[postgis-tickets] r17502 - Strip out direct calls to FLAGS macros where easy
Paul Ramsey
pramsey at cleverelephant.ca
Tue Jun 11 01:49:13 PDT 2019
Author: pramsey
Date: 2019-06-11 13:49:13 -0700 (Tue, 11 Jun 2019)
New Revision: 17502
Added:
trunk/liblwgeom/gserialized.c
trunk/liblwgeom/gserialized.h
trunk/liblwgeom/gserialized1.h
trunk/liblwgeom/gserialized2.c
trunk/liblwgeom/gserialized2.h
trunk/liblwgeom/liblwgeom.h.in
trunk/liblwgeom/lwgeom.c
trunk/postgis/geobuf.c
trunk/postgis/gserialized_gist_2d.c
trunk/postgis/lwgeom_dumppoints.c
trunk/postgis/lwgeom_functions_analytic.c
trunk/postgis/lwgeom_functions_basic.c
trunk/postgis/lwgeom_ogc.c
trunk/postgis/lwgeom_rtree.c
trunk/postgis/lwgeom_sfcgal.c
Added: trunk/liblwgeom/gserialized.c
Added: trunk/liblwgeom/gserialized.h
Added: trunk/liblwgeom/gserialized1.h
Added: trunk/liblwgeom/gserialized2.c
Added: trunk/liblwgeom/gserialized2.h
Modified: trunk/liblwgeom/liblwgeom.h.in
--- trunk/liblwgeom/liblwgeom.h.in 2019-06-11 20:13:13 UTC (rev 17501)
+++ trunk/liblwgeom/liblwgeom.h.in 2019-06-11 20:49:13 UTC (rev 17502)
@@ -1429,6 +1429,11 @@
extern int lwgeom_has_m(const LWGEOM *geom);
+* Return #LW_TRUE if geometry has SOLID flag.
+extern int lwgeom_is_solid(const LWGEOM *geom);
* Return the number of dimensions (2, 3, 4) in a geometry
extern int lwgeom_ndims(const LWGEOM *geom);
Modified: trunk/liblwgeom/lwgeom.c
--- trunk/liblwgeom/lwgeom.c 2019-06-11 20:13:13 UTC (rev 17501)
+++ trunk/liblwgeom/lwgeom.c 2019-06-11 20:49:13 UTC (rev 17502)
@@ -925,6 +925,13 @@
int
+lwgeom_is_solid(const LWGEOM *geom)
+ if ( ! geom ) return LW_FALSE;
+ return FLAGS_GET_GEODETIC(geom->flags);
+int
if ( ! geom ) return 0;
@@ -932,6 +939,8 @@
void
lwgeom_set_geodetic(LWGEOM *geom, int value)
Modified: trunk/postgis/geobuf.c
--- trunk/postgis/geobuf.c 2019-06-11 20:13:13 UTC (rev 17501)
+++ trunk/postgis/geobuf.c 2019-06-11 20:49:13 UTC (rev 17502)
@@ -490,11 +490,12 @@
static void analyze_geometry_flags(struct geobuf_agg_context *ctx,
LWGEOM *lwgeom)
- if (!ctx->has_dimensions) {
- if (FLAGS_GET_Z(lwgeom->flags) || FLAGS_GET_M(lwgeom->flags))
+ if (!ctx->has_dimensions)
+ if (lwgeom_has_z(lwgeom) && lwgeom_has_m(lwgeom))
+ ctx->dimensions = 4;
+ else if (lwgeom_has_z(lwgeom) || lwgeom_has_m(lwgeom))
ctx->dimensions = 3;
- else if (FLAGS_GET_ZM(lwgeom->flags))
- ctx->dimensions = 4;
else
ctx->dimensions = 2;
ctx->has_dimensions = 1;
Modified: trunk/postgis/gserialized_gist_2d.c
--- trunk/postgis/gserialized_gist_2d.c 2019-06-11 20:13:13 UTC (rev 17501)
+++ trunk/postgis/gserialized_gist_2d.c 2019-06-11 20:49:13 UTC (rev 17502)
@@ -561,7 +561,6 @@
gserialized_datum_get_box2df_p(Datum gsdatum, BOX2DF *box2df)
GSERIALIZED *gpart;
- uint8_t flags;
int result = LW_SUCCESS;
POSTGIS_DEBUG(4, "entered function");
