 2,2 0,0 -2),(0 -1,0.5 0,0 1,1 0,0 -1)),((8 7,10 10,14 6,11 4,8 7)))"
+ * Ndims
+ "POINT(1 2 3)",
+ "POINT(2 1 3)"
+ "POINTM(1 2 3)",
+ "POINTM(2 1 3)"
+ "POINT(1 2 3 4)",
+ "POINT(2 1 3 4)"
+ * Srid
+ "SRID=4326;POINT(1 2)",
+ "SRID=4326;POINT(2 1)"
+ "SRID=0;POINT(1 2)",
+ "POINT(2 1)"
+static void test_f2d(void)
+ double d = 1000000.123456789123456789;
+ float f;
+ double e;
+ f = next_float_down(d);
+ d = next_float_down(f);
+ CU_ASSERT_DOUBLE_EQUAL(f,d, 0.0000001);
+ e = (double)f;
+ CU_ASSERT_DOUBLE_EQUAL(f,e, 0.0000001);
+ f = next_float_up(d);
+ d = next_float_up(f);
+ d = DBL_MAX;
+ CU_ASSERT_DOUBLE_EQUAL(f, d, 0.0000001);
+ d = DBL_MAX;
+ d = -DBL_MAX;
+ d = -DBL_MAX;
+ * This is a test for memory leaks, can't really test
+ * w/out checking with a leak detector (ie: valgrind)
+ * See http://trac.osgeo.org/postgis/ticket/1102
+static void test_lwgeom_clone(void)
+ size_t i;
+ char *ewkt[] =
+ "POINT(0 0.2)",
+ "TIN(((0 0 0,0 0 1,0 1 0,0 0 0)),((0 0 0,0 1 0,1 0 0,0 0 0)),((0 0 0,1 0 0,0 0 1,0 0 0)),((1 0 0,0 1 0,0 0 1,1 0 0)))"
+ for ( i = 0; i < (sizeof ewkt/sizeof(char *)); i++ )
+ LWGEOM *geom, *cloned;
+ char *in_ewkt;
+ char *out_ewkt;
+ cloned = lwgeom_clone(geom);
+ out_ewkt = lwgeom_to_ewkt(cloned);
+ if (strcmp(in_ewkt, out_ewkt))
+ fprintf(stderr, "\nExp: %s\nObt: %s\n", in_ewkt, out_ewkt);
+ lwfree(out_ewkt);
+ lwgeom_free(cloned);
+ * Test lwgeom_force_clockwise
+static void test_lwgeom_force_clockwise(void)
+ LWGEOM *geom;
+ LWGEOM *geom2;
+ char *in_ewkt, *out_ewkt;
+ /* counterclockwise, must be reversed */
+ geom = lwgeom_from_wkt("POLYGON((0 0, 10 0, 10 10, 0 10, 0 0))", LW_PARSER_CHECK_NONE);
+ CU_ASSERT_FALSE(lwgeom_is_clockwise(geom));
+ lwgeom_force_clockwise(geom);
+ in_ewkt = "POLYGON((0 0,0 10,10 10,10 0,0 0))";
+ out_ewkt = lwgeom_to_ewkt(geom);
+ lwfree(out_ewkt);
+ /* clockwise, fine as is */
+ geom = lwgeom_from_wkt("POLYGON((0 0, 0 10, 10 10, 10 0, 0 0))", LW_PARSER_CHECK_NONE);
+ CU_ASSERT_TRUE(lwgeom_is_clockwise(geom));
+ lwfree(out_ewkt);
+ /* counterclockwise shell (must be reversed), mixed-wise holes */
+ geom = lwgeom_from_wkt("POLYGON((0 0,10 0,10 10,0 10,0 0),(2 2,2 4,4 2,2 2),(6 2,8 2,8 4,6 2))", LW_PARSER_CHECK_NONE);
+ in_ewkt = "POLYGON((0 0,0 10,10 10,10 0,0 0),(2 2,4 2,2 4,2 2),(6 2,8 2,8 4,6 2))";
+ lwfree(out_ewkt);
+ /* clockwise shell (fine), mixed-wise holes */
+ geom = lwgeom_from_wkt("POLYGON((0 0,0 10,10 10,10 0,0 0),(2 2,4 2,2 4,2 2),(6 2,8 4,8 2,6 2))", LW_PARSER_CHECK_NONE);
+ lwfree(out_ewkt);
+ /* clockwise narrow ring, fine as-is */
+ /* NOTE: this is a narrow ring, see ticket #1302 */
+ in_ewkt = "0103000000010000000500000000917E9BA468294100917E9B8AEA2841C976BE1FA4682941C976BE9F8AEA2841B39ABE1FA46829415ACCC29F8AEA284137894120A4682941C976BE9F8AEA284100917E9BA468294100917E9B8AEA2841";
+ geom = lwgeom_from_hexwkb(in_ewkt, LW_PARSER_CHECK_NONE);
+ geom2 = lwgeom_from_hexwkb(in_ewkt, LW_PARSER_CHECK_NONE);
+ lwgeom_force_clockwise(geom2);
+ /** use same check instead of strcmp to account
+ for difference in endianness **/
+ CU_ASSERT( lwgeom_same(geom, geom2) );
+ * Test lwgeom_is_empty
+static void test_lwgeom_is_empty(void)
+ LWGEOM *geom;
+ CU_ASSERT( !lwgeom_is_empty(geom) );
+ CU_ASSERT( lwgeom_is_empty(geom) );
+ geom = lwgeom_from_wkt("MULTIPOINT EMPTY", LW_PARSER_CHECK_NONE);
+ geom = lwgeom_from_wkt("MULTILINESTRING EMPTY", LW_PARSER_CHECK_NONE);
+ geom = lwgeom_from_wkt("MULTIPOLYGON EMPTY", LW_PARSER_CHECK_NONE);
+ geom = lwgeom_from_wkt("GEOMETRYCOLLECTION(GEOMETRYCOLLECTION EMPTY, POINT EMPTY, LINESTRING EMPTY, POLYGON EMPTY, MULTIPOINT EMPTY, MULTILINESTRING EMPTY, MULTIPOLYGON EMPTY, GEOMETRYCOLLECTION(MULTIPOLYGON EMPTY))", LW_PARSER_CHECK_NONE);
+ * Test lwgeom_same
+static void test_lwgeom_same(void)
+ LWGEOM *geom, *geom2;
+ CU_ASSERT( lwgeom_same(geom, geom) );
+ geom = lwgeom_from_wkt("MULTIPOLYGON(((0 0, 10 0, 10 10, 0 10, 0 0)))", LW_PARSER_CHECK_NONE);
+ geom = lwgeom_from_wkt("LINESTRING(0 0, 2 0)", LW_PARSER_CHECK_NONE);
+ geom = lwgeom_from_wkt("MULTILINESTRING((0 0, 2 0))", LW_PARSER_CHECK_NONE);
+ geom = lwgeom_from_wkt("POINT(0 0)", LW_PARSER_CHECK_NONE);
+ geom = lwgeom_from_wkt("MULTIPOINT((0 0),(4 5))", LW_PARSER_CHECK_NONE);
+ geom2 = lwgeom_from_wkt("GEOMETRYCOLLECTION(GEOMETRYCOLLECTION EMPTY, POINT EMPTY, LINESTRING EMPTY, POLYGON EMPTY, MULTIPOINT EMPTY, MULTILINESTRING EMPTY, MULTIPOLYGON EMPTY, GEOMETRYCOLLECTION(MULTIPOLYGON EMPTY))", LW_PARSER_CHECK_NONE);
+ CU_ASSERT( ! lwgeom_same(geom, geom2) );
+ geom2 = lwgeom_from_wkt("MULTIPOINT((0 0))", LW_PARSER_CHECK_NONE);
+ geom2 = lwgeom_from_wkt("POINT Z EMPTY", LW_PARSER_CHECK_NONE);
+ * Test lwgeom_force_curve
+static void test_lwgeom_as_curve(void)
+ LWGEOM *geom;
+ LWGEOM *geom2;
+ geom = lwgeom_from_wkt("LINESTRING(0 0, 10 0)", LW_PARSER_CHECK_NONE);
+ geom2 = lwgeom_as_curve(geom);
+ in_ewkt = "COMPOUNDCURVE((0 0,10 0))";
+ lwfree(out_ewkt);
+ geom = lwgeom_from_wkt("MULTILINESTRING((0 0, 10 0))", LW_PARSER_CHECK_NONE);
+ in_ewkt = "MULTICURVE((0 0,10 0))";
+ lwfree(out_ewkt);
+ in_ewkt = "CURVEPOLYGON((0 0,10 0,10 10,0 10,0 0))";
+ lwfree(out_ewkt);
+ in_ewkt = "MULTISURFACE(((0 0,10 0,10 10,0 10,0 0)))";
+ lwfree(out_ewkt);
+static void test_lwline_from_lwmpoint(void)
+ LWLINE *line;
+ LWMPOINT *mpoint;
