[postgis-tickets] r17511 - AddRasterConstraints: Ignore NULLs when generating constraints
Raul
raul at rmr.ninja
Wed Jun 12 06:08:50 PDT 2019
Author: algunenano
Date: 2019-06-12 06:08:50 -0700 (Wed, 12 Jun 2019)
New Revision: 17511
trunk/NEWS
trunk/raster/rt_pg/rtpostgis.sql.in
trunk/raster/test/regress/tickets.sql
trunk/raster/test/regress/tickets_expected
Closes https://github.com/postgis/postgis/pull/418
References #4388
Modified: trunk/NEWS
--- trunk/NEWS 2019-06-12 11:38:52 UTC (rev 17510)
+++ trunk/NEWS 2019-06-12 13:08:50 UTC (rev 17511)
@@ -20,6 +20,7 @@
- #4414, Include version number in address_standardizer lib (Raúl Marín)
- #4352, Use CREATE OR REPLACE AGGREGATE for PG12+ (Raúl Marín)
- #4334, Fix upgrade issues related to renamed parameters (Raúl Marín)
+ - #4388, AddRasterConstraints: Ignore NULLs when generating constraints (Raúl Marín)
PostGIS 3.0.0alpha1
2019/05/26
@@ -164,6 +165,7 @@
- #4383, Fix undefined behaviour in implicit conversions (Raúl Marín)
- #4334, Fix upgrade issues related to renamed function parameters (Raúl Marín)
PostGIS 2.5.0
Modified: trunk/raster/rt_pg/rtpostgis.sql.in
--- trunk/raster/rt_pg/rtpostgis.sql.in 2019-06-12 11:38:52 UTC (rev 17510)
+++ trunk/raster/rt_pg/rtpostgis.sql.in 2019-06-12 13:08:50 UTC (rev 17511)
@@ -7243,7 +7243,9 @@
sql := 'SELECT st_srid('
|| quote_ident($3)
|| ') FROM ' || fqtn
- || ' LIMIT 1';
+ || ' WHERE '
+ || quote_ident($3)
+ || ' IS NOT NULL LIMIT 1;';
BEGIN
EXECUTE sql INTO attr;
EXCEPTION WHEN OTHERS THEN
@@ -7326,7 +7328,9 @@
|| quote_ident($3)
|| ') FROM '
|| fqtn
- || ' LIMIT 1';
+ || ' WHERE '
BEGIN
@@ -7477,11 +7481,13 @@
fqtn := fqtn || quote_ident($2);
sql := 'SELECT @extschema at .ST_SRID('
- || quote_ident($3)
- || ') FROM '
- || fqtn
- || ' LIMIT 1;';
- EXECUTE sql INTO srid;
+ || ') FROM '
+ || fqtn
+ || ' WHERE '
+ EXECUTE sql INTO srid;
cn := 'enforce_max_extent_' || $3;
@@ -7544,7 +7550,11 @@
sql := 'SELECT @extschema at .st_makeemptyraster(1, 1, upperleftx, upperlefty, scalex, scaley, skewx, skewy, srid) FROM @extschema at .st_metadata((SELECT '
|| quote_ident($3)
- || ' FROM ' || fqtn || ' LIMIT 1))';
+ || ' FROM '
+ || fqtn
+ || ' WHERE '
+ || ' IS NOT NULL LIMIT 1))';
BEGIN
@@ -7792,8 +7802,11 @@
cn := 'enforce_num_bands_' || $3;
sql := 'SELECT @extschema at .st_numbands(' || quote_ident($3)
- || ') FROM ' || fqtn
- || ' LIMIT 1';
+ || ') FROM '
+ || fqtn
+ || ' WHERE '
BEGIN
@@ -7868,7 +7881,9 @@
sql := 'SELECT @extschema at ._raster_constraint_pixel_types(' || quote_ident($3)
|| ') FROM ' || fqtn
- || ' LIMIT 1';
+ || ' WHERE '
BEGIN
@@ -7954,7 +7969,9 @@
sql := 'SELECT @extschema at ._raster_constraint_nodata_values(' || quote_ident($3)
|| ') FROM ' || fqtn
- || ' LIMIT 1';
+ || ' WHERE '
BEGIN
@@ -8043,7 +8060,9 @@
sql := 'SELECT @extschema at ._raster_constraint_out_db(' || quote_ident($3)
|| ') FROM ' || fqtn
- || ' LIMIT 1';
+ || ' WHERE '
BEGIN
Modified: trunk/raster/test/regress/tickets.sql
--- trunk/raster/test/regress/tickets.sql 2019-06-12 11:38:52 UTC (rev 17510)
+++ trunk/raster/test/regress/tickets.sql 2019-06-12 13:08:50 UTC (rev 17511)
@@ -125,3 +125,12 @@
select '#3457', ST_Area((ST_DumpAsPolygons(ST_Clip(ST_ASRaster(ST_GeomFromText('POLYGON((0 0,100 0,100 100,0 100,0 0))',4326),ST_Addband(ST_MakeEmptyRaster(1,1,0,0,1,-1,0,0,4326),'32BF'::text,0,-1),'32BF'::text,1,-1), ST_GeomFromText('POLYGON((0 0,100 100,100 0,0 0))',4326)))).geom);
SELECT '#4412', exists(select ST_PixelAsPolygons(ST_AddBand(ST_MakeEmptyRaster(2, 2, 0, 0, 1, -1, 0, 0, 0), 1, '64BF', 0, 'NaN'), 1)) AS rast;
+#4308,
+CREATE TABLE table_4308 (r raster);
+INSERT INTO table_4308(r) values (NULL);
+INSERT INTO table_4308(r) SELECT ST_AddBand(ST_MakeEmptyRaster(10, 10, 1, 1, 2, 2, 0, 0,4326), 1, '8BSI'::text, -129, NULL);;
+SELECT AddRasterConstraints('table_4308', 'r');
+DROP TABLE table_4308;
\ No newline at end of file
Modified: trunk/raster/test/regress/tickets_expected
--- trunk/raster/test/regress/tickets_expected 2019-06-12 11:38:52 UTC (rev 17510)
+++ trunk/raster/test/regress/tickets_expected 2019-06-12 13:08:50 UTC (rev 17511)
@@ -18,3 +18,15 @@
#4102.2|-10
#3457|4950
#4412|t
+NOTICE: Adding SRID constraint
+NOTICE: Adding scale-X constraint
+NOTICE: Adding scale-Y constraint
+NOTICE: Adding blocksize-X constraint
+NOTICE: Adding blocksize-Y constraint
+NOTICE: Adding alignment constraint
+NOTICE: Adding number of bands constraint
+NOTICE: Adding pixel type constraint
+NOTICE: Adding nodata value constraint
+NOTICE: Adding out-of-database constraint
+NOTICE: Adding maximum extent constraint
+t