@@ -577,12 +576,11 @@
** which makes slicing worthwhile.
gpart = (GSERIALIZED*)PG_DETOAST_DATUM(gsdatum);
- flags = gpart->flags;
POSTGIS_DEBUGF(4, "got flags %d", gpart->flags);
/* Do we even have a serialized bounding box? */
- if ( FLAGS_GET_BBOX(flags) )
+ if (gserialized_has_bbox(gpart))
/* Yes! Copy it out into the box! */
POSTGIS_DEBUG(4, "copying box out of serialization");
Modified: trunk/postgis/lwgeom_dumppoints.c
--- trunk/postgis/lwgeom_dumppoints.c 2019-06-11 20:13:13 UTC (rev 17501)
+++ trunk/postgis/lwgeom_dumppoints.c 2019-06-11 20:49:13 UTC (rev 17502)
@@ -176,8 +176,8 @@
if (state->pt <= 3) {
getPoint4d_p(tri->points, state->pt, &pt);
lwpoint = lwpoint_make(tri->srid,
- FLAGS_GET_Z(tri->points->flags),
- FLAGS_GET_M(tri->points->flags),
+ lwgeom_has_z(lwgeom),
+ lwgeom_has_m(lwgeom),
&pt);
if (state->pt > 3) {
@@ -210,8 +210,8 @@
getPoint4d_p(poly->rings[state->ring], state->pt, &pt);
lwpoint = lwpoint_make(poly->srid,
- FLAGS_GET_Z(poly->rings[state->ring]->flags),
- FLAGS_GET_M(poly->rings[state->ring]->flags),
&pt);
break;
@@ -291,21 +291,4 @@
- * Geometry types of collection types for reference
-#if 0
- case MULTIPOINTTYPE:
- case MULTILINETYPE:
- case MULTIPOLYGONTYPE:
- case COLLECTIONTYPE:
- case CURVEPOLYTYPE:
- case COMPOUNDTYPE:
- case MULTICURVETYPE:
- case MULTISURFACETYPE:
- case POLYHEDRALSURFACETYPE:
- case TINTYPE:
-#endif
Modified: trunk/postgis/lwgeom_functions_analytic.c
--- trunk/postgis/lwgeom_functions_analytic.c 2019-06-11 20:13:13 UTC (rev 17501)
+++ trunk/postgis/lwgeom_functions_analytic.c 2019-06-11 20:49:13 UTC (rev 17502)
@@ -433,9 +433,9 @@
getPoint4d_p(in_lwpoint->point, 0, &offsetpoint);
grid.ipx = offsetpoint.x;
grid.ipy = offsetpoint.y;
- if (FLAGS_GET_Z(in_lwpoint->flags) ) grid.ipz = offsetpoint.z;
+ if (lwgeom_has_z(in_lwpoint) ) grid.ipz = offsetpoint.z;
else grid.ipz=0;
- if (FLAGS_GET_M(in_lwpoint->flags) ) grid.ipm = offsetpoint.m;
+ if (lwgeom_has_m(in_lwpoint) ) grid.ipm = offsetpoint.m;
else grid.ipm=0;
#if POSTGIS_DEBUG_LEVEL >= 4
Modified: trunk/postgis/lwgeom_functions_basic.c
--- trunk/postgis/lwgeom_functions_basic.c 2019-06-11 20:13:13 UTC (rev 17501)
+++ trunk/postgis/lwgeom_functions_basic.c 2019-06-11 20:49:13 UTC (rev 17502)
@@ -1151,7 +1151,8 @@
lwtype_name(gserialized_get_type(gser1)),
lwtype_name(gserialized_get_type(gser2)));
- if (FLAGS_GET_ZM(gser1->flags) != FLAGS_GET_ZM(gser2->flags))
+ if ((gserialized_has_z(gser1) != gserialized_has_z(gser2)) ||