+ mpoint = (LWMPOINT*)lwgeom_from_wkt("MULTIPOINT(0 0, 0 1, 1 1, 1 2, 2 2)", LW_PARSER_CHECK_NONE);
+ line = lwline_from_lwmpoint(SRID_DEFAULT, mpoint);
+ CU_ASSERT_EQUAL(line->points->npoints, mpoint->ngeoms);
+ CU_ASSERT_DOUBLE_EQUAL(lwline_length_2d(line), 4.0, 0.000001);
+ lwline_free(line);
+ lwmpoint_free(mpoint);
+ * Test lwgeom_scale
+static void test_lwgeom_scale(void)
+ LWGEOM *geom;
+ POINT4D factor;
+ char *out_ewkt;
+ GBOX *box;
+ geom = lwgeom_from_wkt("SRID=4326;GEOMETRYCOLLECTION(POINT(0 1 2 3),POLYGON((-1 -1 0 1,-1 2.5 0 1,2 2 0 1,2 -1 0 1,-1 -1 0 1),(0 0 1 2,0 1 1 2,1 1 1 2,1 0 2 3,0 0 1 2)),LINESTRING(0 0 0 0, 1 2 3 4))", LW_PARSER_CHECK_NONE);
+ factor.x = 2; factor.y = 3; factor.z = 4; factor.m = 5;
+ lwgeom_scale(geom, &factor);
+ ASSERT_STRING_EQUAL(out_ewkt, "SRID=4326;GEOMETRYCOLLECTION(POINT(0 3 8 15),POLYGON((-2 -3 0 5,-2 7.5 0 5,4 6 0 5,4 -3 0 5,-2 -3 0 5),(0 0 4 10,0 3 4 10,2 3 4 10,2 0 8 15,0 0 4 10)),LINESTRING(0 0 0 0,2 6 12 20))");
+ lwfree(out_ewkt);
+ geom = lwgeom_from_wkt("POINT(1 1 1 1)", LW_PARSER_CHECK_NONE);
+ box = geom->bbox;
+ ASSERT_DOUBLE_EQUAL(box->xmin, 2);
+ ASSERT_DOUBLE_EQUAL(box->xmax, 2);
+ ASSERT_DOUBLE_EQUAL(box->ymin, 3);
+ ASSERT_DOUBLE_EQUAL(box->ymax, 3);
+ ASSERT_DOUBLE_EQUAL(box->zmin, 4);
+ ASSERT_DOUBLE_EQUAL(box->zmax, 4);
+ ASSERT_DOUBLE_EQUAL(box->mmin, 5);
+ ASSERT_DOUBLE_EQUAL(box->mmax, 5);
+void test_gbox_same_2d(void);
+ LWGEOM* g1 = lwgeom_from_wkt("LINESTRING(0 0, 1 1)", LW_PARSER_CHECK_NONE);
+ LWGEOM* g2 = lwgeom_from_wkt("LINESTRING(0 0, 0 1, 1 1)", LW_PARSER_CHECK_NONE);
+ LWGEOM* g3 = lwgeom_from_wkt("LINESTRING(0 0, 1 1.000000000001)", LW_PARSER_CHECK_NONE);
+ lwgeom_add_bbox(g1);
+ lwgeom_add_bbox(g2);
+ lwgeom_add_bbox(g3);
+ CU_ASSERT_TRUE(gbox_same_2d(g1->bbox, g2->bbox));
+ CU_ASSERT_FALSE(gbox_same_2d(g1->bbox, g3->bbox));
+ /* Serializing a GBOX with precise coordinates renders the boxes not strictly equal,
+ * but still equal according to gbox_same_2d_float.
+ GSERIALIZED* s3 = gserialized_from_lwgeom(g3, NULL);
+ GBOX s3box;
+ gserialized_read_gbox_p(s3, &s3box);
+ CU_ASSERT_FALSE(gbox_same_2d(g3->bbox, &s3box));
+ CU_ASSERT_TRUE(gbox_same_2d_float(g3->bbox, &s3box));
+ /* The serialized box equals itself by either the exact or closest-float compares */
+ CU_ASSERT_TRUE(gbox_same_2d(&s3box, &s3box));
+ CU_ASSERT_TRUE(gbox_same_2d_float(&s3box, &s3box));
+ lwgeom_free(g1);
+ lwgeom_free(g2);
+ lwgeom_free(g3);
+ lwfree(s3);
+void test_gserialized_peek_gbox_p_no_box_when_empty(void);
+ uint32_t i;
+ char *ewkt[] =
+ "POINT EMPTY",
+ "MULTIPOINT (EMPTY)",
+ "MULTILINESTRING EMPTY",
+ "MULTILINESTRING (EMPTY)"
+ LWGEOM* geom = lwgeom_from_wkt(ewkt[i], LW_PARSER_CHECK_NONE);
+ GBOX box;
+ gbox_init(&box);
+ GSERIALIZED* gser = gserialized_from_lwgeom(geom, NULL);
+ CU_ASSERT_FALSE(gserialized_has_bbox(gser));
+ CU_ASSERT_EQUAL(LW_FAILURE, gserialized_peek_gbox_p(gser, &box));
+ lwfree(gser);
+void test_gserialized_peek_gbox_p_gets_correct_box(void);
+ uint32_t i;
+ char *ewkt[] =
+ "POINT (2.2945672355 48.85822923236)",
+ "POINTZ (2.2945672355 48.85822923236 15)",
+ "POINTM (2.2945672355 48.85822923236 12)",
+ "POINT ZM (2.2945672355 48.85822923236 12 2)",
+ "MULTIPOINT ((-76.45402132523 44.225406213532))",
+ "MULTIPOINT Z ((-76.45402132523 44.225406213532 112))",
+ "MULTIPOINT ZM ((-76.45402132523 44.225406213532 112 44))",
+ "LINESTRING (2.2945672355 48.85822923236, -76.45402132523 44.225406213532)",
+ "LINESTRING Z (2.2945672355 48.85822923236 6, -76.45402132523 44.225406213532 8)",
+ "LINESTRING ZM (2.2945672355 48.85822923236 3 2, -76.45402132523 44.225406213532 9 4)",
+ "MULTILINESTRING ((2.2945672355 48.85822923236, -76.45402132523 44.225406213532))",
+ "MULTILINESTRING Z ((2.2945672355 48.85822923236 4, -76.45402132523 44.225406213532 3))"
+ GBOX box_from_peek;
+ GBOX box_from_lwgeom;
+ gbox_init(&box_from_peek);
+ gbox_init(&box_from_lwgeom);
+ lwgeom_calculate_gbox(geom, &box_from_lwgeom);
+ gserialized_peek_gbox_p(gser, &box_from_peek);
+ gbox_float_round(&box_from_lwgeom);
+ CU_ASSERT_TRUE(gbox_same(&box_from_peek, &box_from_lwgeom));
+ lwfree(gser);
+void test_gserialized_peek_gbox_p_fails_for_unsupported_cases(void);
+ uint32_t i;
+ char *ewkt[] =
+ "MULTIPOINT ((-76.45402132523 44.225406213532), (-72 33))",
+ "LINESTRING (2.2945672355 48.85822923236, -76.45402132523 44.225406213532, -72 33)",
+ "MULTILINESTRING ((2.2945672355 48.85822923236, -76.45402132523 44.225406213532, -72 33))",
+ "MULTILINESTRING ((2.2945672355 48.85822923236, -76.45402132523 44.225406213532), (-72 33, -71 32))"
+ GBOX box;
+ gbox_init(&box);
+ lwgeom_drop_bbox(geom);
+ /* Construct a GSERIALIZED* that doesn't have a box, so that we can test the
+ * actual logic of the peek function */
+ size_t expected_size = gserialized_from_lwgeom_size(geom);
+ GSERIALIZED* gser = lwalloc(expected_size);
+ uint8_t* ptr = (uint8_t*) gser;
+ ptr += 8; // Skip header
+ gserialized_from_lwgeom_any(geom, ptr);
+ gser->flags = geom->flags;
+ lwfree(gser);
+void test_signum_macro(void);
+ CU_ASSERT_EQUAL(SIGNUM(-5.0),-1);
+ CU_ASSERT_EQUAL(SIGNUM( 5.0), 1);
+ CU_ASSERT_EQUAL(SIGNUM( 0.0), 0);
+ CU_ASSERT_EQUAL(SIGNUM(10) * 5, 5);
+ CU_ASSERT_EQUAL(SIGNUM(-10) * 5, -5);
+** Used by test harness to register the tests in this file.
