[postgis-tickets] [PostGIS] #4334: Can't upgrade with a view based on ST_AsMVTGeom
trac at osgeo.org
Wed Jun 12 03:30:23 PDT 2019
Reporter: Algunenano | Owner: Algunenano
Type: defect | Status: closed
Priority: high | Milestone: PostGIS 3.0.0
Component: build/upgrade/install | Version: 2.4.x
Resolution: fixed | Keywords:
Changes (by Raul Marin):
* status: new => closed
* resolution: => fixed
Comment:
In [changeset:"17508" 17508]:
#!CommitTicketReference repository="" revision="17508"
Rename update sql files
postgis/postgis_drop_after.sql -> postgis/postgis_after_upgrade.sql
postgis/postgis_drop_before.sql -> postgis/postgis_before_upgrade.sql
Closes #4334
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4334#comment:18>