+ (gserialized_has_m(gser1) != gserialized_has_m(gser2)))
elog(ERROR, "Cannot ST_Collect geometries with differing dimensionality.");
PG_RETURN_NULL();
@@ -2675,7 +2676,7 @@
else
lwcol = lwgeom_construct_empty(
- type, lwgeom->srid, FLAGS_GET_Z(lwgeom->flags), FLAGS_GET_M(lwgeom->flags));
+ type, lwgeom->srid, lwgeom_has_z(lwgeom), lwgeom_has_m(lwgeom));
else
@@ -3092,7 +3093,7 @@
lwgeom_in = lwgeom_from_gserialized(geom_in);
- hasm = FLAGS_GET_M(lwgeom_in->flags);
+ hasm = lwgeom_has_m(lwgeom_in);
if (!hasm)
Modified: trunk/postgis/lwgeom_ogc.c
--- trunk/postgis/lwgeom_ogc.c 2019-06-11 20:13:13 UTC (rev 17501)
+++ trunk/postgis/lwgeom_ogc.c 2019-06-11 20:49:13 UTC (rev 17502)
@@ -697,12 +697,9 @@
lwgeom = lwgeom_from_gserialized(geom);
point = lwgeom_as_lwpoint(lwgeom);
- if ( lwgeom_is_empty(lwgeom) )
+ if (lwgeom_is_empty(lwgeom) || !lwgeom_has_m(lwgeom))
PG_RETURN_NULL();
- /* no M in input */
- if ( ! FLAGS_GET_M(point->flags) ) PG_RETURN_NULL();
getPoint3dm_p(point->point, 0, &p);
PG_FREE_IF_COPY(geom, 0);
Modified: trunk/postgis/lwgeom_rtree.c
--- trunk/postgis/lwgeom_rtree.c 2019-06-11 20:13:13 UTC (rev 17501)
+++ trunk/postgis/lwgeom_rtree.c 2019-06-11 20:49:13 UTC (rev 17502)
@@ -471,7 +471,7 @@
lwgeoms = lwalloc(sizeof(LWGEOM *));
lwgeoms[0] = (LWGEOM *)root->segment;
- POSTGIS_DEBUGF(3, "Found geom %p, type %d, dim %d", root->segment, root->segment->type, FLAGS_GET_Z(root->segment->flags));
+ POSTGIS_DEBUGF(3, "Found geom %p, type %d, dim %d", root->segment, root->segment->type, lwgeom_has_z(root->segment));
result = (LWMLINE *)lwcollection_construct(MULTILINETYPE, SRID_UNKNOWN, NULL, 1, lwgeoms);
@@ -484,7 +484,7 @@
tmp = RTreeFindLineSegments(root->leftNode, value);
if (tmp)
- POSTGIS_DEBUGF(3, "Found geom %p, type %d, dim %d", tmp, tmp->type, FLAGS_GET_Z(tmp->flags));
+ POSTGIS_DEBUGF(3, "Found geom %p, type %d, dim %d", tmp, tmp->type, lwgeom_has_z(tmp));
if (result)
result = RTreeMergeMultiLines(result, tmp);
@@ -501,7 +501,7 @@
tmp = RTreeFindLineSegments(root->rightNode, value);
if (tmp)
if (result)
Modified: trunk/postgis/lwgeom_sfcgal.c
--- trunk/postgis/lwgeom_sfcgal.c 2019-06-11 20:13:13 UTC (rev 17501)
+++ trunk/postgis/lwgeom_sfcgal.c 2019-06-11 20:49:13 UTC (rev 17502)
@@ -503,7 +503,7 @@
if (!lwgeom)
elog(ERROR, "sfcgal_is_solid: Unable to deserialize input");
- result = FLAGS_GET_SOLID(lwgeom->flags);
+ result = lwgeom_is_solid(lwgeom);
lwgeom_free(lwgeom);