+void libgeom_suite_setup(void);
+ CU_pSuite suite = CU_add_suite("serialization/deserialization", NULL, NULL);
+ PG_ADD_TEST(suite, test_typmod_macros);
+ PG_ADD_TEST(suite, test_flags_macros);
+ PG_ADD_TEST(suite, test_serialized_srid);
+ PG_ADD_TEST(suite, test_gserialized_from_lwgeom_size);
+ PG_ADD_TEST(suite, test_gbox_serialized_size);
+ PG_ADD_TEST(suite, test_lwgeom_from_gserialized);
+ PG_ADD_TEST(suite, test_lwgeom_count_vertices);
+ PG_ADD_TEST(suite, test_on_gser_lwgeom_count_vertices);
+ PG_ADD_TEST(suite, test_geometry_type_from_string);
+ PG_ADD_TEST(suite, test_lwcollection_extract);
+ PG_ADD_TEST(suite, test_lwgeom_free);
+ PG_ADD_TEST(suite, test_lwgeom_swap_ordinates);
+ PG_ADD_TEST(suite, test_f2d);
+ PG_ADD_TEST(suite, test_lwgeom_clone);
+ PG_ADD_TEST(suite, test_lwgeom_force_clockwise);
+ PG_ADD_TEST(suite, test_lwgeom_calculate_gbox);
+ PG_ADD_TEST(suite, test_lwgeom_is_empty);
+ PG_ADD_TEST(suite, test_lwgeom_same);
+ PG_ADD_TEST(suite, test_lwline_from_lwmpoint);
+ PG_ADD_TEST(suite, test_lwgeom_as_curve);
+ PG_ADD_TEST(suite, test_lwgeom_scale);
+ PG_ADD_TEST(suite, test_gserialized_is_empty);
+ PG_ADD_TEST(suite, test_gserialized_peek_gbox_p_no_box_when_empty);
+ PG_ADD_TEST(suite, test_gserialized_peek_gbox_p_gets_correct_box);
+ PG_ADD_TEST(suite, test_gserialized_peek_gbox_p_fails_for_unsupported_cases);
+ PG_ADD_TEST(suite, test_gbox_same_2d);
+ PG_ADD_TEST(suite, test_signum_macro);
Deleted: trunk/liblwgeom/cunit/cu_libgeom.c
--- trunk/liblwgeom/cunit/cu_libgeom.c 2019-06-11 18:31:23 UTC (rev 17499)
+++ trunk/liblwgeom/cunit/cu_libgeom.c 2019-06-11 18:39:07 UTC (rev 17500)
@@ -1,1266 +0,0 @@
- * PostGIS - Spatial Types for PostgreSQL
- * http://postgis.net
- * Copyright 2009 Paul Ramsey <pramsey at cleverelephant.ca>
- * This is free software; you can redistribute and/or modify it under
- * the terms of the GNU General Public Licence. See the COPYING file.
-#include <stdio.h>
-#include <stdlib.h>
-#include <string.h>
-#include "CUnit/Basic.h"
-#include "liblwgeom_internal.h"
-#include "g_serialized.c" /* for gserialized_peek_gbox_p */
-#include "cu_tester.h"
-static void test_typmod_macros(void)
- int32_t typmod = 0;
- int32_t srid = 4326;
- int type = 6;
- int z = 1;
- int rv;
- TYPMOD_SET_SRID(typmod,srid);
- rv = TYPMOD_GET_SRID(typmod);
- CU_ASSERT_EQUAL(rv, srid);
- srid = -5005;
- srid = 999999;
- srid = -999999;
- srid = SRID_UNKNOWN;
- srid = 0;
- srid = 1;
- TYPMOD_SET_TYPE(typmod,type);
- rv = TYPMOD_GET_TYPE(typmod);
- CU_ASSERT_EQUAL(rv,type);
- TYPMOD_SET_Z(typmod);
- rv = TYPMOD_GET_Z(typmod);
- CU_ASSERT_EQUAL(rv,z);
- rv = TYPMOD_GET_M(typmod);
- CU_ASSERT_EQUAL(rv,0);
-static void test_flags_macros(void)
- uint8_t flags = 0;
- CU_ASSERT_EQUAL(0, FLAGS_GET_Z(flags));
- FLAGS_SET_Z(flags, 1);
- CU_ASSERT_EQUAL(1, FLAGS_GET_Z(flags));
- FLAGS_SET_Z(flags, 0);
- CU_ASSERT_EQUAL(0, FLAGS_GET_BBOX(flags));
- CU_ASSERT_EQUAL(0, FLAGS_GET_M(flags));
- FLAGS_SET_M(flags, 1);
- CU_ASSERT_EQUAL(1, FLAGS_GET_M(flags));
- FLAGS_SET_BBOX(flags, 1);
- CU_ASSERT_EQUAL(1, FLAGS_GET_BBOX(flags));
- CU_ASSERT_EQUAL(0, FLAGS_GET_READONLY(flags));
- FLAGS_SET_READONLY(flags, 1);
- CU_ASSERT_EQUAL(1, FLAGS_GET_READONLY(flags));
- FLAGS_SET_READONLY(flags, 0);
- CU_ASSERT_EQUAL(0, FLAGS_GET_GEODETIC(flags));
- FLAGS_SET_GEODETIC(flags, 1);
- CU_ASSERT_EQUAL(1, FLAGS_GET_GEODETIC(flags));
- flags = gflags(1, 0, 1); /* z=1, m=0, geodetic=1 */
- CU_ASSERT_EQUAL(2, FLAGS_GET_ZM(flags));
- flags = gflags(1, 1, 1); /* z=1, m=1, geodetic=1 */
- CU_ASSERT_EQUAL(3, FLAGS_GET_ZM(flags));
- flags = gflags(0, 1, 0); /* z=0, m=1, geodetic=0 */
- CU_ASSERT_EQUAL(1, FLAGS_GET_ZM(flags));
-static void test_serialized_srid(void)
- GSERIALIZED s;
- int32_t srid, rv;
- srid = 4326;
- gserialized_set_srid(&s, srid);
- rv = gserialized_get_srid(&s);
- srid = -3005;
- //printf("srid=%d rv=%d\n",srid,rv);
- CU_ASSERT_EQUAL(rv, SRID_UNKNOWN);
- srid = 100000;
-static void test_gserialized_from_lwgeom_size(void)
- LWGEOM *g;
- size_t size = 0;
- g = lwgeom_from_wkt("POINT(0 0)", LW_PARSER_CHECK_NONE);
- size = gserialized_from_lwgeom_size(g);
- CU_ASSERT_EQUAL( size, 32 );
- lwgeom_free(g);
- g = lwgeom_from_wkt("POINT(0 0 0)", LW_PARSER_CHECK_NONE);
- CU_ASSERT_EQUAL( size, 40 );
- lwgeom_free(g);
- g = lwgeom_from_wkt("MULTIPOINT(0 0 0, 1 1 1)", LW_PARSER_CHECK_NONE);
- CU_ASSERT_EQUAL( size, 80 );
- lwgeom_free(g);
- g = lwgeom_from_wkt("LINESTRING(0 0, 1 1)", LW_PARSER_CHECK_NONE);
- CU_ASSERT_EQUAL( size, 48 );
- lwgeom_free(g);
- g = lwgeom_from_wkt("MULTILINESTRING((0 0, 1 1),(0 0, 1 1))", LW_PARSER_CHECK_NONE);
- CU_ASSERT_EQUAL( size, 96 );
- lwgeom_free(g);
- g = lwgeom_from_wkt("POLYGON((0 0, 0 1, 1 1, 1 0, 0 0))", LW_PARSER_CHECK_NONE);
- CU_ASSERT_EQUAL( size, 104 );
- lwgeom_free(g);
- g = lwgeom_from_wkt("POLYGON((-1 -1, -1 2, 2 2, 2 -1, -1 -1), (0 0, 0 1, 1 1, 1 0, 0 0))", LW_PARSER_CHECK_NONE);
- CU_ASSERT_EQUAL( size, 184 );
- lwgeom_free(g);
-static void test_lwgeom_calculate_gbox(void)
- LWGEOM *g;
- GBOX b;
- lwgeom_calculate_gbox_cartesian(g, &b);
- CU_ASSERT_DOUBLE_EQUAL(b.xmin, 0.0, 0.0000001);
- lwgeom_free(g);
- /* Inf = 0x7FF0000000000000 */
- /* POINT(0 0) = 00 00000001 0000000000000000 0000000000000000 */
- /* POINT(0 Inf) = 00 00000001 0000000000000000 7FF0000000000000 */
- g = lwgeom_from_hexwkb("000000000100000000000000007FF0000000000000", LW_PARSER_CHECK_NONE);
- CU_ASSERT(isinf(b.ymax));
- lwgeom_free(g);
- /* LINESTRING(0 0, 0 Inf) = 00 00000002 00000002 0000000000000000 7FF0000000000000 0000000000000000 0000000000000000 */
- /* Inf should show up in bbox */
- g = lwgeom_from_hexwkb("00000000020000000200000000000000007FF000000000000000000000000000000000000000000000", LW_PARSER_CHECK_NONE);
- lwgeom_free(g);
- /* Geometry with NaN 0101000020E8640000000000000000F8FF000000000000F8FF */
- /* NaN should show up in bbox for "SRID=4326;POINT(0 NaN)" */
- g = lwgeom_from_hexwkb("0101000020E86400000000000000000000000000000000F8FF", LW_PARSER_CHECK_NONE);
- CU_ASSERT(isnan(b.ymax));
- lwgeom_free(g);
-static void test_gbox_serialized_size(void)
- uint8_t flags = gflags(0, 0, 0);
- CU_ASSERT_EQUAL(gbox_serialized_size(flags),16);
- CU_ASSERT_EQUAL(gbox_serialized_size(flags),24);
- CU_ASSERT_EQUAL(gbox_serialized_size(flags),32);
-static void test_lwgeom_from_gserialized(void)
- LWGEOM *geom;
- GSERIALIZED *g;
- char *in_ewkt;
- char *out_ewkt;
- size_t i = 0;
- char *ewkt[] =
- "POINT EMPTY",
- "POINT(0 0.2)",
- "LINESTRING EMPTY",
- "LINESTRING(-1 -1,-1 2.5,2 2,2 -1)",
- "MULTIPOINT EMPTY",
- "MULTIPOINT(0.9 0.9,0.9 0.9,0.9 0.9,0.9 0.9,0.9 0.9,0.9 0.9)",
- "SRID=1;MULTILINESTRING EMPTY",
- "SRID=1;MULTILINESTRING((-1 -1,-1 2.5,2 2,2 -1),(-1 -1,-1 2.5,2 2,2 -1),(-1 -1,-1 2.5,2 2,2 -1),(-1 -1,-1 2.5,2 2,2 -1))",
- "POLYGON((-1 -1,-1 2.5,2 2,2 -1,-1 -1),(0 0,0 1,1 1,1 0,0 0))",
- "POLYGON EMPTY",
- "SRID=4326;POLYGON((-1 -1,-1 2.5,2 2,2 -1,-1 -1),(0 0,0 1,1 1,1 0,0 0))",
- "SRID=4326;POLYGON EMPTY",
- "SRID=4326;POLYGON((-1 -1,-1 2.5,2 2,2 -1,-1 -1),(0 0,0 1,1 1,1 0,0 0),(-0.5 -0.5,-0.5 -0.4,-0.4 -0.4,-0.4 -0.5,-0.5 -0.5))",
- "SRID=100000;POLYGON((-1 -1 3,-1 2.5 3,2 2 3,2 -1 3,-1 -1 3),(0 0 3,0 1 3,1 1 3,1 0 3,0 0 3),(-0.5 -0.5 3,-0.5 -0.4 3,-0.4 -0.4 3,-0.4 -0.5 3,-0.5 -0.5 3))",
- "SRID=4326;MULTIPOLYGON(((-1 -1,-1 2.5,2 2,2 -1,-1 -1),(0 0,0 1,1 1,1 0,0 0),(-0.5 -0.5,-0.5 -0.4,-0.4 -0.4,-0.4 -0.5,-0.5 -0.5)),((-1 -1,-1 2.5,2 2,2 -1,-1 -1),(0 0,0 1,1 1,1 0,0 0),(-0.5 -0.5,-0.5 -0.4,-0.4 -0.4,-0.4 -0.5,-0.5 -0.5)))",
- "SRID=4326;MULTIPOLYGON EMPTY",
- "SRID=4326;GEOMETRYCOLLECTION(POINT(0 1),POLYGON((-1 -1,-1 2.5,2 2,2 -1,-1 -1),(0 0,0 1,1 1,1 0,0 0)),MULTIPOLYGON(((-1 -1,-1 2.5,2 2,2 -1,-1 -1),(0 0,0 1,1 1,1 0,0 0),(-0.5 -0.5,-0.5 -0.4,-0.4 -0.4,-0.4 -0.5,-0.5 -0.5))))",
- "SRID=4326;GEOMETRYCOLLECTION EMPTY",
- "SRID=4326;GEOMETRYCOLLECTION(POINT EMPTY,MULTIPOLYGON EMPTY)",
- "MULTICURVE((5 5 1 3,3 5 2 2,3 3 3 1,0 3 1 1),CIRCULARSTRING(0 0 0 0,0.26794 1 3 -2,0.5857864 1.414213 1 2))",
- "MULTISURFACE(CURVEPOLYGON(CIRCULARSTRING(-2 0,-1 -1,0 0,1 -1,2 0,0 2,-2 0),(-1 0,0 0.5,1 0,0 1,-1 0)),((7 8,10 10,6 14,4 11,7 8)))",
- "MULTISURFACE(CURVEPOLYGON(CIRCULARSTRING EMPTY))",
- for ( i = 0; i < (sizeof ewkt/sizeof(char*)); i++ )
- LWGEOM* geom2;
- in_ewkt = ewkt[i];
- geom = lwgeom_from_wkt(in_ewkt, LW_PARSER_CHECK_NONE);
- lwgeom_add_bbox(geom);
- if ( geom->bbox ) gbox_float_round(geom->bbox);
- g = gserialized_from_lwgeom(geom, 0);
- geom2 = lwgeom_from_gserialized(g);
- out_ewkt = lwgeom_to_ewkt(geom2);
- /* printf("\n in = %s\nout = %s\n", in_ewkt, out_ewkt); */
- CU_ASSERT_STRING_EQUAL(in_ewkt, out_ewkt);
- /* either both or none of the bboxes are null */
- CU_ASSERT( (geom->bbox != NULL) || (geom2->bbox == NULL) );
- /* either both are null or they are the same */
- CU_ASSERT(geom->bbox == NULL || gbox_same(geom->bbox, geom2->bbox));
- lwgeom_free(geom);
- lwgeom_free(geom2);
- lwfree(g);
- lwfree(out_ewkt);
-static void test_gserialized_is_empty(void)
- int i = 0;
- struct gserialized_empty_cases {
- const char* wkt;
- int isempty;
- struct gserialized_empty_cases cases[] = {
- { "POINT EMPTY", 1 },
- { "POINT(1 1)", 0 },
- { "LINESTRING EMPTY", 1 },
- { "MULTILINESTRING EMPTY", 1 },
- { "MULTILINESTRING(EMPTY)", 1 },
- { "MULTILINESTRING(EMPTY,EMPTY)", 1 },
- { "MULTILINESTRING(EMPTY,(0 0,1 1))", 0 },
- { "MULTILINESTRING((0 0,1 1),EMPTY)", 0 },
- { "MULTILINESTRING(EMPTY,(0 0,1 1),EMPTY)", 0 },
- { "MULTILINESTRING(EMPTY,EMPTY,EMPTY)", 1 },
- { "GEOMETRYCOLLECTION(POINT EMPTY,MULTILINESTRING(EMPTY,EMPTY,EMPTY))", 1 },
- { "GEOMETRYCOLLECTION(POINT EMPTY,MULTILINESTRING(EMPTY),POINT(1 1))", 0 },
- { "GEOMETRYCOLLECTION(POINT EMPTY,MULTILINESTRING(EMPTY, (0 0)),POINT EMPTY)", 0 },
- { "GEOMETRYCOLLECTION(POLYGON EMPTY,POINT EMPTY,MULTILINESTRING(EMPTY,EMPTY),POINT EMPTY)", 1 },
- { "GEOMETRYCOLLECTION(POLYGON EMPTY,GEOMETRYCOLLECTION(POINT EMPTY),MULTILINESTRING(EMPTY,EMPTY),POINT EMPTY)", 1 },
- { NULL, 0 }
- while( cases[i].wkt )
- // i = 11;
- LWGEOM *lw = lwgeom_from_wkt(cases[i].wkt, LW_PARSER_CHECK_NONE);
- GSERIALIZED *g = gserialized_from_lwgeom(lw, 0);
- int ie = gserialized_is_empty(g);
- // printf("%s: we say %d, they say %d\n", cases[i].wkt, cases[i].isempty, ie);
- CU_ASSERT_EQUAL(ie, cases[i].isempty);
- lwgeom_free(lw);
- lwfree(g);
- i++;
-static void test_geometry_type_from_string(void)
- int rv;
- uint8_t type = 0;
- int z = 0, m = 0;
- char *str;
- str = " POINTZ";
- rv = geometry_type_from_string(str, &type, &z, &m);
- //printf("\n in type: %s\nout type: %d\n out z: %d\n out m: %d", str, type, z, m);
- CU_ASSERT_EQUAL(rv, LW_SUCCESS);
- CU_ASSERT_EQUAL(type, POINTTYPE);
- CU_ASSERT_EQUAL(z, 1);
- CU_ASSERT_EQUAL(m, 0);
- str = "LINESTRINGM ";
- CU_ASSERT_EQUAL(type, LINETYPE);
- CU_ASSERT_EQUAL(z, 0);
- CU_ASSERT_EQUAL(m, 1);
- str = "MULTIPOLYGONZM";
- CU_ASSERT_EQUAL(type, MULTIPOLYGONTYPE);
- str = " GEOMETRYCOLLECTIONZM ";
- CU_ASSERT_EQUAL(type, COLLECTIONTYPE);
- str = " GEOMERYCOLLECTIONZM ";
- CU_ASSERT_EQUAL(rv, LW_FAILURE);
-static void test_lwgeom_count_vertices(void)
- LWGEOM *geom;
- geom = lwgeom_from_wkt("MULTIPOINT(-1 -1,-1 2.5,2 2,2 -1)", LW_PARSER_CHECK_NONE);
- CU_ASSERT_EQUAL(lwgeom_count_vertices(geom),4);
- geom = lwgeom_from_wkt("SRID=1;MULTILINESTRING((-1 -131,-1 2.5,2 2,2 -1),(-1 -1,-1 2.5,2 2,2 -1),(-1 -1,-1 2.5,2 2,2 -1),(-1 -1,-1 2.5,2 2,2 -1))", LW_PARSER_CHECK_NONE);
- CU_ASSERT_EQUAL(lwgeom_count_vertices(geom),16);
- geom = lwgeom_from_wkt("SRID=4326;MULTIPOLYGON(((-1 -1,-1 2.5,211 2,2 -1,-1 -1),(0 0,0 1,1 1,1 0,0 0),(-0.5 -0.5,-0.5 -0.4,-0.4 -0.4,-0.4 -0.5,-0.5 -0.5)),((-1 -1,-1 2.5,2 2,2 -1,-1 -1),(0 0,0 1,1 1,1 0,0 0),(-0.5 -0.5,-0.5 -0.4,-0.4 -0.4,-0.4 -0.5,-0.5 -0.5)))", LW_PARSER_CHECK_NONE);
- CU_ASSERT_EQUAL(lwgeom_count_vertices(geom),30);
-static void test_on_gser_lwgeom_count_vertices(void)
- LWGEOM *lwgeom;
- GSERIALIZED *g_ser1;
- size_t ret_size;
- lwgeom = lwgeom_from_wkt("MULTIPOINT(-1 -1,-1 2.5,2 2,2 -1,1 1,2 2,4 5)", LW_PARSER_CHECK_NONE);
- CU_ASSERT_EQUAL(lwgeom_count_vertices(lwgeom),7);
- g_ser1 = gserialized_from_lwgeom(lwgeom, &ret_size);
- lwgeom_free(lwgeom);
- lwgeom = lwgeom_from_gserialized(g_ser1);
- lwfree(g_ser1);
-static void test_lwcollection_extract(void)
- LWGEOM *geom;
- LWCOLLECTION *col;
- geom = lwgeom_from_wkt("GEOMETRYCOLLECTION(POINT(0 0))", LW_PARSER_CHECK_NONE);
- col = lwcollection_extract((LWCOLLECTION*)geom, 1);
- CU_ASSERT_EQUAL(col->type, MULTIPOINTTYPE);
- lwcollection_free(col);
- col = lwcollection_extract((LWCOLLECTION*)geom, 2);
- CU_ASSERT_EQUAL(col->type, MULTILINETYPE);
- col = lwcollection_extract((LWCOLLECTION*)geom, 3);
- CU_ASSERT_EQUAL(col->type, MULTIPOLYGONTYPE);
- geom = lwgeom_from_wkt("GEOMETRYCOLLECTION EMPTY", LW_PARSER_CHECK_NONE);
-static void test_lwgeom_free(void)
- LWGEOM *geom;
- /* Empty geometries don't seem to free properly (#370) */
- CU_ASSERT_EQUAL(geom->type, COLLECTIONTYPE);
- geom = lwgeom_from_wkt("POLYGON EMPTY", LW_PARSER_CHECK_NONE);
- CU_ASSERT_EQUAL(geom->type, POLYGONTYPE);
- geom = lwgeom_from_wkt("LINESTRING EMPTY", LW_PARSER_CHECK_NONE);
- CU_ASSERT_EQUAL(geom->type, LINETYPE);
- geom = lwgeom_from_wkt("POINT EMPTY", LW_PARSER_CHECK_NONE);
- CU_ASSERT_EQUAL(geom->type, POINTTYPE);
-static void do_lwgeom_swap_ordinates(char *in, char *out)
- LWGEOM *g;
- char * t;
- double xmax, ymax;
- int testbox;
- g = lwgeom_from_wkt(in, LW_PARSER_CHECK_NONE);
- lwgeom_add_bbox(g);
- testbox = (g->bbox != NULL);
- if ( testbox )
- xmax = g->bbox->xmax;
- ymax = g->bbox->ymax;
- lwgeom_swap_ordinates(g,LWORD_X,LWORD_Y);
- if ( testbox )
- CU_ASSERT_DOUBLE_EQUAL(g->bbox->xmax, ymax, 0.00001);
- CU_ASSERT_DOUBLE_EQUAL(g->bbox->ymax, xmax, 0.00001);
- t = lwgeom_to_wkt(g, WKT_EXTENDED, 8, NULL);
- if (t == NULL) fprintf(stderr, "In:%s", in);
- if (strcmp(t, out))
- fprintf(stderr, "\nIn: %s\nOut: %s\nTheo: %s\n", in, t, out);
- CU_ASSERT_STRING_EQUAL(t, out)
- lwgeom_free(g);
- lwfree(t);
-static void test_lwgeom_swap_ordinates(void)
- * 2D geometries types
- do_lwgeom_swap_ordinates(
- "POINT(1 2)",
- "POINT(2 1)"
- "LINESTRING(1 2,3 4)",
- "LINESTRING(2 1,4 3)"
- "POLYGON((1 2,3 4,5 6,1 2))",
- "POLYGON((2 1,4 3,6 5,2 1))"
- "POLYGON((1 2,3 4,5 6,1 2),(7 8,9 10,11 12,7 8))",
- "POLYGON((2 1,4 3,6 5,2 1),(8 7,10 9,12 11,8 7))"
- "MULTIPOINT(1 2,3 4)",
- "MULTIPOINT(2 1,4 3)"
- "MULTILINESTRING((1 2,3 4),(5 6,7 8))",
- "MULTILINESTRING((2 1,4 3),(6 5,8 7))"
- "MULTIPOLYGON(((1 2,3 4,5 6,7 8)),((9 10,11 12,13 14,10 9)))",
- "MULTIPOLYGON(((2 1,4 3,6 5,8 7)),((10 9,12 11,14 13,9 10)))"
- "GEOMETRYCOLLECTION EMPTY",
- "GEOMETRYCOLLECTION(POINT(1 2),LINESTRING(3 4,5 6))",
- "GEOMETRYCOLLECTION(POINT(2 1),LINESTRING(4 3,6 5))"
- "GEOMETRYCOLLECTION(POINT(1 2),GEOMETRYCOLLECTION(LINESTRING(3 4,5 6)))",
- "GEOMETRYCOLLECTION(POINT(2 1),GEOMETRYCOLLECTION(LINESTRING(4 3,6 5)))"
- "CIRCULARSTRING(-2 0,0 2,2 0,0 2,2 4)",
- "CIRCULARSTRING(0 -2,2 0,0 2,2 0,4 2)"
- "COMPOUNDCURVE(CIRCULARSTRING(0 1,1 1,1 0),(1 0,0 1))",
- "COMPOUNDCURVE(CIRCULARSTRING(1 0,1 1,0 1),(0 1,1 0))"
- "CURVEPOLYGON(CIRCULARSTRING(-2 0,-1 -1,0 0,1 -1,2 0,0 2,-2 0),(-1 0,0 0.5,1 0,0 1,-1 0))",
- "CURVEPOLYGON(CIRCULARSTRING(0 -2,-1 -1,0 0,-1 1,0 2,2 0,0 -2),(0 -1,0.5 0,0 1,1 0,0 -1))"
- "MULTICURVE((5 5,3 5,3 3,0 3),CIRCULARSTRING(0 0,2 1,2 3))",
- "MULTICURVE((5 5,5 3,3 3,3 0),CIRCULARSTRING(0 0,1 2,3 2))"
- "MULTISURFACE(CURVEPOLYGON(CIRCULARSTRING(0 -2,-1 -1,0 0,-1 1,0 2,2 0,0 -2),(0 -1,0.5 0,0 1,1 0,0 -1)),((8 7,10 10,14 6,11 4,8 7)))"
- * Ndims
- "POINT(1 2 3)",
- "POINT(2 1 3)"
- "POINTM(1 2 3)",
- "POINTM(2 1 3)"
- "POINT(1 2 3 4)",
- "POINT(2 1 3 4)"
- * Srid
- "SRID=4326;POINT(1 2)",
- "SRID=4326;POINT(2 1)"
- "SRID=0;POINT(1 2)",
- "POINT(2 1)"
-static void test_f2d(void)
- double d = 1000000.123456789123456789;
- float f;
- double e;
- f = next_float_down(d);
- d = next_float_down(f);
- CU_ASSERT_DOUBLE_EQUAL(f,d, 0.0000001);
- e = (double)f;
- CU_ASSERT_DOUBLE_EQUAL(f,e, 0.0000001);
- f = next_float_up(d);
- d = next_float_up(f);
- d = DBL_MAX;
- CU_ASSERT_DOUBLE_EQUAL(f, d, 0.0000001);
- d = DBL_MAX;
- d = -DBL_MAX;
- d = -DBL_MAX;
- * This is a test for memory leaks, can't really test
- * w/out checking with a leak detector (ie: valgrind)
- * See http://trac.osgeo.org/postgis/ticket/1102
-static void test_lwgeom_clone(void)
- size_t i;
- char *ewkt[] =
- "POINT(0 0.2)",
- "TIN(((0 0 0,0 0 1,0 1 0,0 0 0)),((0 0 0,0 1 0,1 0 0,0 0 0)),((0 0 0,1 0 0,0 0 1,0 0 0)),((1 0 0,0 1 0,0 0 1,1 0 0)))"
- for ( i = 0; i < (sizeof ewkt/sizeof(char *)); i++ )
- LWGEOM *geom, *cloned;
- char *in_ewkt;
- char *out_ewkt;
- cloned = lwgeom_clone(geom);
- out_ewkt = lwgeom_to_ewkt(cloned);
- if (strcmp(in_ewkt, out_ewkt))
- fprintf(stderr, "\nExp: %s\nObt: %s\n", in_ewkt, out_ewkt);
- lwfree(out_ewkt);
- lwgeom_free(cloned);
- * Test lwgeom_force_clockwise
-static void test_lwgeom_force_clockwise(void)
- LWGEOM *geom;
- LWGEOM *geom2;
- char *in_ewkt, *out_ewkt;
- /* counterclockwise, must be reversed */
- geom = lwgeom_from_wkt("POLYGON((0 0, 10 0, 10 10, 0 10, 0 0))", LW_PARSER_CHECK_NONE);
- CU_ASSERT_FALSE(lwgeom_is_clockwise(geom));
- lwgeom_force_clockwise(geom);
- in_ewkt = "POLYGON((0 0,0 10,10 10,10 0,0 0))";
- out_ewkt = lwgeom_to_ewkt(geom);
- lwfree(out_ewkt);
- /* clockwise, fine as is */
- geom = lwgeom_from_wkt("POLYGON((0 0, 0 10, 10 10, 10 0, 0 0))", LW_PARSER_CHECK_NONE);
- CU_ASSERT_TRUE(lwgeom_is_clockwise(geom));
- lwfree(out_ewkt);
- /* counterclockwise shell (must be reversed), mixed-wise holes */
- geom = lwgeom_from_wkt("POLYGON((0 0,10 0,10 10,0 10,0 0),(2 2,2 4,4 2,2 2),(6 2,8 2,8 4,6 2))", LW_PARSER_CHECK_NONE);
- in_ewkt = "POLYGON((0 0,0 10,10 10,10 0,0 0),(2 2,4 2,2 4,2 2),(6 2,8 2,8 4,6 2))";
- lwfree(out_ewkt);
- /* clockwise shell (fine), mixed-wise holes */
- geom = lwgeom_from_wkt("POLYGON((0 0,0 10,10 10,10 0,0 0),(2 2,4 2,2 4,2 2),(6 2,8 4,8 2,6 2))", LW_PARSER_CHECK_NONE);
- lwfree(out_ewkt);
- /* clockwise narrow ring, fine as-is */
- /* NOTE: this is a narrow ring, see ticket #1302 */
- in_ewkt = "0103000000010000000500000000917E9BA468294100917E9B8AEA2841C976BE1FA4682941C976BE9F8AEA2841B39ABE1FA46829415ACCC29F8AEA284137894120A4682941C976BE9F8AEA284100917E9BA468294100917E9B8AEA2841";
- geom = lwgeom_from_hexwkb(in_ewkt, LW_PARSER_CHECK_NONE);
- geom2 = lwgeom_from_hexwkb(in_ewkt, LW_PARSER_CHECK_NONE);
- lwgeom_force_clockwise(geom2);
- /** use same check instead of strcmp to account
- for difference in endianness **/
- CU_ASSERT( lwgeom_same(geom, geom2) );
- * Test lwgeom_is_empty
-static void test_lwgeom_is_empty(void)
- LWGEOM *geom;
- CU_ASSERT( !lwgeom_is_empty(geom) );
- CU_ASSERT( lwgeom_is_empty(geom) );
- geom = lwgeom_from_wkt("MULTIPOINT EMPTY", LW_PARSER_CHECK_NONE);
- geom = lwgeom_from_wkt("MULTILINESTRING EMPTY", LW_PARSER_CHECK_NONE);
- geom = lwgeom_from_wkt("MULTIPOLYGON EMPTY", LW_PARSER_CHECK_NONE);
- geom = lwgeom_from_wkt("GEOMETRYCOLLECTION(GEOMETRYCOLLECTION EMPTY, POINT EMPTY, LINESTRING EMPTY, POLYGON EMPTY, MULTIPOINT EMPTY, MULTILINESTRING EMPTY, MULTIPOLYGON EMPTY, GEOMETRYCOLLECTION(MULTIPOLYGON EMPTY))", LW_PARSER_CHECK_NONE);
- * Test lwgeom_same
-static void test_lwgeom_same(void)
- LWGEOM *geom, *geom2;
- CU_ASSERT( lwgeom_same(geom, geom) );
- geom = lwgeom_from_wkt("MULTIPOLYGON(((0 0, 10 0, 10 10, 0 10, 0 0)))", LW_PARSER_CHECK_NONE);
- geom = lwgeom_from_wkt("LINESTRING(0 0, 2 0)", LW_PARSER_CHECK_NONE);
- geom = lwgeom_from_wkt("MULTILINESTRING((0 0, 2 0))", LW_PARSER_CHECK_NONE);
- geom = lwgeom_from_wkt("POINT(0 0)", LW_PARSER_CHECK_NONE);
- geom = lwgeom_from_wkt("MULTIPOINT((0 0),(4 5))", LW_PARSER_CHECK_NONE);
- geom2 = lwgeom_from_wkt("GEOMETRYCOLLECTION(GEOMETRYCOLLECTION EMPTY, POINT EMPTY, LINESTRING EMPTY, POLYGON EMPTY, MULTIPOINT EMPTY, MULTILINESTRING EMPTY, MULTIPOLYGON EMPTY, GEOMETRYCOLLECTION(MULTIPOLYGON EMPTY))", LW_PARSER_CHECK_NONE);
- CU_ASSERT( ! lwgeom_same(geom, geom2) );
- geom2 = lwgeom_from_wkt("MULTIPOINT((0 0))", LW_PARSER_CHECK_NONE);
- geom2 = lwgeom_from_wkt("POINT Z EMPTY", LW_PARSER_CHECK_NONE);
- * Test lwgeom_force_curve
-static void test_lwgeom_as_curve(void)
- LWGEOM *geom;
- LWGEOM *geom2;
- geom = lwgeom_from_wkt("LINESTRING(0 0, 10 0)", LW_PARSER_CHECK_NONE);
- geom2 = lwgeom_as_curve(geom);
- in_ewkt = "COMPOUNDCURVE((0 0,10 0))";
- lwfree(out_ewkt);
- geom = lwgeom_from_wkt("MULTILINESTRING((0 0, 10 0))", LW_PARSER_CHECK_NONE);
- in_ewkt = "MULTICURVE((0 0,10 0))";
- lwfree(out_ewkt);
- in_ewkt = "CURVEPOLYGON((0 0,10 0,10 10,0 10,0 0))";
- lwfree(out_ewkt);
- in_ewkt = "MULTISURFACE(((0 0,10 0,10 10,0 10,0 0)))";
- lwfree(out_ewkt);
-static void test_lwline_from_lwmpoint(void)
- LWLINE *line;
- LWMPOINT *mpoint;
- mpoint = (LWMPOINT*)lwgeom_from_wkt("MULTIPOINT(0 0, 0 1, 1 1, 1 2, 2 2)", LW_PARSER_CHECK_NONE);
- line = lwline_from_lwmpoint(SRID_DEFAULT, mpoint);
- CU_ASSERT_EQUAL(line->points->npoints, mpoint->ngeoms);
- CU_ASSERT_DOUBLE_EQUAL(lwline_length_2d(line), 4.0, 0.000001);
- lwline_free(line);
- lwmpoint_free(mpoint);
- * Test lwgeom_scale
-static void test_lwgeom_scale(void)
- LWGEOM *geom;
- POINT4D factor;
- char *out_ewkt;
- GBOX *box;
- geom = lwgeom_from_wkt("SRID=4326;GEOMETRYCOLLECTION(POINT(0 1 2 3),POLYGON((-1 -1 0 1,-1 2.5 0 1,2 2 0 1,2 -1 0 1,-1 -1 0 1),(0 0 1 2,0 1 1 2,1 1 1 2,1 0 2 3,0 0 1 2)),LINESTRING(0 0 0 0, 1 2 3 4))", LW_PARSER_CHECK_NONE);
- factor.x = 2; factor.y = 3; factor.z = 4; factor.m = 5;
- lwgeom_scale(geom, &factor);
- ASSERT_STRING_EQUAL(out_ewkt, "SRID=4326;GEOMETRYCOLLECTION(POINT(0 3 8 15),POLYGON((-2 -3 0 5,-2 7.5 0 5,4 6 0 5,4 -3 0 5,-2 -3 0 5),(0 0 4 10,0 3 4 10,2 3 4 10,2 0 8 15,0 0 4 10)),LINESTRING(0 0 0 0,2 6 12 20))");
- lwfree(out_ewkt);
- geom = lwgeom_from_wkt("POINT(1 1 1 1)", LW_PARSER_CHECK_NONE);
- box = geom->bbox;
- ASSERT_DOUBLE_EQUAL(box->xmin, 2);
- ASSERT_DOUBLE_EQUAL(box->xmax, 2);
- ASSERT_DOUBLE_EQUAL(box->ymin, 3);
- ASSERT_DOUBLE_EQUAL(box->ymax, 3);
- ASSERT_DOUBLE_EQUAL(box->zmin, 4);
- ASSERT_DOUBLE_EQUAL(box->zmax, 4);
- ASSERT_DOUBLE_EQUAL(box->mmin, 5);
- ASSERT_DOUBLE_EQUAL(box->mmax, 5);
-void test_gbox_same_2d(void);
- LWGEOM* g1 = lwgeom_from_wkt("LINESTRING(0 0, 1 1)", LW_PARSER_CHECK_NONE);
- LWGEOM* g2 = lwgeom_from_wkt("LINESTRING(0 0, 0 1, 1 1)", LW_PARSER_CHECK_NONE);
- LWGEOM* g3 = lwgeom_from_wkt("LINESTRING(0 0, 1 1.000000000001)", LW_PARSER_CHECK_NONE);
- lwgeom_add_bbox(g1);
- lwgeom_add_bbox(g2);
- lwgeom_add_bbox(g3);
- CU_ASSERT_TRUE(gbox_same_2d(g1->bbox, g2->bbox));
- CU_ASSERT_FALSE(gbox_same_2d(g1->bbox, g3->bbox));
- /* Serializing a GBOX with precise coordinates renders the boxes not strictly equal,
- * but still equal according to gbox_same_2d_float.
- GSERIALIZED* s3 = gserialized_from_lwgeom(g3, NULL);
- GBOX s3box;
- gserialized_read_gbox_p(s3, &s3box);
- CU_ASSERT_FALSE(gbox_same_2d(g3->bbox, &s3box));
- CU_ASSERT_TRUE(gbox_same_2d_float(g3->bbox, &s3box));
- /* The serialized box equals itself by either the exact or closest-float compares */
- CU_ASSERT_TRUE(gbox_same_2d(&s3box, &s3box));
- CU_ASSERT_TRUE(gbox_same_2d_float(&s3box, &s3box));
- lwgeom_free(g1);
- lwgeom_free(g2);
- lwgeom_free(g3);
- lwfree(s3);
-void test_gserialized_peek_gbox_p_no_box_when_empty(void);
- uint32_t i;
- char *ewkt[] =
- "POINT EMPTY",
- "MULTIPOINT (EMPTY)",
- "MULTILINESTRING EMPTY",
- "MULTILINESTRING (EMPTY)"
- LWGEOM* geom = lwgeom_from_wkt(ewkt[i], LW_PARSER_CHECK_NONE);
- GBOX box;
- gbox_init(&box);
- GSERIALIZED* gser = gserialized_from_lwgeom(geom, NULL);
- CU_ASSERT_FALSE(gserialized_has_bbox(gser));
- CU_ASSERT_EQUAL(LW_FAILURE, gserialized_peek_gbox_p(gser, &box));
- lwfree(gser);
-void test_gserialized_peek_gbox_p_gets_correct_box(void);
- uint32_t i;
- char *ewkt[] =
- "POINT (2.2945672355 48.85822923236)",
- "POINTZ (2.2945672355 48.85822923236 15)",
- "POINTM (2.2945672355 48.85822923236 12)",
- "POINT ZM (2.2945672355 48.85822923236 12 2)",
- "MULTIPOINT ((-76.45402132523 44.225406213532))",
- "MULTIPOINT Z ((-76.45402132523 44.225406213532 112))",
- "MULTIPOINT ZM ((-76.45402132523 44.225406213532 112 44))",
- "LINESTRING (2.2945672355 48.85822923236, -76.45402132523 44.225406213532)",
- "LINESTRING Z (2.2945672355 48.85822923236 6, -76.45402132523 44.225406213532 8)",
- "LINESTRING ZM (2.2945672355 48.85822923236 3 2, -76.45402132523 44.225406213532 9 4)",
- "MULTILINESTRING ((2.2945672355 48.85822923236, -76.45402132523 44.225406213532))",
- "MULTILINESTRING Z ((2.2945672355 48.85822923236 4, -76.45402132523 44.225406213532 3))"
- GBOX box_from_peek;
- GBOX box_from_lwgeom;
- gbox_init(&box_from_peek);
- gbox_init(&box_from_lwgeom);
- lwgeom_calculate_gbox(geom, &box_from_lwgeom);
- gserialized_peek_gbox_p(gser, &box_from_peek);
- gbox_float_round(&box_from_lwgeom);
- CU_ASSERT_TRUE(gbox_same(&box_from_peek, &box_from_lwgeom));
- lwfree(gser);
-void test_gserialized_peek_gbox_p_fails_for_unsupported_cases(void);
- uint32_t i;
- char *ewkt[] =
- "MULTIPOINT ((-76.45402132523 44.225406213532), (-72 33))",
- "LINESTRING (2.2945672355 48.85822923236, -76.45402132523 44.225406213532, -72 33)",
- "MULTILINESTRING ((2.2945672355 48.85822923236, -76.45402132523 44.225406213532, -72 33))",
- "MULTILINESTRING ((2.2945672355 48.85822923236, -76.45402132523 44.225406213532), (-72 33, -71 32))"
- GBOX box;
- gbox_init(&box);
- lwgeom_drop_bbox(geom);
- /* Construct a GSERIALIZED* that doesn't have a box, so that we can test the
- * actual logic of the peek function */
- size_t expected_size = gserialized_from_lwgeom_size(geom);
- GSERIALIZED* gser = lwalloc(expected_size);
- uint8_t* ptr = (uint8_t*) gser;
- ptr += 8; // Skip header
- gserialized_from_lwgeom_any(geom, ptr);
- gser->flags = geom->flags;
- lwfree(gser);
-void test_signum_macro(void);
- CU_ASSERT_EQUAL(SIGNUM(-5.0),-1);
- CU_ASSERT_EQUAL(SIGNUM( 5.0), 1);
- CU_ASSERT_EQUAL(SIGNUM( 0.0), 0);
- CU_ASSERT_EQUAL(SIGNUM(10) * 5, 5);
- CU_ASSERT_EQUAL(SIGNUM(-10) * 5, -5);
-** Used by test harness to register the tests in this file.
-void libgeom_suite_setup(void);
- CU_pSuite suite = CU_add_suite("serialization/deserialization", NULL, NULL);
- PG_ADD_TEST(suite, test_typmod_macros);
- PG_ADD_TEST(suite, test_flags_macros);
- PG_ADD_TEST(suite, test_serialized_srid);
- PG_ADD_TEST(suite, test_gserialized_from_lwgeom_size);
- PG_ADD_TEST(suite, test_gbox_serialized_size);
- PG_ADD_TEST(suite, test_lwgeom_from_gserialized);
- PG_ADD_TEST(suite, test_lwgeom_count_vertices);
- PG_ADD_TEST(suite, test_on_gser_lwgeom_count_vertices);
- PG_ADD_TEST(suite, test_geometry_type_from_string);
- PG_ADD_TEST(suite, test_lwcollection_extract);
- PG_ADD_TEST(suite, test_lwgeom_free);
- PG_ADD_TEST(suite, test_lwgeom_swap_ordinates);
- PG_ADD_TEST(suite, test_f2d);
- PG_ADD_TEST(suite, test_lwgeom_clone);
- PG_ADD_TEST(suite, test_lwgeom_force_clockwise);
- PG_ADD_TEST(suite, test_lwgeom_calculate_gbox);
- PG_ADD_TEST(suite, test_lwgeom_is_empty);
- PG_ADD_TEST(suite, test_lwgeom_same);
- PG_ADD_TEST(suite, test_lwline_from_lwmpoint);
- PG_ADD_TEST(suite, test_lwgeom_as_curve);
- PG_ADD_TEST(suite, test_lwgeom_scale);
- PG_ADD_TEST(suite, test_gserialized_is_empty);
- PG_ADD_TEST(suite, test_gserialized_peek_gbox_p_no_box_when_empty);
- PG_ADD_TEST(suite, test_gserialized_peek_gbox_p_gets_correct_box);
- PG_ADD_TEST(suite, test_gserialized_peek_gbox_p_fails_for_unsupported_cases);
- PG_ADD_TEST(suite, test_gbox_same_2d);
- PG_ADD_TEST(suite, test_signum_macro);
